    Does anyone know how to make the iFrame module refresh periodically?
    28 Posts 6 Posters 25.5k Views 6 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
      @PeppaPigKilla the code that was added by you is after the return, so the code will never be reached.
      I suggest an interval which calls updateDom, which will be created after the DOM_OBJECTS_CREATED broadcast
      C 1 Reply Last reply
      Reply Quote 2
        cnelso24 @strawberry 3.141
        @strawberry-3.141
        Thanks for the suggestion. I wouldn’t know where to start with that though. I tried this module which did not work refresh for me either.
        strawberry 3.141S K 2 Replies Last reply
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @cnelso24
          @cnelso24 the problem is probably that there isnt a change detected when updating the dom, try to add a timestamp attribute to the iframe.
          • K
            kevsfastz @cnelso24
            @cnelso24
            I have found a fix for this module which I posted here:
            https://github.com/TheBogueRat/MMM-iFrameReload/issues/2
            Kev
            C 2 Replies Last reply
              cnelso24 @kevsfastz
              @kevsfastz
              Thank you!! I will check it out when I get home.
                cnelso24 @kevsfastz
                @kevsfastz
                Just got a chance to try this. Works like a charm! Thank you!
                • foxF
                  fox
                  @kevsfastz is it possible to show simple html content and update periodically?
                  K 1 Reply Last reply
                  • K
                    kevsfastz @fox
                    @fox
                    The simple answer is yes it is possible. What is your goal specifically?
                    foxF 1 Reply Last reply
                    • Mitch1138M
                      Mitch1138
                      Many thanks, I have bee looking for a way to do this for some time. I loaded iFrameReload with the following url. It will load, but not update. Any suggestions as to what I am missing?
                      url: “http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland”,
                      Many thanks
                      • K
                        kevsfastz @Mitch1138
                        @Mitch1138
                        As mentioned above, I have provided a fix or adjustment by adjusting the MMM-IframeReload.js below:
                        • Mitch1138M
                          Mitch1138
                          My mistake, I thought this was updated in the .git. I added the timestamp as you suggested (iframe.src = this.config.url + new Date().getTime();). The url does update now, but since the url displays the tides at a location embedded in the url, it looks like the timestamp is appended to the location. With this added, it is not a valid location and the tides don’t display.
                          Again, many thanks for your help.
                          • K
                            @Mitch1138
                            I see what you mean with the URL, any variables you add at the end even a ? will result in displaying all zeros on the output. You can get around this by using a site such asTHIS to refresh this URL for you instead of using iFrame to call a refresh. Of course all these sites will have advertisments which you do not want displayed on your mirror… so what you COULD do is reposition the iframe so the advertisment is hidden in one of the top corners. For example you can add margins with negative values to the iframe style:
                            iframe.style = “border:0;margin-bottom:-110px;margin-left:-10px;;width:500px;height:450px;filter:invert(100%);”
                            Of course this is not the best nor the most clean solution… maybe someone else has some ideas?
                            • foxF
                              fox @kevsfastz
                              @kevsfastz said in Does anyone know how to make the iFrame module refresh periodically?:
                              @fox
                              I have another raspberry who gets temperatures with one-wire-sensors.
                              This i provide in a simple homepage:
                                  <div>
                                    <div>
                                  <h2>...</h2>
                              	<p><b>Temperaturen:</b></p>
                                  <p>Luft:............ -3.5°</p>
                              	<p>Dach:........... -2.5°</p>
                              	<p>Pool: ............3.5°</p>
                              	<p><b>Status: </b></p>
                              	<p>Pumpe:........... <b>Aus</b></p>
                                  <p>Solarheizung:...<b>Aus</b></p>
                                  <br />
                              	<p><b>Meta: </b></p>
                                  <p>System:...........Linux 4.1.19+ armv6l</p>
                              	<p>CPU Temp:....14.260°</p>
                              	<p>Sensors...........3 x DS18B20 @ 5V </p>
                                  <p>Last Update:......Mon 13-02-2017, 19:40:05 Uhr</p>
                              	</div>
                              	<p>....</p>
                                  </div>
                              how to show this, or parts of it?
                              edit:(the html header will not be shown in this forum framework :walking:
                              • K
                                kevsfastz @fox
                                @fox
                                This depends on the output of your other Pi. If you already have this output displayed in say HTML format ( I assume that’s what you mean when you say simple homepage?) you can easily place this in iFrame via local URL. The best way would be to create its own page so you can control the output, then you can use CSS styles to adjust colors, size, placement etc.
                                • foxF
                                  fox @kevsfastz
                                  @fox
                                  Thank you for your answer. I tried of course, but I got only a white line on the screen.
                                  • K
                                    kevsfastz @fox
                                    @fox
                                    Can you show a sample of your code? I assume the URL is working fine in a web browser?
                                    • foxF
                                      fox @kevsfastz
                                      @kevsfastz
                                      Above is a sample of the code(the weird forum framework removed the headd of the html )
                                      Yes it is working very fine in the web browser
                                      Does this help you?
                                      Thank you in advance !
                                      • foxF
                                        fox
                                        • foxF
                                          fox
                                          created new thread because this one is solved with the original issue
