    Failed to Connect to Wayland Display
    58 Posts 7 Posters 12.7k Views 6 Watching
      sdetweil @atwist
      @atwist yes, that is the file, should have started in default mode
      there is an updated version
      can you replace all the lines of text there with this
      #!/bin/bash
      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
         # if WAYLAND_DISPLAYis set, use it, else set to -0
         export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
         npm run start:wayland
      else
         DISPLAY=:0 npm start
      fi
        atwist
        I updated that file but the error still exists.
        0|MagicMirror | [3709:0102/125357.807528:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
        0|MagicMirror | [3709:0102/125357.807690:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
        0|MagicMirror | [3709:0102/125357.807720:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
        0|MagicMirror | /home/twist/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          sdetweil @atwist
          @atwist interesting
          can you do this
          npm start
            atwist
            Yes, that starts everything and gets me running like normal. Thanks!
            So how do I get it to run on reboot moving forward?
              sdetweil @atwist
              @atwist weird… all the script does is the same thing…
              can you show me the part of the output from npm start like from my desktop
              ####  System Information  ####
              - SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false; MM: 2.34.0
              - OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-164-generic
              - VERSIONS: electron: undefined; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
              - ENV:      XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                          WAYLAND_DISPLAY:  undefined; DISPLAY: :0.0; ELECTRON_ENABLE_GPU: undefined
              - RAM:      total: 48077.13 MB; free: 36485.14 MB; used: 11591.98 MB
              - OTHERS:   uptime: 21764 minutes; timeZone: America/Chicago
              you may have to npm start >somefile.txt
              then once up, ctrl-q,
              and edit the somefile.txt
                atwist
                Here is that information.
                System Information
                • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: 2.34.0
                • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
                • VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY: undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
                • RAM: total: 3796.86 MB; free: 2669.80 MB; used: 1127.06 MB
                • OTHERS: uptime: 3427 minutes; timeZone: America/Chicago
                  atwist
                  Do you happen to have any ideas to fix it moving forward? Thanks!
                  S C 2 Replies Last reply Reply Quote 0
                    sdetweil @atwist
                    @atwist how are you starting MagicMirror?
                    pm2? How did you install MagicMirror
                    If my script, then look at
                    ~/MagicMirror/installers/mm.sh
                      chrisfr1976 @atwist
                      @atwist
                      You could try this as start script:
                      #!/bin/bash
                      export DISPLAY=:0
                      export ELECTRON_OZONE_PLATFORM_HINT=x11
                      npm start
                      The --ozone-platform-hint=x11 flag overrides the automatic detection and forces Electron into X11 mode. Maybe……
                      Regards, Chris.
                        atwist
                        I don’t remember how i installed it but I don’t have MagicMirro.sh so i must not have used your script.
                          atwist @chrisfr1976
                          @chrisfr1976 Thanks for the reply. Sorry but how would i do that?
                            sdetweil @atwist
                            @atwist script name error, I made a shortcut for mm and didn’t catch it expanding there
                              atwist @sdetweil
                              @sdetweil ahh okay. I do have that file. What am I looking for in it though.?
                              S A 2 Replies Last reply Reply Quote 0
                                sdetweil @atwist
                                @atwist can you run this from the command line , and show the results
                                  atwist @atwist
                                  nothing is returned
                                    sdetweil @atwist
                                    @atwist ok, weird, that is the command set I use on mm.sh to determine if Wayland is running or not
                                    Does your mm.sh have those commands listed?
                                      atwist @sdetweil
                                      Yes it does:
                                      else
                                      fi
                                        sdetweil @atwist
                                        @atwist
                                        So it shouldn’t be trying to start using wayland
                                        And npm start on 2.34.0 uses x11
                                          atwist
                                          weird. Any suggestionon what to do?
                                            sdetweil @atwist
                                            @atwist move the script to another name
                                            Try this instead
                                            #!/bin/bash
                                            npm start
                                            Save that as mm.sh then do
                                            chmod +x mm.sh
                                            Then try
                                            pm2 start MagicMirror
