Does anyone know how to make the iFrame module refresh periodically?
28 Posts 6 Posters 22.7k Views 6 Watching
    cnelso24
    I have a google spreadsheet displayed, but the problem is it only refresh the content when I restart Magic Mirror.
    • K Offline
      kevsfastz @cnelso24
      @cnelso24
      I have found a fix for this module which I posted here:
      https://github.com/TheBogueRat/MMM-iFrameReload/issues/2
      Kev
      C 2 Replies Last reply Jan 31, 2017, 3:25 PM Reply Quote 1
        PeppaPigKilla
        Have a Read here http://stackoverflow.com/questions/5146805/an-iframe-i-need-to-refresh-every-30-seconds-but-not-the-whole-page
          cnelso24
          So would I put that code in the iFrame module that I downloaded or in my config.txt. Sorry I’ve barely programmed anything and yesterday was the first time I’ve ever used JavaScript
            PeppaPigKilla
            whats the iframe mod you downloaded ?
            C 1 Reply Last reply Jan 29, 2017, 1:46 AM Reply Quote 0
              cnelso24 @PeppaPigKilla
              @PeppaPigKilla
              link text
              The one listed on the MagicMirror website
                PeppaPigKilla
                on the config part I believe its just the URL. But on the iframe.js file, i think extra code would needed to be added.
                /* global Module */
                /* Magic Mirror
                 * Module: iFrame
                 * By Ben Williams http://desertblade.com
                 * MIT Licensed.
                Module.register("iFrame",{
                		// Default module config.
                		defaults: {
                				height:"300px",
                				width:"100%"
                	// Override dom generator.
                	getDom: function() {
                		var iframe = document.createElement("IFRAME");
                		iframe.style = "border:0"
                		iframe.width = this.config.width;
                		iframe.height = this.config.height;
                		iframe.src =  this.config.url;
                		return iframe;
                    window.setInterval("reloadIFrame();", 30000);
                function reloadIFrame() {
                 document.frames["frameNameHere"].location.reload();
                C 2 Replies Last reply Jan 29, 2017, 6:45 PM Reply Quote 0
                  @PeppaPigKilla
                  Thank you for taking the time to help! Although, I put this into the module code and still no updates after letting it sit for 15 minutes. I also put the
                    @PeppaPigKilla
                    Sorry the forum seems to be overloaded. I put this in my code and still no refreshing. I believe the problem is my iFrame does not have a specified name. I am only able to input the scr=“URL”. Not sure where to put iframe name = “name”. When generating an iFrame from google sheets it does not specify a name either.
                      PeppaPigKilla
                      I tried it and cant get it to work either. best reaching out to the author,
                      S 1 Reply Last reply Jan 29, 2017, 9:12 PM Reply Quote 0
                        strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
                        @PeppaPigKilla the code that was added by you is after the return, so the code will never be reached.
                        I suggest an interval which calls updateDom, which will be created after the DOM_OBJECTS_CREATED broadcast
                        C 1 Reply Last reply Jan 30, 2017, 12:27 AM Reply Quote 2
                        1 / 3
