    MMM-Remote-Control
    57 Posts 9 Posters 2.5k Views 8 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer
      Hey everyone!
      Even though MMM-Remote-Control is the most popular third-party MagicMirror² module (measured by GitHub stars), it looks like it never properly introduced here in the forum. Today’s v4 release seems like the perfect opportunity to change that!
      What is MMM-Remote-Control?
      MMM-Remote-Control lets you control your MagicMirror² from any device on your network – your phone, tablet, or computer. So you can control your mirror from your couch using your cell phone, for example.
      No need to SSH into your Pi or edit config files manually anymore. With a simple web interface, you can:
      • Show/hide modules on the fly
      • Adjust brightness and color temperature
      • Update modules and MagicMirror² itself
      • Install new modules directly from the interface
      • Edit your config.js with a visual editor
      • Restart or shut down your mirror
      • Send notifications and alerts
      • Control your monitor (turn on/off)
      • And much more through a comprehensive REST API
      How to use it?
      Just follow the instructions on the GitHub page.
      What’s new in v4?
      This release is the biggest update in years – a complete modernization of both the user interface and the underlying code:
      For Users:
      • Completely redesigned interface – Modern look, smoother animations, better usability
      • QR Code on your mirror – Just scan it with your phone to instantly access the remote control. No more typing IP addresses!
      Under the Hood:
      • Code modernized to current JavaScript standards
      • Massively expanded test suite for better reliability
      • Enhanced error handling throughout
      • Better documentation and maintainability
      Important Note: While there shouldn’t be any breaking changes, I recommend testing thoroughly after updating due to the extent of the changes.
      You can find the complete changelog and installation instructions on GitHub.
      I’m looking forward to your feedback! If you run into any issues or have ideas for improvements, feel free to open an issue on GitHub.
      Have fun with the update!
      Some Screenshots
      On Mobile Device
      Main Menu
      Power Menu
      View Menu
      optional QR Code on the mirror
      R M SnilleS 3 Replies Last reply Reply Quote 2
        rkorell @KristjanESPERANTO
        @KristjanESPERANTO Good Evening!
        Nice work!
        I like it but with this update it doesn’t work anymore (for me, at least).
        I get an error message: “Cannot GET /remote.html”.
        I first tried to update with
        git pull
        npm ci --omit=dev
        This runs smooth, but results in the mentioned error message (mirror restarted :-) :
        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Remote-Control $ npm ci --omit=dev
        > mmm-remote-control@4.0.1 postinstall
        > node scripts/postinstall.js
        modules.json already exists, skipping copy.
        > mmm-remote-control@4.0.1 prepare
        > simple-git-hooks || echo 'No problem. Skipping git hooks installation.'
        sh: 1: simple-git-hooks: not found
        added 38 packages, and audited 39 packages in 9s
        4 packages are looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        After this I’ve tried to do the manual installation via:
        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Remote-Control $ ~/MagicMirror/modules/MMM-Remote-Control/installer.sh
        this at least showed an error:
        Installation for the MagicMirror² Remote-Control module started!
        Notice: This script and the installed software is provided “as is”, without warranty of any kind, express or implied, including but not limited to the warranties of merchantability, fitness for a particular purpose and noninfringement. In no event shall the authors or copyright holders be liable for any claim, damages or other liability, whether in an action of contract, tort or otherwise, arising from, out of or in connection with the software or the use or other dealings in the software.
        >>> Continue? [y/N]? y
        Directory /home/pi/MagicMirror/modules/MMM-Remote-Control already exists.
        You are currently on the master branch.
        >>> Do you want to switch to the develop branch? [y/N]? N
        >>> Do you want to update your branch? [Y/n]? Y
        Pulling changes...
        Already up to date.
        Checking for new dependencies to install...
        added 38 packages, and audited 39 packages in 3s
        Done.
        Update finished!
        node:internal/modules/cjs/loader:1544
              throw err;
        **Error [ERR_REQUIRE_ESM**]: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/[eval] not supported.
        Instead change the require of index.js in /home/pi/MagicMirror/modules/MMM-Remote-Control/[eval] to a dynamic import() which is available in all CommonJS modules.
            at [eval]:1:13
            at [eval]-wrapper:6:24 {
          code: 'ERR_REQUIRE_ESM'
        Node.js v20.18.1
        >>> Do you want to view instructions on how to configure the module? [Y/n]? n
        You should also set an API key in your config section!
          It's dangerous to go alone! Take this.
          apiKey: ''
          I made it just for you.
        Have fun with the module, if you have any problems, please search for help on github or in the forum:
           Github : https://github.com/Jopyth/MMM-Remote-Control
           Forum  : https://forum.magicmirror.builders
        Do not forget to restart your MagicMirror² to activate the module! Installation finished.
        So my third and last try was a complete fresh installation - but again with no luck - and the same error message, which I’m not able to handle:
        pi@MagicMirrorPi5:~/MagicMirror/modules $ bash -c "$(curl -s https://raw.githubusercontent.com/Jopyth/MMM-Remote-Control/master/installer.sh)"
        >>> Continue? [y/N]? y
        MagicMirror² detected in: /home/pi/MagicMirror
        >>> Is this correct and do you want to start installation? [y/N]? y
        You can use either the master or the develop branch.
        The develop branch contains more features, but is also more likely to cause errors or crashes.
        This can be changed later by executing this script again, or using the git branch command.
        By default the master branch will be installed.
        >>> Do you want to install the develop branch instead? [y/N]? n
        Cloning the repository on master branch...
        Cloning into 'MMM-Remote-Control'...
        remote: Enumerating objects: 2748, done.
        remote: Counting objects: 100% (1098/1098), done.
        remote: Compressing objects: 100% (317/317), done.
        remote: Total 2748 (delta 866), reused 932 (delta 780), pack-reused 1650 (from 3)
        Receiving objects: 100% (2748/2748), 2.50 MiB | 1.13 MiB/s, done.
        Resolving deltas: 100% (1913/1913), done.
        Installing dependencies...
        Successfully created modules.json from template.
        Done.
              throw err;
        **Error [ERR_REQUIRE_ESM]**: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/[eval] not supported.
            at [eval]:1:13
        Node.js v20.18.1
          apiKey: ''
        Do you please have a hint for me how to solve this?
        MM is running on a Pi5 / NVME.
        Thanks for any advice!
        Warmest regards,
        Ralf
          KristjanESPERANTO Module Developer @rkorell
          @rkorell said in MMM-Remote-Control:
          Node.js v20.18.1
          @rkorell Thanks for the feedback and the good error description! I’ll optimize the error logging, but unfortunately you have to update to at least node 22. I recommend version 24.
          For the current MagicMirror version, you also need at least version 22.
          BKeyportB R 2 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            BKeyport Module Developer @KristjanESPERANTO
            what’s with the microupdates? I’ve updated three times today. 🤣
              S374n
              4 updates today… :/ Kind of annoying to see the mirror changes the view with this notification.
              anyway:
              1. GUI looks better. Thanks!
              2. First update changes my main.css - took me a while to figure it out and redo all my customizations.
              3. Restart - doesn’t work. Shutdown i didn’t even try.
              4. Restart Magicmirror2 - doesn’t work, says mm2 is not running.
              5. Turn monitor on/off doesn’t work.
              6. Minimize browser does it but then no way to revert. So point less, now need to reboot.
              Any way to make it SSH from the phone? :)
                @KristjanESPERANTO
                OK…
                New version now shows the same error…
                Actually my mirror works pretty fine…
                So I hesitate to update node …
                What are the risks - and if: How do I do update node?
                • Will my mirror run afterwards or do I have to upgrade the mirror as well?
                Thanks for any advise!
                Warmest regards,
                Ralf
                I’m not able to attach the logfile…
                [2025-12-20T10_58_15_392Z-debug-0.log](Invalid file type. Allowed types are: .jpg, .jpeg, .png, .gif, .png, .jpg, .jpeg, .gif)
                  sdetweil @rkorell
                  @rkorell to upgrade node use one of the tools
                  nvm or n
                  I prefer n
                  stop MagicMirror if running
                  sudo npm install n -g
                  sudo n 22.18
                  hash -r
                  node -v
                  Should confirm node is upgraded
                  Now we need to fix the MagicMirror dependencies
                  rm -rf node_modules
                  npm install
                  Then start MagicMirror
                  In the future, if you want to upgrade MagicMirror, use my upgrade script and it will also upgrade node if necessary
                    sdetweil @rkorell
                    @rkorell you can only upload pics here, you can paste some of the log into a message ( use the code block )
                      rkorell @sdetweil
                      Dear Sam,
                      thanks for this.
                      Until now I had avoided to upgrade with the thought “never touch a running system” …
                      Now it seems to be time for an upgrade - because I like MMM-Remote-Control.
                      @kristjanesperanto said: " at least node 22. I recommend version 24" - would one of these versions be installed by your current upgrade-script?
                      Than I would feel much better using your script than doing it manually …
                      As far as I remember i had some local (code) modifications in standard-weather module - this would prevent your upgrade-script from upgrading, as far as I remember.
                      Is this still true? And if yes: There was a “force” ooption in the script?
                      Thanks a lot for your work!
                      Warmest regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell force was if you already had started installing MM and had the latest code… NOT if you have code changes
                        the upgrade will report if files are changed and allow you to save them in git. but generally its intended to remind you where you made changes and do something about it…
                        the node upgrade should not impact the running MM… (I say that with ’ quote marks, cause I am not sure…)
                        WHY do you NEED the RemoteControl update?? if you don’t NEED it, then don’t take it…
                        • 1 / 6
