    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 23.7k Views 8 Watching
    • karsten13K Offline
      karsten13 @Mathes75
      @Mathes75
      probably python missing, see https://khassel.gitlab.io/magicmirror/faq/dependencies/#use-the-fat-image
      You can change the image in the .env file.
        Mathes75 @karsten13
        @karsten13 to get this right: Using the fat image would have at least python on board. And to get everything to work I would need to add a script, adding the dependencies for MMM-FRITZ-Box-Callmonitor-py3:
        Execute npm install to install the dependencies.
        (Optional) Execute sudo apt-get install python3-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install --break-system-packages fritzconnection to allow access to your FRITZ!Box phone book and recent calls. This can take a few minutes.
        Will definitely give it a try!
          Mathes75 @Mathes75
          Hello @karsten13,
          I have changed the docker image to fat in .env file. Unfortunately, after pulling the docker image, the script stopped with error: No such container: 1b169eacdb711[~35 more numbers/letters].
          Magic Mirror stopped working :( What did I do wrong?
            karsten13 @Mathes75
            @Mathes75
            which script?
            show content of “the script” and output of docker compose config
              Mathes75 @karsten13
              @karsten13
              Sorry for being that unspecific. I changed the .env file in the “Docker image to use” section:
              # Docker Images to use:
              MM_IMAGE="karsten13/magicmirror:v2.34.0_fat"
              LABWC_IMAGE="karsten13/labwc:latest"
              MMPM_IMAGE="karsten13/mmpm:latest"
              WATCHTOWER_IMAGE="ghcr.io/nicholas-fedor/watchtower:latest"
              Executed cd /opt/mm/run && docker compose up -d --force-recreate and the download started. After successfully pulling the image, Terminal stopped here:
               ✔ Image karsten13/magicmirror:fat Pulled                                318.2s
                 ✔ 304150113e8d                  Pull complete                          97.1s
                 ✔ 964f5c44c7bd                  Pull complete                           0.9s
                 ✔ ac8996972af0                  Pull complete                           0.9s
                 ✔ 3ee9d8e5c8b3                  Pull complete                         131.8s
                 ✔ f9b5315e0a0e                  Pull complete                           0.8s
                 ✔ 5e7a4985a616                  Pull complete                           0.7s
                 ✔ 9f175b8c171e                  Pull complete                          98.7s
                 ✔ c1be2df81e57                  Pull complete                           0.7s
                 ✔ 4f4fb700ef54                  Pull complete                           0.0s
                 ✔ 9dcfcb600955                  Pull complete                           1.0s
                 ✔ 0902543587b7                  Pull complete                         212.6s
                 ✔ 6454a8f98e11                  Pull complete                         314.9s
                 ✔ fe8e38a18048                  Pull complete                          97.6s
                 ✔ a4662295f62c                  Pull complete                           0.9s
                 ✔ c5dcf86b0f8a                  Pull complete                           1.0s
               ✔ Network magicmirror_default     Created                                 0.4s
               ✘ Container 1b169eacdb71          Error response from daemon: No such container: 1b169eacdb711404e12c838a79de243c677daaaea260867d04c133a86cc3025b 6.8s
              Output of docker compose config:
              services:
                labwc:
                  container_name: labwc
                  environment:
                    LAB_WC_HIDE_CURSOR: "true"
                    RANDR_PARAMS: ""
                    RANDR_POLL: 1m
                    XDG_RUNTIME_DIR: /tmp/labwc
                  image: karsten13/labwc:latest
                  networks:
                    default: null
                  privileged: true
                  restart: always
                  volumes:
                    - type: bind
                      source: /tmp/labwc
                      target: /tmp/labwc
                      bind: {}
                    - type: bind
                      source: /run/udev
                      target: /run/udev
                      bind: {}
                magicmirror:
                  container_name: mm
                  depends_on:
                    labwc:
                      condition: service_healthy
                      restart: true
                      required: true
                  environment:
                    DISPLAY: unix:0.0
                    ELECTRON_ENABLE_GPU: "0"
                    MM_CUSTOMCSS_FILE: css/custom.css
                    MM_MODULES_DIR: modules
                    MM_OVERRIDE_DEFAULT_MODULES: "true"
                    MM_SCENARIO: electron
                    MM_SHOW_CURSOR: "false"
                    WAYLAND_DISPLAY: wayland-0
                  image: karsten13/magicmirror:v2.34.0_fat
                  network_mode: host
                  privileged: true
                  restart: always
                  shm_size: "268435456"
                  volumes:
                    - type: bind
                      source: /tmp/.X11-unix
                      target: /tmp/.X11-unix
                      bind: {}
                    - type: bind
                      source: /home/pi/.Xauthority
                      target: /home/node/.Xauthority
                      bind: {}
                    - type: bind
                      source: /tmp/labwc
                      target: /tmp/labwc
                      bind: {}
                    - type: bind
                      source: /opt/mm/mounts/config
                      target: /opt/magic_mirror/config
                      bind: {}
                    - type: bind
                      source: /opt/mm/mounts/modules
                      target: /opt/magic_mirror/modules
                      bind: {}
                    - type: bind
                      source: /opt/mm/mounts/css/custom.css
                      target: /opt/magic_mirror/css/custom.css
                      bind: {}
                  post_start:
                    - command:
                        - /bin/sh
                        - -c
                          if [ "init" = "init" ]; then
                            # update volume permissions
                            chown -R 1000:1000 config modules css/custom.css
                            chmod -R 777 config modules css/custom.css
                          fi
                          if command -v node_modules/.bin/electron > /dev/null; then
                            # if electron is installed then start dbus-daemon to avoid errors in the logs
                            dbus-daemon --system || true
                          fi
                      user: root
              networks:
                default:
                karsten13 @Mathes75
                @Mathes75
                looks like there is an old container but no idea why docker is unable to remove it.
                You can try
                cd /opt/mm/run
                docker compose down
                docker rm -f $(docker ps -aq)
                  Mathes75 @karsten13
                  @karsten13
                  Doesn´t look good. I’m too noob about Docker to really understand what’s going on:
                  pi@magicmirrorMB:~ $ cd /opt/mm/run/
                  pi@magicmirrorMB:/opt/mm/run $ docker compose down
                  [+] down 1/1
                   ✔ Container 1b169eacdb71 Removed                                          0.0s
                  pi@magicmirrorMB:/opt/mm/run $ docker rm -f $(docker ps -aq)
                  pi@magicmirrorMB:/opt/mm/run $ docker compose up -d
                  WARN[0000] No services to build
                  [+] up 2/2
                   ✔ Network magicmirror_default Created                                     0.2s
                   ✔ Container mm                Created                                     0.9s
                  After last line just nothing happens. No prompt, no display on mirror.
                  Can I check where the strange container is called or where the reference is?
                    karsten13 @Mathes75
                    @Mathes75
                    show docker ps -a.
                    From the logs it looks like the strange container was deleted but I see no labwc container.
                      Mathes75 @karsten13
                      @karsten13
                      pi@magicmirrorMB:/opt/mm/run $ docker ps -a
                      CONTAINER ID   IMAGE                    COMMAND            CREATED      STATUS                    PORTS     NAMES
                      1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   8 days ago   Exited (128) 2 days ago
                      What? There must be something completely wrong…
                        Mathes75 @karsten13
                        @karsten13
                        Is there a way to reload the images from scratch, delete them from the RPi without losing the customization?
                          karsten13 @Mathes75
                          @Mathes75
                          really strange, the 1b1... is still there …
                          try docker system prune -f and check after this again docker ps -a
                            Mathes75 @karsten13
                            @karsten13
                            After docker compose down, prune resulted in Total reclaimed space: 0B .
                            When trying to start the containers and running the commands:
                            [+] up 2/2
                             ✔ Container mm                Created        0.5s
                            pi@magicmirrorMB:/opt/mm/run $ docker system prune -f
                            Deleted Containers:
                            b04e79ead19ae7e42b7c7899f8e9b4b2d4f870770362c684bfadbfdaae6725aa
                            Deleted Networks:
                            magicmirror_default
                            Total reclaimed space: 4.096kB
                            1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   9 days ago   Exited (128) 2 days ago
                            I think the easiest way is to start from scratch. Save the config.js, remember the modules and just reinstall. Switch to fat image again and fiddle around with FRITZ stuff. Sorry for keeping you busy and thanks a lot for your help and patience!
                            Let me know if you want to finish troubleshooting ;-)
                              karsten13 @Mathes75
                              @Mathes75
                              one thing (if not already done) would be a reboot and then again the prune command.
                              Otherwise start from scratch …
                                Mathes75 @karsten13
                                @karsten13
                                To make it short - same. Will start from scratch and let you know.
                                  Mathes75 @Mathes75
                                  Short and final update on this - I give up.
                                  Reimaged the card, edited the .env file before first start, so directly pulled the fat image. Set up my standard Modules, everything up and running - except MMM-FRITZ-BoxCallmonitor - and started to test mounts to map the fritzconnection Python scripts… as again, a strange container showed up:
                                  pi@magicmirroros:/opt/mm/run $ docker compose up -d
                                  [+] up 2/2
                                   ✘ Container b053acabeef9 Error response from daemon: No such container: b053acabeef9f142eb3382656732bee6b75d549c10ec2ef80da27ec2c60946d6                                          2.2s
                                   ✔ Container labwc        Recreated        2.2s
                                  Now I am sure my trusty SDcard is corrupt. Thanks @karsten13 for all the troubleshooting and help! I have learned a lot around Docker last days.
                                  Will get a new card and see some time. Other projects requiring my attention.
                                    MiPraSo @rkorell
                                    @rkorell
                                    Thank you for the adjustment. Now the pop-up window no longer freezes when calls are blocked. The installation worked as described here.
                                    Regards,
                                    Michael
                                      rkorell Module Developer @MiPraSo
                                      @MiPraSo cool! thanks for this confirmation.
                                      Glad to hear it works for you!
                                      Regards,
                                      Ralf
                                      • 4 / 4
