    Does anyone know how to make the iFrame module refresh periodically?
    28 Posts 6 Posters 24.7k Views 6 Watching
      cnelso24
      I have a google spreadsheet displayed, but the problem is it only refresh the content when I restart Magic Mirror.
      • K Offline
        kevsfastz @cnelso24
        @cnelso24
        I have found a fix for this module which I posted here:
        https://github.com/TheBogueRat/MMM-iFrameReload/issues/2
        Kev
        C 2 Replies Last reply Reply Quote 1
          PeppaPigKilla
          Have a Read here http://stackoverflow.com/questions/5146805/an-iframe-i-need-to-refresh-every-30-seconds-but-not-the-whole-page
            cnelso24
            So would I put that code in the iFrame module that I downloaded or in my config.txt. Sorry I’ve barely programmed anything and yesterday was the first time I’ve ever used JavaScript
              PeppaPigKilla
              whats the iframe mod you downloaded ?
                cnelso24 @PeppaPigKilla
                @PeppaPigKilla
                link text
                The one listed on the MagicMirror website
                  PeppaPigKilla
                  on the config part I believe its just the URL. But on the iframe.js file, i think extra code would needed to be added.
                  /* global Module */
                  /* Magic Mirror
                   * Module: iFrame
                   * By Ben Williams http://desertblade.com
                   * MIT Licensed.
                  Module.register("iFrame",{
                  		// Default module config.
                  		defaults: {
                  				height:"300px",
                  				width:"100%"
                  	// Override dom generator.
                  	getDom: function() {
                  		var iframe = document.createElement("IFRAME");
                  		iframe.style = "border:0"
                  		iframe.width = this.config.width;
                  		iframe.height = this.config.height;
                  		iframe.src =  this.config.url;
                  		return iframe;
                      window.setInterval("reloadIFrame();", 30000);
                  function reloadIFrame() {
                   document.frames["frameNameHere"].location.reload();
                  C 2 Replies Last reply Reply Quote 0
                    @PeppaPigKilla
                    Thank you for taking the time to help! Although, I put this into the module code and still no updates after letting it sit for 15 minutes. I also put the
                      @PeppaPigKilla
                      Sorry the forum seems to be overloaded. I put this in my code and still no refreshing. I believe the problem is my iFrame does not have a specified name. I am only able to input the scr=“URL”. Not sure where to put iframe name = “name”. When generating an iFrame from google sheets it does not specify a name either.
                        PeppaPigKilla
                        I tried it and cant get it to work either. best reaching out to the author,
                        • strawberry 3.141S Offline
                          strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
                          @PeppaPigKilla the code that was added by you is after the return, so the code will never be reached.
                          I suggest an interval which calls updateDom, which will be created after the DOM_OBJECTS_CREATED broadcast
                          C 1 Reply Last reply Reply Quote 2
                            cnelso24 @strawberry 3.141
                            @strawberry-3.141
                            Thanks for the suggestion. I wouldn’t know where to start with that though. I tried this module which did not work refresh for me either.
                            strawberry 3.141S K 2 Replies Last reply Reply Quote 0
                              strawberry 3.141 Project Sponsor Module Developer @cnelso24
                              @cnelso24 the problem is probably that there isnt a change detected when updating the dom, try to add a timestamp attribute to the iframe.
                              • K Offline
                                kevsfastz @cnelso24
                                @cnelso24
                                Kev
                                  cnelso24 @kevsfastz
                                  @kevsfastz
                                  Thank you!! I will check it out when I get home.
                                    cnelso24 @kevsfastz
                                    @kevsfastz
                                    Just got a chance to try this. Works like a charm! Thank you!
                                    • F Offline
                                      fox
                                      @kevsfastz is it possible to show simple html content and update periodically?
                                      Issues With MMM-WatchDog known?
                                      https://forum.magicmirror.builders/post/29827
                                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                      • K Offline
                                        kevsfastz @fox
                                        @fox
                                        The simple answer is yes it is possible. What is your goal specifically?
                                        • Mitch1138M Offline
                                          Mitch1138
                                          Many thanks, I have bee looking for a way to do this for some time. I loaded iFrameReload with the following url. It will load, but not update. Any suggestions as to what I am missing?
                                          url: “http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland”,
                                          Many thanks
                                          • K Offline
                                            kevsfastz @Mitch1138
                                            @Mitch1138
                                            As mentioned above, I have provided a fix or adjustment by adjusting the MMM-IframeReload.js below:
                                              Mitch1138
                                              My mistake, I thought this was updated in the .git. I added the timestamp as you suggested (iframe.src = this.config.url + new Date().getTime();). The url does update now, but since the url displays the tides at a location embedded in the url, it looks like the timestamp is appended to the location. With this added, it is not a valid location and the tides don’t display.
                                              Again, many thanks for your help.
