    Does anyone know how to make the iFrame module refresh periodically?
    28 Posts 6 Posters 25.5k Views 6 Watching
      PeppaPigKilla
      whats the iframe mod you downloaded ?
      C 1 Reply Last reply
        cnelso24 @PeppaPigKilla
        @PeppaPigKilla
        link text
        The one listed on the MagicMirror website
          PeppaPigKilla
          on the config part I believe its just the URL. But on the iframe.js file, i think extra code would needed to be added.
          /* global Module */
          /* Magic Mirror
           * Module: iFrame
           * By Ben Williams http://desertblade.com
           * MIT Licensed.
          Module.register("iFrame",{
          		// Default module config.
          		defaults: {
          				height:"300px",
          				width:"100%"
          	// Override dom generator.
          	getDom: function() {
          		var iframe = document.createElement("IFRAME");
          		iframe.style = "border:0"
          		iframe.width = this.config.width;
          		iframe.height = this.config.height;
          		iframe.src =  this.config.url;
          		return iframe;
              window.setInterval("reloadIFrame();", 30000);
          function reloadIFrame() {
           document.frames["frameNameHere"].location.reload();
          C 2 Replies Last reply
            @PeppaPigKilla
            Thank you for taking the time to help! Although, I put this into the module code and still no updates after letting it sit for 15 minutes. I also put the
              @PeppaPigKilla
              Sorry the forum seems to be overloaded. I put this in my code and still no refreshing. I believe the problem is my iFrame does not have a specified name. I am only able to input the scr=“URL”. Not sure where to put iframe name = “name”. When generating an iFrame from google sheets it does not specify a name either.
                PeppaPigKilla
                I tried it and cant get it to work either. best reaching out to the author,
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
                  @PeppaPigKilla the code that was added by you is after the return, so the code will never be reached.
                  I suggest an interval which calls updateDom, which will be created after the DOM_OBJECTS_CREATED broadcast
                  Reply Quote 2
                    cnelso24 @strawberry 3.141
                    @strawberry-3.141
                    Thanks for the suggestion. I wouldn’t know where to start with that though. I tried this module which did not work refresh for me either.
                    strawberry 3.141S K 2 Replies Last reply
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @cnelso24
                      @cnelso24 the problem is probably that there isnt a change detected when updating the dom, try to add a timestamp attribute to the iframe.
                      • K
                        kevsfastz @cnelso24
                        @cnelso24
                        I have found a fix for this module which I posted here:
                        https://github.com/TheBogueRat/MMM-iFrameReload/issues/2
                        Kev
                          cnelso24 @kevsfastz
                          @kevsfastz
                          Thank you!! I will check it out when I get home.
                            cnelso24 @kevsfastz
                            @kevsfastz
                            Just got a chance to try this. Works like a charm! Thank you!
                            • foxF
                              fox
                              @kevsfastz is it possible to show simple html content and update periodically?
                              Issues With MMM-WatchDog known?
                              https://forum.magicmirror.builders/post/29827
                              Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                              K 1 Reply Last reply
                              • K
                                kevsfastz @fox
                                @fox
                                The simple answer is yes it is possible. What is your goal specifically?
                                foxF 1 Reply Last reply
                                • Mitch1138M
                                  Mitch1138
                                  Many thanks, I have bee looking for a way to do this for some time. I loaded iFrameReload with the following url. It will load, but not update. Any suggestions as to what I am missing?
                                  url: “http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland”,
                                  Many thanks
                                  • K
                                    kevsfastz @Mitch1138
                                    @Mitch1138
                                    As mentioned above, I have provided a fix or adjustment by adjusting the MMM-IframeReload.js below:
                                    • Mitch1138M
                                      Mitch1138
                                      My mistake, I thought this was updated in the .git. I added the timestamp as you suggested (iframe.src = this.config.url + new Date().getTime();). The url does update now, but since the url displays the tides at a location embedded in the url, it looks like the timestamp is appended to the location. With this added, it is not a valid location and the tides don’t display.
                                      Again, many thanks for your help.
                                      • K
                                        @Mitch1138
                                        I see what you mean with the URL, any variables you add at the end even a ? will result in displaying all zeros on the output. You can get around this by using a site such asTHIS to refresh this URL for you instead of using iFrame to call a refresh. Of course all these sites will have advertisments which you do not want displayed on your mirror… so what you COULD do is reposition the iframe so the advertisment is hidden in one of the top corners. For example you can add margins with negative values to the iframe style:
                                        iframe.style = “border:0;margin-bottom:-110px;margin-left:-10px;;width:500px;height:450px;filter:invert(100%);”
                                        Of course this is not the best nor the most clean solution… maybe someone else has some ideas?
                                        • foxF
                                          fox @kevsfastz
                                          @kevsfastz said in Does anyone know how to make the iFrame module refresh periodically?:
                                          @fox
                                          I have another raspberry who gets temperatures with one-wire-sensors.
                                          This i provide in a simple homepage:
                                              <div>
                                                <div>
                                              <h2>...</h2>
                                          	<p><b>Temperaturen:</b></p>
                                              <p>Luft:............ -3.5°</p>
                                          	<p>Dach:........... -2.5°</p>
                                          	<p>Pool: ............3.5°</p>
                                          	<p><b>Status: </b></p>
                                          	<p>Pumpe:........... <b>Aus</b></p>
                                              <p>Solarheizung:...<b>Aus</b></p>
                                              <br />
                                          	<p><b>Meta: </b></p>
                                              <p>System:...........Linux 4.1.19+ armv6l</p>
                                          	<p>CPU Temp:....14.260°</p>
                                          	<p>Sensors...........3 x DS18B20 @ 5V </p>
                                              <p>Last Update:......Mon 13-02-2017, 19:40:05 Uhr</p>
                                          	</div>
                                          	<p>....</p>
                                              </div>
                                          how to show this, or parts of it?
                                          edit:(the html header will not be shown in this forum framework :walking:
                                          • K
                                            kevsfastz @fox
                                            @fox
                                            This depends on the output of your other Pi. If you already have this output displayed in say HTML format ( I assume that’s what you mean when you say simple homepage?) you can easily place this in iFrame via local URL. The best way would be to create its own page so you can control the output, then you can use CSS styles to adjust colors, size, placement etc.
