    Failed to Connect to Wayland Display
    58 Posts 7 Posters 6.8k Views 6 Watching
      atwist
      I updated that file but the error still exists.
      0|MagicMirror | [3709:0102/125357.807528:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
      0|MagicMirror | [3709:0102/125357.807690:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
      0|MagicMirror | [3709:0102/125357.807720:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
      0|MagicMirror | /home/twist/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        sdetweil @atwist
        @atwist interesting
        can you do this
        npm start
          atwist
          Yes, that starts everything and gets me running like normal. Thanks!
          So how do I get it to run on reboot moving forward?
            sdetweil @atwist
            @atwist weird… all the script does is the same thing…
            can you show me the part of the output from npm start like from my desktop
            ####  System Information  ####
            - SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false; MM: 2.34.0
            - OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-164-generic
            - VERSIONS: electron: undefined; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
            - ENV:      XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                        WAYLAND_DISPLAY:  undefined; DISPLAY: :0.0; ELECTRON_ENABLE_GPU: undefined
            - RAM:      total: 48077.13 MB; free: 36485.14 MB; used: 11591.98 MB
            - OTHERS:   uptime: 21764 minutes; timeZone: America/Chicago
            you may have to npm start >somefile.txt
            then once up, ctrl-q,
            and edit the somefile.txt
              atwist
              Here is that information.
              System Information
              • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: 2.34.0
              • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
              • VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
              • ENV: XDG_SESSION_TYPE: x11; MM_CONFIG_FILE: undefined
                WAYLAND_DISPLAY: undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
              • RAM: total: 3796.86 MB; free: 2669.80 MB; used: 1127.06 MB
              • OTHERS: uptime: 3427 minutes; timeZone: America/Chicago
                atwist
                Do you happen to have any ideas to fix it moving forward? Thanks!
                S C 2 Replies Last reply Reply Quote 0
                  sdetweil @atwist
                  @atwist how are you starting MagicMirror?
                  pm2? How did you install MagicMirror
                  If my script, then look at
                  ~/MagicMirror/installers/mm.sh
                    chrisfr1976 @atwist
                    @atwist
                    You could try this as start script:
                    #!/bin/bash
                    export DISPLAY=:0
                    export ELECTRON_OZONE_PLATFORM_HINT=x11
                    npm start
                    The --ozone-platform-hint=x11 flag overrides the automatic detection and forces Electron into X11 mode. Maybe……
                    Regards, Chris.
                      atwist
                      I don’t remember how i installed it but I don’t have MagicMirro.sh so i must not have used your script.
                        atwist @chrisfr1976
                        @chrisfr1976 Thanks for the reply. Sorry but how would i do that?
                          sdetweil @atwist
                          @atwist script name error, I made a shortcut for mm and didn’t catch it expanding there
                            atwist @sdetweil
                            @sdetweil ahh okay. I do have that file. What am I looking for in it though.?
                            S A 2 Replies Last reply Reply Quote 0
                              sdetweil @atwist
                              @atwist can you run this from the command line , and show the results
                              ps -ef | grep -v grep | grep -i -e xway -e labwc
                                atwist @atwist
                                nothing is returned
                                  sdetweil @atwist
                                  @atwist ok, weird, that is the command set I use on mm.sh to determine if Wayland is running or not
                                  Does your mm.sh have those commands listed?
                                    atwist @sdetweil
                                    Yes it does:
                                    if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc
                                       # if WAYLAND_DISPLAYis set, use it, else set to -0
                                       export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                       npm run start:wayland
                                    else
                                       DISPLAY=:0 npm start
                                    fi
                                      sdetweil @atwist
                                      @atwist
                                      So it shouldn’t be trying to start using wayland
                                      And npm start on 2.34.0 uses x11
                                        atwist
                                        weird. Any suggestionon what to do?
                                          sdetweil @atwist
                                          @atwist move the script to another name
                                          Try this instead
                                          #!/bin/bash
                                          npm start
                                          Save that as mm.sh then do
                                          chmod +x mm.sh
                                          Then try
                                          pm2 start MagicMirror
                                            atwist @sdetweil
                                            @sdetweil thanks. It shows that the process started successfully but it doesn’t appear on the screen.
