    Calendar CustomEvents
    19 Posts 3 Posters 1.3k Views 3 Watching
      daportelli
      I am trying to update the text in the customEvents section of the default calendar using a transform, but I am unable to make it work. Any thoughts on what I am doing wrong?
      {keyword: 'Canterbury-Bankstown Bulldogs', transform: { search: 'Canterbury-Bankstown Bulldogs', replace: 'Bulldogs'},
      {keyword: 'Spotify', transform: { search: 'Spotify', replace: 'Music'}},
      David
        sdetweil @daportelli
        @daportelli Ah, you are using MMM-GoogleCalendar
        which doesn’t support the text replacement
        I am talking about the default module:‘calendar’
          @daportelli can you show me the calendar module config, xxx out any cal urls
            daportelli @sdetweil
            Here is the full module config, everything else works. I cannot figure this out. Thanks for the assist.
            			module: 'MMM-GoogleCalendar',
            			header: "David's Calendar",
            			classes: "clalendar-full",
            			disabled: false,
            				colored: true,
            				maximumNumberOfDays: 10,
            				maximumEntries: 30,
            				maxTitleLength: 35,
            				displayRepeatingCountTitle: true,
            				defaultRepeatingCountTitle: "",
            				getRelative: 12,
            				fade: false,
            				fadePoint: 0.00,
            			customEvents: [
            						{keyword: 'Spotify', transform: { search: '(?i)Spotify\\s*$', replace: 'Music'}},
            						{keyword: 'Photo', symbol: 'camera', color: 'Silver'},
            						{keyword: 'Benji', symbol: 'paw', color: 'LightGoldenrodYellow'},
            						{keyword: 'Doctor', symbol: 'staff-snake', color: '#0048ba'},
            						{keyword: 'Dr ', symbol: 'staff-snake', color: '##58B1CD'},
            						{keyword: 'Dentist', symbol: 'tooth'},
            						{keyword: 'Orthodontist', symbol: 'teeth'},
            						{keyword: 'Party', symbol: 'gift'},
            						{keyword: 'Christmas', symbol: 'sleigh'},
            						{keyword: 'BMC', symbol: 'staff-snake', color: '##58B1CD'},
            						{keyword: 'Anzac Day', symbol: 'monument'},
            						{keyword: 'Big w', symbol: 'building'},
            						{keyword: 'Recycling', symbol: 'recycle'},
            						{keyword: 'Rubbish', symbol: 'trash-can'},
            						{keyword: 'tennis', symbol:'table-tennis-paddle-ball', color:'#ff7518'}  // Pumkin
            							symbol: "calendar", //Main Calendar
            							color: "#89cff0",  //Baby Blue
            							calendarID: "XXXXXXX@gmail.com"
            							symbol: "calendar-week", //bills
            							color: "#e95c4b",  //Fire Opal
            							calendarID: "XXXXXXX@group.calendar.google.com"
            							symbol: "birthday-cake",
            							color: "#87a96b",  //Asparagus
            							calendarID: ""
            							symbol: "briefcase",	//work
            							color: "#7fffd4",  //Aquamarine
            							symbol: "football",   //NRL
            							color: "#458b74",  //Aquamarine4
            							symbol: "calendar",  //Public Holidays
            							color: "#f767d8",  //pink
            							calendarID: "en-gb.australian#holiday@group.v.calendar.google.com"
            							// add another calendar HERE if needed          // To add more calendars, replicate the above entry within this array with the respective ID
              @daportelli I won’t be able to get to looking at this til late today
              Can you use an online regex tester on you regex and data
              Like
              https://fossa.com/resources/devops-tools/regex-tester/
                @daportelli said:
                (?i)Spotify\s*$
                this didn’t work for my tests, find any title with the word Spotify in it, and change it to only Music
                this works (I use https://regex101.com/ to test my regex’s)
                search: '^.*\b(Spotify)\b.*$', replace:'Music'
                on the other… do you know that the space looking thing between is actually presented as a space?
                open the developers window, ctrl-shift-i, go to the sources tab, navigate the left pane
                to the modules/default/calendar, select calendar.js
                put a stop on the line in the listed in this image (click the line number),
                press ctrl-r to refresh the page,
                code will stop there, move the mouse over the word calendarData
                it will popup the box, mouse up to click the list,
                and it will expand, scroll to find the event, and click to expand it to look at the text…
                  Sorry for the delayed response. Work and life got in the way. I went to the regex tester and used the example from the calendar config for customEvents {keyword: ‘in Hamburg’, transform: { search: ’ in Hamburg$’ , replace: ‘’}} and I could not make it work as per the example in the documentation.
                  (https://fossa.com/resources/devops-tools/regex-tester/)
                  I also tried the other checker with a simplier transform.
                  (https://regex101.com/)
                  I am struggling to understand what I am doing wrong.
                  Your help is appreciated.
                  David
                  • evroomE Offline
                    evroom @daportelli
                    The ‘Regular Expression’ is your ‘search’ from the config line, hence ‘in Hamburg$’.
                    The ‘Replacement Pattern’ is your ‘Replace’ from the config line, hence ‘’ (nothing)
                    The ‘Test String’ is what is triggered by your ‘keyword’ so in this case ‘Geburtstag in Hamburg’ will trigger the search and replace.
                    So, fill in:
                    Regular Expression: in Hamburg$
                    Test String: Geburtstag in Hamburg
                    Replacement Pattern: ‘’
                    Then your Match will be ‘in Hamburg’ and your Highlighted will be ‘Geburtstag’ (that what remains white).
                    For testing search & replace on https://regex101.com, you will need to choose Function - Substitution on the left side.
                    Regular Expression: .in.Hamburg$
                    Substitution:
                    This will result in: Geburtstag
                    This will only match on ‘in Hamburg’, so to make it more flexible you will need to make use of so called grouping:
                    Regular Expression: (Geburtstag).+$
                    Substitution: $1
                    MagicMirror version: 2.35.0
                    Test environment:
                    MagicMirror version: 2.36.0-develop
                      daportelli
                      Thanks for explaining this in a language I can understand. I got that to work.
                      In my calendar I have “amex” typed in lower case and I want the transform it to upper “AMEX” to show this works.
                      However when I use the below code on a calendar event that only has an event titled ‘amex’ in lower case does not work.
                      {keyword: 'amex', transform: { search: 'amex', replace: 'AMEX'}},
                      This simple thing is confusing me. I have removed all variables, and it still does not work.
                      Thanks again for everyone help.
                      S evroomE 2 Replies Last reply Reply Quote 0
                        @daportelli I’m not sure of the effect, but the keyword is treated as a regular expression. I don’t know if single quotes make a difference
                        Also don’t know if js regex works the same, from the code
                        • evroomE Offline
                          evroom @daportelli
                          @daportelli
                          The comments in the code are very confusing, but I think I get it now, more or less.
                          Try this:
                          {keyword: '.*', transform: { search: 'Spotify', replace: 'Music'}},
                          {keyword: '.*', transform: { search: 'Canterbury-Bankstown Bulldogs', replace: 'Bulldogs'},
                          The keyword is the event title string you want to change, in format regex.
                          The search is the substring that you want to replace, in format regex
                          The replace is what will be replaced based on your search
                          So in this case, let’s say the event title string is:
                          ‘Spotify play list’
                          Then you search the complete string (.*) for the substring from search and you replace it by the string from replace.
                          Hence, the event title now becomes:
                          ‘Music play list’
                          I hope it is a little bit more clear.
                          Should it not work, then please supply a event title and in short what you want to be replaced.
                          Test environment:
                            sdetweil @evroom
                            @evroom keyword means find this(via regex) in the title, then work rest of customization . ONLY For events that find keyword string
                            .* Means all events
                            • evroomE Offline
                              evroom @sdetweil
                              .* Means all events
                              Yes, it is a double regex, right?
                              First look if this an event title that you would like to change, then search for the string you want to replace.
                              Still do not understand why the examples from the first post do not work, but for that we would need the exact event titles.
                              {keyword: ‘this event’, transform: { search: ‘changed’, replace: ‘modified’}
                              Event title: ‘we want this event to be changed’.
                              New title: ‘we want this event to be modified’.
                              Do you happen to know how to make the keyword case insensitive?
                              string/i or m/string/i do not work.
                              Neither does (?i)
                              which means ‘match the reminder of the pattern with the i modifier.
                              Test environment:
                                sdetweil @evroom
                                @evroom keyword is not insensitive and cannot be set that way.
                                the search can be
                                  @sdetweil to remove as many variables as I can, I have created a reoccuring event called “Spotify” and I want to change it to “Music”
                                  And I have tried the code below with single and double quotes with no success
                                  For something so simple this is driving me crazy.
                                    @daportelli ok, I just setup an event, happening every day
                                    ‘Spotify Event’
                                    added the custom event def you showed
                                                            header: "US Holidays",
        customEvents: [
        { keyword:'.*', transform :{ search:'Spotify', replace:'Music'} }
        symbol: "calendar-check",
        url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                                    and got this result
                                    MM 2.34
                                    I changed the customEvent definition to
                                    { keyword:'event', transform :{ search:'Spotify', replace:'Music'} }
                                    and it produced the same resutlts
                                        @sdetweil well that explains it. I thought the default calendar configs were available to the MMM-GoogleCalendar.
                                        Sorry, i did not make it clearer. Everyone thanks for the assist in getting to the bottom of it.
                                          @daportelli looks like cloned config, but not implemetation
                                            @daportelli if you change the module name for a test, does it work?
                                            What do you get from MMM-GoogleCalendar that the default does not provide?
                                            never mind, it won’t work with the google side config…
                                            as for the purpose of this configuration.
                                            the content is protected by https encryption and no user will see it, its only exposed ON the system where MagicMirror runs, same for both modules.
                                            you can get the secret URL from the calendar.google.com settings,
