    MMM-AtomVisualizer language
    13 Posts 3 Posters 2.3k Views 3 Watching
    • N Offline
      nowayto
      Hello @kristjanesperanto, I saw you are AtomVisualizer module’s developer.
      Kindly, I need to ask where do I have to go to select the language.
      I saw something about “getTranslation” inside MMM-AtomVisualizer.js but I didn’t understand where do I have to act to have an EN translation.
      Thanks in advance, I’m sure I am the problem but I’m not very skilled on these configurations.
      In the config option parameter I don’t see anything about language.
      Thanks again
        sdetweil @nowayto
        @nowayto it should just work if your system is set to English
        If not set to English, then I think the first in the getTranslations list is the default.
        So if you change the order it should work
        KristjanESPERANTOK N 2 Replies Last reply Reply Quote 0
        • KristjanESPERANTOK Offline
          Ah, yes the first is used as the fallback language. It was German, which is not the best choice :-)
          I changed it to English and released a new version.
          @nowayto Please update and check 🙂
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO yeh I think this is a general bug.
            Even if you had a parm, could change the order. It’s called before start.
            even so, I was wrong, this.config points the the proper module config at the time of getTranslations()
            so it could customize the returned language list
            • N Offline
              nowayto @sdetweil
              @sdetweil Ok, in the past I think I set up the system in Italian.
              So I’ll try to switch the order and, eventually, I’ll switch the language. Thanks
              • N Offline
                nowayto @nowayto
                @kristjanesperanto thanks for your answer.
                I solved like @sdetweil said, simply changing the order inside AtomVisualizer config and it worked.
                Usually my rule is to never modify items inside modules folders so I though there was a way to set it from the config.js like other modules but might be I didn’t understand it, that’s why I asked here :)
                It’s a nice module, I like it!
                Thanks again for your support guys.
                • N nowayto has marked this topic as solved on
                  sdetweil @nowayto
                  @nowayto he also uploaded a fix, so you could have used that.
                  to get it do
                  cd ~/MagicMirror/modules/MMM-AtomVisualizer
                  git checkout MMM-AtomVisualizer.js
                  git pull
                  then restart MagicMirror
                  this restores the file to the last local repo version
                  then updates with the new
                  I wasn’t suggesting KEEPING the locally modified, it was only for testing.
                  til a fix… and there is one now
                  • N Offline
                    nowayto @sdetweil
                    @sdetweil Yeah, I will do that, I just wanna say it worked.
                    Another detail, default configuration has this line:
                    elements: [“H”, “He”, “Li”, “C”, “N”, “O”, “Ne”, “Na”, “Fe”, “Cu”, “Ag”, “Xe”],
                    what should I write inside the [] parenthesis to cycle through all the elements?
                    S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                      sdetweil @nowayto
                      @nowayto see
                      https://www.thoughtco.com/element-symbols-list-606530
                      • N Offline
                        nowayto @sdetweil
                        @sdetweil I know the elements abbreviations.
                        I was just thinking if there was a way to “cycle all elements” instead of writing 110/120 elements inside the config
                          sdetweil @nowayto
                          @nowayto @kristjanesperanto will have to answer that.
                            KristjanESPERANTO Module Developer @nowayto
                            I just released version 0.1.5. With this update, all elements are used when the array is empty 🙂
                            • N Offline
                              nowayto @KristjanESPERANTO
                              @KristjanESPERANTO
                              Nice!
                              Thank you
