    Failed to Connect to Wayland Display
    58 Posts 7 Posters 14.3k Views 6 Watching
      sdetweil @atwist
      @atwist interesting
      can you do this
      npm start
        atwist
        Yes, that starts everything and gets me running like normal. Thanks!
        So how do I get it to run on reboot moving forward?
          sdetweil @atwist
          @atwist weird… all the script does is the same thing…
          can you show me the part of the output from npm start like from my desktop
          ####  System Information  ####
          - SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false; MM: 2.34.0
          - OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-164-generic
          - VERSIONS: electron: undefined; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
          - ENV:      XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                      WAYLAND_DISPLAY:  undefined; DISPLAY: :0.0; ELECTRON_ENABLE_GPU: undefined
          - RAM:      total: 48077.13 MB; free: 36485.14 MB; used: 11591.98 MB
          - OTHERS:   uptime: 21764 minutes; timeZone: America/Chicago
          you may have to npm start >somefile.txt
          then once up, ctrl-q,
          and edit the somefile.txt
            atwist
            Here is that information.
            System Information
            • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: 2.34.0
            • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
            • VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
            • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
              WAYLAND_DISPLAY: undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
            • RAM: total: 3796.86 MB; free: 2669.80 MB; used: 1127.06 MB
            • OTHERS: uptime: 3427 minutes; timeZone: America/Chicago
              atwist
              Do you happen to have any ideas to fix it moving forward? Thanks!
              S C 2 Replies Last reply Reply Quote 0
                sdetweil @atwist
                @atwist how are you starting MagicMirror?
                pm2? How did you install MagicMirror
                If my script, then look at
                ~/MagicMirror/installers/mm.sh
                  chrisfr1976 @atwist
                  @atwist
                  You could try this as start script:
                  #!/bin/bash
                  export DISPLAY=:0
                  export ELECTRON_OZONE_PLATFORM_HINT=x11
                  npm start
                  The --ozone-platform-hint=x11 flag overrides the automatic detection and forces Electron into X11 mode. Maybe……
                  Regards, Chris.
                    atwist
                    I don’t remember how i installed it but I don’t have MagicMirro.sh so i must not have used your script.
                      atwist @chrisfr1976
                      @chrisfr1976 Thanks for the reply. Sorry but how would i do that?
                        sdetweil @atwist
                        @atwist script name error, I made a shortcut for mm and didn’t catch it expanding there
                          atwist @sdetweil
                          @sdetweil ahh okay. I do have that file. What am I looking for in it though.?
                          S A 2 Replies Last reply Reply Quote 0
                            sdetweil @atwist
                            @atwist can you run this from the command line , and show the results
                            ps -ef | grep -v grep | grep -i -e xway -e labwc
                              atwist @atwist
                              nothing is returned
                                sdetweil @atwist
                                @atwist ok, weird, that is the command set I use on mm.sh to determine if Wayland is running or not
                                Does your mm.sh have those commands listed?
                                  atwist @sdetweil
                                  Yes it does:
                                  if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc
                                     # if WAYLAND_DISPLAYis set, use it, else set to -0
                                     export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                     npm run start:wayland
                                  else
                                     DISPLAY=:0 npm start
                                  fi
                                    sdetweil @atwist
                                    @atwist
                                    So it shouldn’t be trying to start using wayland
                                    And npm start on 2.34.0 uses x11
                                      atwist
                                      weird. Any suggestionon what to do?
                                        sdetweil @atwist
                                        @atwist move the script to another name
                                        Try this instead
                                        #!/bin/bash
                                        npm start
                                        Save that as mm.sh then do
                                        chmod +x mm.sh
                                        Then try
                                        pm2 start MagicMirror
                                          atwist @sdetweil
                                          @sdetweil thanks. It shows that the process started successfully but it doesn’t appear on the screen.
                                            sdetweil @atwist
                                            @atwist you are on the pi directly, right? Not via ssh or vnc
