    Failed to Connect to Wayland Display
    17 Posts 3 Posters 861 Views 3 Watching
      atwist
      Yes, pm2.
      Here is that file.
      #!/bin/bash
      This file is still here to keep PM2 working on older installations.
      DISPLAY=:0 npm start
        sdetweil @atwist
        @atwist yes, that is the file, should have started in default mode
        there is an updated version
        can you replace all the lines of text there with this
        #!/bin/bash
        if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
           # if WAYLAND_DISPLAYis set, use it, else set to -0
           export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
           npm run start:wayland
        else
        fi
          atwist
          I updated that file but the error still exists.
          0|MagicMirror | [3709:0102/125357.807528:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
          0|MagicMirror | [3709:0102/125357.807690:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
          0|MagicMirror | [3709:0102/125357.807720:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
          0|MagicMirror | /home/twist/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
            sdetweil @atwist
            @atwist interesting
            can you do this
            npm start
              atwist
              Yes, that starts everything and gets me running like normal. Thanks!
              So how do I get it to run on reboot moving forward?
                sdetweil @atwist
                @atwist weird… all the script does is the same thing…
                can you show me the part of the output from npm start like from my desktop
                ####  System Information  ####
                - SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false; MM: 2.34.0
                - OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-164-generic
                - VERSIONS: electron: undefined; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                - ENV:      XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                            WAYLAND_DISPLAY:  undefined; DISPLAY: :0.0; ELECTRON_ENABLE_GPU: undefined
                - RAM:      total: 48077.13 MB; free: 36485.14 MB; used: 11591.98 MB
                - OTHERS:   uptime: 21764 minutes; timeZone: America/Chicago
                you may have to npm start >somefile.txt
                then once up, ctrl-q,
                and edit the somefile.txt
                  atwist
                  Here is that information.
                  System Information
                  • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: 2.34.0
                  • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
                  • VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                  • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                    WAYLAND_DISPLAY: undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
                  • RAM: total: 3796.86 MB; free: 2669.80 MB; used: 1127.06 MB
                  • OTHERS: uptime: 3427 minutes; timeZone: America/Chicago
                    atwist
                    Do you happen to have any ideas to fix it moving forward? Thanks!
                    S C 2 Replies Last reply Reply Quote 0
                      sdetweil @atwist
                      @atwist how are you starting MagicMirror?
                      pm2? How did you install MagicMirror
                      If my script, then look at
                      ~/MagicMirror/installers/mm.sh
                        chrisfr1976 @atwist
                        @atwist
                        You could try this as start script:
                        #!/bin/bash
                        export DISPLAY=:0
                        export ELECTRON_OZONE_PLATFORM_HINT=x11
                        npm start
                        The --ozone-platform-hint=x11 flag overrides the automatic detection and forces Electron into X11 mode. Maybe……
                        Regards, Chris.
