    Does anyone know how to make the iFrame module refresh periodically?
    28 Posts 6 Posters 23.2k Views 6 Watching
      PeppaPigKilla
      on the config part I believe its just the URL. But on the iframe.js file, i think extra code would needed to be added.
      /* global Module */
      /* Magic Mirror
       * Module: iFrame
       * By Ben Williams http://desertblade.com
       * MIT Licensed.
      Module.register("iFrame",{
      		// Default module config.
      		defaults: {
      				height:"300px",
      				width:"100%"
      	// Override dom generator.
      	getDom: function() {
      		var iframe = document.createElement("IFRAME");
      		iframe.style = "border:0"
      		iframe.width = this.config.width;
      		iframe.height = this.config.height;
      		iframe.src =  this.config.url;
      		return iframe;
          window.setInterval("reloadIFrame();", 30000);
      function reloadIFrame() {
       document.frames["frameNameHere"].location.reload();
      C 2 Replies Last reply Reply Quote 0
        cnelso24 @PeppaPigKilla
        @PeppaPigKilla
        Thank you for taking the time to help! Although, I put this into the module code and still no updates after letting it sit for 15 minutes. I also put the
          @PeppaPigKilla
          Sorry the forum seems to be overloaded. I put this in my code and still no refreshing. I believe the problem is my iFrame does not have a specified name. I am only able to input the scr=“URL”. Not sure where to put iframe name = “name”. When generating an iFrame from google sheets it does not specify a name either.
            PeppaPigKilla
            I tried it and cant get it to work either. best reaching out to the author,
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
              @PeppaPigKilla the code that was added by you is after the return, so the code will never be reached.
              I suggest an interval which calls updateDom, which will be created after the DOM_OBJECTS_CREATED broadcast
              C 1 Reply Last reply Reply Quote 2
                cnelso24 @strawberry 3.141
                @strawberry-3.141
                Thanks for the suggestion. I wouldn’t know where to start with that though. I tried this module which did not work refresh for me either.
                strawberry 3.141S K 2 Replies Last reply Reply Quote 0
                  strawberry 3.141 Project Sponsor Module Developer @cnelso24
                  @cnelso24 the problem is probably that there isnt a change detected when updating the dom, try to add a timestamp attribute to the iframe.
                  • K Offline
                    kevsfastz @cnelso24
                    @cnelso24
                    I have found a fix for this module which I posted here:
                    https://github.com/TheBogueRat/MMM-iFrameReload/issues/2
                    Kev
                    C 2 Replies Last reply Reply Quote 1
                      cnelso24 @kevsfastz
                      @kevsfastz
                      Thank you!! I will check it out when I get home.
                        cnelso24 @kevsfastz
                        @kevsfastz
                        Just got a chance to try this. Works like a charm! Thank you!
