    Failed to Connect to Wayland Display
    58 Posts 7 Posters 6.8k Views 6 Watching
      atwist
      Here is that information.
      System Information
      • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: 2.34.0
      • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
      • VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
      • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
        WAYLAND_DISPLAY: undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
      • RAM: total: 3796.86 MB; free: 2669.80 MB; used: 1127.06 MB
      • OTHERS: uptime: 3427 minutes; timeZone: America/Chicago
        atwist
        Do you happen to have any ideas to fix it moving forward? Thanks!
        S C 2 Replies Last reply Reply Quote 0
          sdetweil @atwist
          @atwist how are you starting MagicMirror?
          pm2? How did you install MagicMirror
          If my script, then look at
          ~/MagicMirror/installers/mm.sh
            chrisfr1976 @atwist
            @atwist
            You could try this as start script:
            #!/bin/bash
            export DISPLAY=:0
            export ELECTRON_OZONE_PLATFORM_HINT=x11
            npm start
            The --ozone-platform-hint=x11 flag overrides the automatic detection and forces Electron into X11 mode. Maybe……
            Regards, Chris.
              atwist
              I don’t remember how i installed it but I don’t have MagicMirro.sh so i must not have used your script.
                atwist @chrisfr1976
                @chrisfr1976 Thanks for the reply. Sorry but how would i do that?
                  sdetweil @atwist
                  @atwist script name error, I made a shortcut for mm and didn’t catch it expanding there
                    atwist @sdetweil
                    @sdetweil ahh okay. I do have that file. What am I looking for in it though.?
                    S A 2 Replies Last reply Reply Quote 0
                      sdetweil @atwist
                      @atwist can you run this from the command line , and show the results
                      ps -ef | grep -v grep | grep -i -e xway -e labwc
                        atwist @atwist
                        nothing is returned
                          sdetweil @atwist
                          @atwist ok, weird, that is the command set I use on mm.sh to determine if Wayland is running or not
                          Does your mm.sh have those commands listed?
                            atwist @sdetweil
                            Yes it does:
                            if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc
                               # if WAYLAND_DISPLAYis set, use it, else set to -0
                               export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                               npm run start:wayland
                            else
                               DISPLAY=:0 npm start
                            fi
                              sdetweil @atwist
                              @atwist
                              So it shouldn’t be trying to start using wayland
                              And npm start on 2.34.0 uses x11
                                atwist
                                weird. Any suggestionon what to do?
                                  sdetweil @atwist
                                  @atwist move the script to another name
                                  Try this instead
                                  #!/bin/bash
                                  npm start
                                  Save that as mm.sh then do
                                  chmod +x mm.sh
                                  Then try
                                  pm2 start MagicMirror
                                    atwist @sdetweil
                                    @sdetweil thanks. It shows that the process started successfully but it doesn’t appear on the screen.
                                      sdetweil @atwist
                                      @atwist you are on the pi directly, right? Not via ssh or vnc
                                        sdetweil @atwist
                                        @atwist try adding these two lines in front of the
                                        export DISPLAY=:0
                                        npm start line
                                        And try the
                                        ./MagicMirror.sh again.
                                        May need to reboot before retry
                                          atwist @sdetweil
                                          @sdetweil yes directly on it
                                            atwist @sdetweil
                                            @sdetweil the file you are referring to is in the installers folder. Correct?
                                            It does start the interface with your suggestions. Is it able to start it in reboot since it no longer does?
