    MMM-Remote-Control
    57 Posts 9 Posters 14.1k Views 10 Watching
      Dear Sam,
      thanks for this.
      Until now I had avoided to upgrade with the thought “never touch a running system” …
      Now it seems to be time for an upgrade - because I like MMM-Remote-Control.
      @kristjanesperanto said: " at least node 22. I recommend version 24" - would one of these versions be installed by your current upgrade-script?
      Than I would feel much better using your script than doing it manually …
      As far as I remember i had some local (code) modifications in standard-weather module - this would prevent your upgrade-script from upgrading, as far as I remember.
      Is this still true? And if yes: There was a “force” ooption in the script?
      Thanks a lot for your work!
      Warmest regards,
      Ralf
      S 2 Replies Last reply
        sdetweil @rkorell
        @rkorell force was if you already had started installing MM and had the latest code… NOT if you have code changes
        the upgrade will report if files are changed and allow you to save them in git. but generally its intended to remind you where you made changes and do something about it…
        the node upgrade should not impact the running MM… (I say that with ’ quote marks, cause I am not sure…)
        WHY do you NEED the RemoteControl update?? if you don’t NEED it, then don’t take it…
        R 2 Replies Last reply
          sdetweil @rkorell
          @rkorell said in MMM-Remote-Control:
          today it will install node 22.18.0
          after Jan 1 (2 weeks away) it will install 22.21.1 (for the next release)
          R 1 Reply Last reply
            Good point!
            Unfortunately I’ve already DONE the upgrade of remote-control - and now it doesn’t work anymore :-)
              just ran a testrun of your upgrade script:
              pi@MagicMirrorPi5:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              Minimum Node version: v22.18.0
              Installed Node version: v20.18.1
              Node should be upgraded.
              Node.js upgrade defered, doing test run
              Minimum npm version: V10.9.2
              Installed npm version: V10.8.2
              npm should be upgraded.
              npm upgrade defered, doing test run  ...
              saving custom.css
              reverting to master branch from _fix_clipping, saving changed files
              would restore file modules/default/weather/current.njk before switch back to master branch
              would restore file package-lock.json before switch back to master branch
              would restore file package.json before switch back to master branch
              error: Your local changes to the following files would be overwritten by checkout:
                      package-lock.json
                      package.json
              Please commit your changes or stash them before you switch branches.
              Aborting
              unable to change back to master branch, stopping execution
              What does the last message mean?
              “unable to change back to master branch, stopping execution”
              What have I to do?
                BTW: Do you know if it is possible to restore the “old” version from remote-control?
                May THIS is the better option for me?
                  sdetweil @rkorell
                  @rkorell can you tell me when old was? luckily this module uses tags for releases, so you could restore to one of the previous releases…
                  in the module folder do
                  git fetch --all --tags
                  then when we figure out which release to try, we can
                  git checkout <tag_name>
                  Release 3.2.1 was about 5 months ago.
                    @sdetweil I’ve found V3.3.2 and just try "git checkout 1f451ce "
                      sdetweil @rkorell
                      @rkorell if you pull the tags, you can use the tag name
                      git checkout v3.3.2
                        For some really strange reasons, neither
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Remote-Control $ git fetch --all --tags
                        pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Remote-Control $ git fetch --tags
                        currently give any feedback…
                        So I’ve worked with the found git-hash:
                        This at least worked and rolled back to V. 3.3.2.
                        Unfortunately some dependencies (package-lock.json ???) are not strict enough, so the rollback produces an error message:
                        [ERROR] Error when loading MMM-Remote-Control: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js not supported.
                        So I downgraded UUID:
                        cd ~/MagicMirror/modules/MMM-Remote-Control
                        npm install uuid@9.0.1
                        npm ci --omit=dev
                        With this module is running again.
                        From now on I’m in a in ‘detached HEAD’ state - but this seems OK.
                        Thanks for your time, effort and always great help!
                        Ralf
                          sdetweil @rkorell
                          @rkorell I was just about to add that you needed to redo the npm install for the module after deleting the node_modules folder
                          else you were trying to run the new dependencies with the old code
                          but you fixed it…
                            Yes :-)
                            In fact I’ve used
                            npm ci --omit=dev
                            this does the deletion of the node_modules folder inherently AFAIK …
                            Thanks again, dear Sam!
                            Ralf
                              sdetweil @rkorell
                              npm ci
                              be careful… the package.json was built and tested on a cloud based virtual machine.
                              pi and other hardware types MAY need a different version of a dependency, i’ve only seen it myself twice in 6 years, but
                              npm ci uses the exact package.json
                              npm install will get the appropriate for this platform, even if the version changes.
                              anyhow… I use npm install --omit=dev when I do the installs script or MMM-Config
                                OK; thanks for this hint.
                                May npm install has avoided the resulting error which I had to solve…
                                Anyway: Thanks a LOT!
                                Regards,
                                Ralf
                                KristjanESPERANTOK 1 Reply Last reply
                                • KristjanESPERANTOK
                                  KristjanESPERANTO Module Developer @rkorell
                                  Thanks for the feedback!
                                  Since Sam has already addressed some of the issues, I won’t go into them again.
                                  A few problems were mentioned, some of which I have just addressed with v4.1.0. E.g.:
                                  • Restart/Shutdown: Should now also work on systems without PM2.
                                  • Minimize: Now says “restart to restore” so you know how to undo it.
                                  About the monitor control issue:
                                  This would be tricky to get running by default everywhere because every system uses different commands (X11/Wayland/etc). You have to check the Monitor Control docs and configure the right commands for your specific setup - the defaults won’t work everywhere.
                                  About the “npm install/npm ci” topic:
                                  Yes, npm ci can be problematic for modules with native dependencies that need platform-specific builds. However, MMM-Remote-Control only uses pure JavaScript dependencies (marked, qrcode, simple-git, swagger-ui-dist, uuid) - no native modules that require compilation.
                                  For this module, npm ci is actually the better choice because:
                                  • Guarantees exact tested versions which the developers released
                                  • Faster installation (no dependency resolution)
                                  • Same behavior in CI and production
                                  • No change on the package-lock.json
                                  So the warning about npm ci is valid in general, but doesn’t apply here.
                                  About the microupdates. Since the test suite does not a lot parts yet, some details simply go unnoticed after major changes. If you are not experiencing any problems with the module, you do not need to install every update.
                                  About node update: I recommend using nvm for node updates. This is also what is offered as default for Linux on the official download page. This makes many things easier - like if something does not work after an update, you can easily switch back to the previous node version. So you don’t need to be so afraid of updates.
                                  S R 2 Replies Last reply
                                    KristjanESPERANTO Module Developer @S374n
                                    @S374n said in MMM-Remote-Control:
                                    First update changes my main.css - took me a while to figure it out and redo all my customizations.
                                    You should not change main.css. All customizations should be made in custom.css: https://docs.magicmirror.builders/modules/customcss.html#custom-css
                                      sdetweil @KristjanESPERANTO
                                      @KristjanESPERANTO n also allows you to change version on the fly.
                                      One nvm ‘benefit’, it stores the node versions in the users home folder at .nvm
                                      So, on a multi-user system each user could have different node versions.
                                      As MagicMirror is deployed as only user, it’s functionally the same.
                                      One n benefit, it stores the version in the /usr/ local folder
                                      So it requires sudo to make the change, cannot be accidental
                                        @sdetweil said in MMM-Remote-Control:
                                        So it requires sudo to make the change, …
                                        This can also be seen as a disadvantage 🙂
                                          @KristjanESPERANTO maybe, if you never use sudo, but we use it very often
                                            meikelrix @KristjanESPERANTO
                                            @KristjanESPERANTO Hi, I very much like MMM-Remote-Control!
                                            The last update has possibly introduced an error with respect to the “Custom Menu Items” => I have a menu item which still shows, but the sub menu items don’t show anymore?
                                            Else wise please let me repeat: excellent job on MMM-Remote-Control!
                                            M 1 Reply Last reply
