    Compliments text cycler without the randomizer
    14 Posts 4 Posters 9.3k Views 4 Watching
    • W Offline
      washichi
      I’m new to JavaScript, so please correct me here if needed!
      I gave it a go and deleted the randomness, didn’t try it out cause my RPI sin’t running, but this should work:
      https://gist.github.com/washichi/74a1b08025aa166c8c296a245b06a517
        cnelso24 @washichi
        @washichi
        it does not work. I tried loading your code into the compliments.js file and none of my modules loaded after that. Thank you for trying though. I am also very new, that’s why I am asking for help
        • cowboysdudeC Offline
          Easy way is if you don’t want random then enter just 1 entry under each time… ;) That way you don’t have to do anything to change it… it’ll just show what you want all the time …
          The compliments module isn’t random. It rotates through whatever is in the module according to the time of day…
          So if you want it say something different then change it :)
            cnelso24 @cowboysdude
            @cowboysdude
            hmm… good point but then it will only display 1 string at a time, am I correct? What I am trying to do is display 6-8 strings all the time in a specific order.
              @cnelso24 Do a search on here… someone was asking or trying to make this work with a separate json file that they wanted to create… maybe you can do it that way.
              Try this forum… near the bottom:
              https://forum.magicmirror.builders/topic/1460/personalize-compliments/6
              yawns was talking about something that could possibly work!
              • W Offline
                washichi @cnelso24
                @cnelso24 Okay, so what you want is more something like hello world, but 6 times.
                I’ll get my PI back tomorrow, I will setup magicmirror and play around with the modules.
                I’m planning on making my own module, so this is a good exercise :p
                I’ll let you know If I got it working
                • yawnsY Offline
                  yawns Moderator
                  I just put this together, based on the original compliments module. I am not sure if this should be added to the default module by PullRequest, which is why I created a standalone repository first.
                  [card:yawnsde/MMM-Compliments]
                  C 1 Reply Last reply Reply Quote 3
                    cnelso24 @yawns
                    @yawns
                    Thank you! I’ll check it out when I get home
                    • yawnsY Offline
                      yawns Moderator @cnelso24
                      @cnelso24
                      Hi, did you already test the fork? If so, could you provide some feedback, please? I’d like to follow up on the request and mark as resolved once you are happy with it.
                        cnelso24 @yawns
                        @yawns
                        I’m sorry I have not, I have been working overtime this week. I (hopefully) will get to test it out this evening.
