    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 22.8k Views 8 Watching
      Mathes75 @karsten13
      @karsten13 to get this right: Using the fat image would have at least python on board. And to get everything to work I would need to add a script, adding the dependencies for MMM-FRITZ-Box-Callmonitor-py3:
      Execute npm install to install the dependencies.
      (Optional) Execute sudo apt-get install python3-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install --break-system-packages fritzconnection to allow access to your FRITZ!Box phone book and recent calls. This can take a few minutes.
      Will definitely give it a try!
        Mathes75 @Mathes75
        Hello @karsten13,
        I have changed the docker image to fat in .env file. Unfortunately, after pulling the docker image, the script stopped with error: No such container: 1b169eacdb711[~35 more numbers/letters].
        Magic Mirror stopped working :( What did I do wrong?
        • karsten13K Offline
          karsten13 @Mathes75
          @Mathes75
          which script?
          show content of “the script” and output of docker compose config
            Mathes75 @karsten13
            @karsten13
            Sorry for being that unspecific. I changed the .env file in the “Docker image to use” section:
            # Docker Images to use:
            MM_IMAGE="karsten13/magicmirror:v2.34.0_fat"
            LABWC_IMAGE="karsten13/labwc:latest"
            MMPM_IMAGE="karsten13/mmpm:latest"
            WATCHTOWER_IMAGE="ghcr.io/nicholas-fedor/watchtower:latest"
            Executed cd /opt/mm/run && docker compose up -d --force-recreate and the download started. After successfully pulling the image, Terminal stopped here:
             ✔ Image karsten13/magicmirror:fat Pulled                                318.2s
               ✔ 304150113e8d                  Pull complete                          97.1s
               ✔ 964f5c44c7bd                  Pull complete                           0.9s
               ✔ ac8996972af0                  Pull complete                           0.9s
               ✔ 3ee9d8e5c8b3                  Pull complete                         131.8s
               ✔ f9b5315e0a0e                  Pull complete                           0.8s
               ✔ 5e7a4985a616                  Pull complete                           0.7s
               ✔ 9f175b8c171e                  Pull complete                          98.7s
               ✔ c1be2df81e57                  Pull complete                           0.7s
               ✔ 4f4fb700ef54                  Pull complete                           0.0s
               ✔ 9dcfcb600955                  Pull complete                           1.0s
               ✔ 0902543587b7                  Pull complete                         212.6s
               ✔ 6454a8f98e11                  Pull complete                         314.9s
               ✔ fe8e38a18048                  Pull complete                          97.6s
               ✔ a4662295f62c                  Pull complete                           0.9s
               ✔ c5dcf86b0f8a                  Pull complete                           1.0s
             ✔ Network magicmirror_default     Created                                 0.4s
             ✘ Container 1b169eacdb71          Error response from daemon: No such container: 1b169eacdb711404e12c838a79de243c677daaaea260867d04c133a86cc3025b 6.8s
            Output of docker compose config:
            services:
              labwc:
                container_name: labwc
                environment:
                  LAB_WC_HIDE_CURSOR: "true"
                  RANDR_PARAMS: ""
                  RANDR_POLL: 1m
                  XDG_RUNTIME_DIR: /tmp/labwc
                image: karsten13/labwc:latest
                networks:
                  default: null
                privileged: true
                restart: always
                volumes:
                  - type: bind
                    source: /tmp/labwc
                    target: /tmp/labwc
                    bind: {}
                  - type: bind
                    source: /run/udev
                    target: /run/udev
                    bind: {}
              magicmirror:
                container_name: mm
                depends_on:
                  labwc:
                    condition: service_healthy
                    restart: true
                    required: true
                environment:
                  DISPLAY: unix:0.0
                  ELECTRON_ENABLE_GPU: "0"
                  MM_CUSTOMCSS_FILE: css/custom.css
                  MM_MODULES_DIR: modules
                  MM_OVERRIDE_DEFAULT_MODULES: "true"
                  MM_SCENARIO: electron
                  MM_SHOW_CURSOR: "false"
                  WAYLAND_DISPLAY: wayland-0
                image: karsten13/magicmirror:v2.34.0_fat
                network_mode: host
                privileged: true
                restart: always
                shm_size: "268435456"
                volumes:
                  - type: bind
                    source: /tmp/.X11-unix
                    target: /tmp/.X11-unix
                    bind: {}
                  - type: bind
                    source: /home/pi/.Xauthority
                    target: /home/node/.Xauthority
                    bind: {}
                  - type: bind
                    source: /tmp/labwc
                    target: /tmp/labwc
                    bind: {}
                  - type: bind
                    source: /opt/mm/mounts/config
                    target: /opt/magic_mirror/config
                    bind: {}
                  - type: bind
                    source: /opt/mm/mounts/modules
                    target: /opt/magic_mirror/modules
                    bind: {}
                  - type: bind
                    source: /opt/mm/mounts/css/custom.css
                    target: /opt/magic_mirror/css/custom.css
                    bind: {}
                post_start:
                  - command:
                      - /bin/sh
                      - -c
                        if [ "init" = "init" ]; then
                          # update volume permissions
                          chown -R 1000:1000 config modules css/custom.css
                          chmod -R 777 config modules css/custom.css
                        fi
                        if command -v node_modules/.bin/electron > /dev/null; then
                          # if electron is installed then start dbus-daemon to avoid errors in the logs
                          dbus-daemon --system || true
                        fi
                    user: root
            networks:
              default:
              karsten13 @Mathes75
              @Mathes75
              looks like there is an old container but no idea why docker is unable to remove it.
              You can try
              cd /opt/mm/run
              docker compose down
              docker rm -f $(docker ps -aq)
                Mathes75 @karsten13
                @karsten13
                Doesn´t look good. I’m too noob about Docker to really understand what’s going on:
                pi@magicmirrorMB:~ $ cd /opt/mm/run/
                pi@magicmirrorMB:/opt/mm/run $ docker compose down
                [+] down 1/1
                 ✔ Container 1b169eacdb71 Removed                                          0.0s
                pi@magicmirrorMB:/opt/mm/run $ docker rm -f $(docker ps -aq)
                pi@magicmirrorMB:/opt/mm/run $ docker compose up -d
                WARN[0000] No services to build
                [+] up 2/2
                 ✔ Network magicmirror_default Created                                     0.2s
                 ✔ Container mm                Created                                     0.9s
                After last line just nothing happens. No prompt, no display on mirror.
                Can I check where the strange container is called or where the reference is?
                  karsten13 @Mathes75
                  @Mathes75
                  show docker ps -a.
                  From the logs it looks like the strange container was deleted but I see no labwc container.
                    Mathes75 @karsten13
                    @karsten13
                    pi@magicmirrorMB:/opt/mm/run $ docker ps -a
                    CONTAINER ID   IMAGE                    COMMAND            CREATED      STATUS                    PORTS     NAMES
                    1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   8 days ago   Exited (128) 2 days ago
                    What? There must be something completely wrong…
                      Mathes75 @karsten13
                      @karsten13
                      Is there a way to reload the images from scratch, delete them from the RPi without losing the customization?
                        karsten13 @Mathes75
                        @Mathes75
                        really strange, the 1b1... is still there …
                        try docker system prune -f and check after this again docker ps -a
                          Mathes75 @karsten13
                          @karsten13
                          After docker compose down, prune resulted in Total reclaimed space: 0B .
                          When trying to start the containers and running the commands:
                          [+] up 2/2
                           ✔ Container mm                Created        0.5s
                          pi@magicmirrorMB:/opt/mm/run $ docker system prune -f
                          Deleted Containers:
                          b04e79ead19ae7e42b7c7899f8e9b4b2d4f870770362c684bfadbfdaae6725aa
                          Deleted Networks:
                          magicmirror_default
                          Total reclaimed space: 4.096kB
                          1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   9 days ago   Exited (128) 2 days ago
                          I think the easiest way is to start from scratch. Save the config.js, remember the modules and just reinstall. Switch to fat image again and fiddle around with FRITZ stuff. Sorry for keeping you busy and thanks a lot for your help and patience!
                          Let me know if you want to finish troubleshooting ;-)
                            karsten13 @Mathes75
                            @Mathes75
                            one thing (if not already done) would be a reboot and then again the prune command.
                            Otherwise start from scratch …
                              Mathes75 @karsten13
                              @karsten13
                              To make it short - same. Will start from scratch and let you know.
                                Mathes75 @Mathes75
                                Short and final update on this - I give up.
                                Reimaged the card, edited the .env file before first start, so directly pulled the fat image. Set up my standard Modules, everything up and running - except MMM-FRITZ-BoxCallmonitor - and started to test mounts to map the fritzconnection Python scripts… as again, a strange container showed up:
                                pi@magicmirroros:/opt/mm/run $ docker compose up -d
                                [+] up 2/2
                                 ✘ Container b053acabeef9 Error response from daemon: No such container: b053acabeef9f142eb3382656732bee6b75d549c10ec2ef80da27ec2c60946d6                                          2.2s
                                 ✔ Container labwc        Recreated        2.2s
                                Now I am sure my trusty SDcard is corrupt. Thanks @karsten13 for all the troubleshooting and help! I have learned a lot around Docker last days.
                                Will get a new card and see some time. Other projects requiring my attention.
                                  MiPraSo @rkorell
                                  @rkorell
                                  Thank you for the adjustment. Now the pop-up window no longer freezes when calls are blocked. The installation worked as described here.
                                  Regards,
                                  Michael
                                    rkorell Module Developer @MiPraSo
                                    @MiPraSo cool! thanks for this confirmation.
                                    Glad to hear it works for you!
                                    Regards,
                                    Ralf
                                    • 4 / 4
