    Default Calendar Not Loading Events After New MM Update
    31 Posts 7 Posters 800 Views 7 Watching
    • I Offline
      inteeraymee
      Please help!
      I just updated my MM to the new version and right after doing that my calendar would not load any events. Prior to the update it was working fine. Is there anything in the config I need to tweak? Everything else seems to be working fine.
      Thanks in advance!
        sdetweil @inteeraymee
        @inteeraymee can you tell us more?
        Where is your calendar sourced? Google, Apple, caldav,
        How did you update to latest MagicMirror
        How do you start MagicMirror? Pm2, or some other way
        H I 2 Replies Last reply Reply Quote 0
        • H Offline
          HeikoGr @sdetweil
          @sdetweil @inteeraymee
          I have the same issue after updating from MagicMirror 2.34.0 to 2.35.0.
          In my case this is not a general calendar config problem and not an auth/fetch problem either. Some calendars still load fine, others fail right after the update, which pointed me to a parser regression.
          What I found:
          MagicMirror 2.34.0 used node-ical 0.22.1
          MagicMirror 2.35.0 uses node-ical 0.25.6
          The affected calendars are fetched successfully with HTTP 200
          The failure happens during ICS parsing
          These are the two of the log lines I get:
          [ERROR] [calendar] https://<server>/remote.php/dav/calendars/xx1/?export - iCal parsing failed: Cannot parse: 1-01-15T12:00:00Z
          [DEBUG] [calendar] Parsed iCal data from https://<server>/remote.php/dav/calendars/xx2/?export with 130 entries.
          The important detail in the broken ICS files is this VTIMEZONE block:
          BEGIN:VTIMEZONE
          TZID:W. Europe Standard Time
          BEGIN:DAYLIGHT
          DTSTART:00010325T020000
          TZOFFSETFROM:+0100
          TZOFFSETTO:+0200
          RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=3
          END:DAYLIGHT
          BEGIN:STANDARD
          DTSTART:00011028T030000
          TZOFFSETFROM:+0200
          TZOFFSETTO:+0100
          RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=10
          END:STANDARD
          END:VTIMEZONE
          I tested the exact same ICS file with both node-ical versions:
          node-ical 0.22.1: parses successfully
          node-ical 0.25.6: fails with Cannot parse: 1-01-15T12:00:00Z
          I also verified that if I remove only that W. Europe Standard Time VTIMEZONE block from the failing ICS, the file parses again with node-ical 0.25.6.
          So the problem seems to be a regression in node-ical 0.25.x when resolving VTIMEZONE definitions with year 0001 in DTSTART. The calendar fetch itself succeeds; the crash happens while parsing timezone metadata.
          This may especially affect calendars coming from Outlook/Exchange/Nextcloud imports, because W. Europe Standard Time looks like a Microsoft-style timezone definition.
          • H Offline
            HeikoGr
            i filed an issue: https://github.com/jens-maus/node-ical/issues/495
            it could be an edge case on my side.
            @inteeraymee by any chance: did you use emClient anytime in the past?
            only workaround for my setup is to pin to v2.34.0 .
            Updating the calendars might be the best solution for me…
              sdetweil @HeikoGr
              @HeikoGr we originally never parsed the vtimezone sections
              • I Offline
                inteeraymee @sdetweil
                @sdetweil I have about 5 that are sourced in Google and another 2 or so that are subscription-based (i.e. sports teams).
                The way that I am starting MM is via ssh since my monitor is inside a frame up on a wall, making it a challenge to connect directly. The script I use is:
                sudo -u rudin-fam
                DISPLAY=:0
                XAUTHORITY=/home/rudin-fam/.Xauthority
                nohup chromium --kiosk http://localhost:8080
                –noerrdialogs
                –disable-infobars
                –disable-session-crashed-bubble
                –disable-restore-session-state
                >/dev/null 2>&1 &
                  @inteeraymee that’s the display side, where is the server side?
                  • H Offline
                    hrt13 @sdetweil
                    @sdetweil Hi, I am having the same problem since upgrading this morning (MM v2.35)
                    5 calendars, all from Google
                    Platform: Raspberry Pi3 B
                    OS: Debian GNU/Linux 11 (bullseye)
                    I haven’t tried regenerating the calendar links, should I?
                      sdetweil @hrt13
                      @hrt13 shouldn’t need to
                      Are there any errors reported in the console log where you start MagicMirror?
                      If using pm2, then
                      pm2 logs —lines=xxx
                      Xxx is the number of latest lines to display, default 15
                      You might need 100
                      • H Offline
                        hrt13 @sdetweil
                        @sdetweil Using pm2, I see a lot of “could not expand event” errors. Here’s one:
                        " [2026-04-02 12:29:21.274] [ERROR] [calendar] Could not expand event “Hockey vs. C”: ical.expandRecurringEvent is not a function"
                          sdetweil @hrt13
                          @hrt13 awesome to help could you find that event
                          curl -sL the_url_for_calendar >somefile.txt
                          Then edit somefile.txt and search for that title
                          Copy
                          Begin:vevent
                          End:vevent
                          And paste here. In code block
                          Edit Any info that might identify you, just dont delete any lines
                          • H Offline
                            hrt13 @sdetweil
                            I think this is it, it may be in the past (I’ll look for a more current one, I didn’t think I was getting events from the past), also, sorry about the ^M’s:
                            BEGIN:VEVENT
                            DTSTART:20150228T005000Z
                            DTEND:20150228T022000Z
                            DTSTAMP:20260402T201324Z
                            UID:somenumber@google.com
                            CREATED:20150130T132500Z
                            LAST-MODIFIED:20150130T132500Z
                            SEQUENCE:0
                            STATUS:CONFIRMED
                            SUMMARY:Hockey vs. C
                            TRANSP:OPAQUE
                            END:VEVENT
                              sdetweil @hrt13
                              @hrt13 is there one on a repeating schedule?
                              We shouldn’t expand one if it doesn’t have an rrule
                              H 2 Replies Last reply Reply Quote 0
                              • H Offline
                                hrt13 @sdetweil
                                @sdetweil said:
                                There are some recent repeating events though I’m not sure any show in the logs. I’ll see if I can find some new events. Looking at the logs again, it seems it’s retrieving lots of past events which, of course, wouldn’t show on the calendar. The latest I’ve seen so far is an event from Jan 2026.
                                • H Offline
                                  hrt13 @sdetweil
                                  @sdetweil this is definitely a repeating schedule
                                  Log file error:
                                  [2026-04-02 19:59:16.671] [ERROR] [calendar] Could not expand event “Tax Day”: ical.expandRecurringEvent is not a function
                                  curl -sL output
                                  BEGIN:VCALENDAR
                                  PRODID:-//Google Inc//Google Calendar 70.9054//EN
                                  VERSION:2.0
                                  CALSCALE:GREGORIAN
                                  METHOD:PUBLISH
                                  X-WR-CALNAME:Holidays in United States
                                  X-WR-TIMEZONE:UTC
                                  X-WR-CALDESC:Holidays and Observances in United States
                                  BEGIN:VEVENT
                                  DTSTART;VALUE=DATE:20220418
                                  DTEND;VALUE=DATE:20220419
                                  DTSTAMP:20260403T003912Z
                                  UID:20220418_clveaq2fmqp95elk3vma4ifhcs@google.com
                                  CLASS:PUBLIC
                                  CREATED:20240603T101345Z
                                  DESCRIPTION:Observance\nTo hide observances\, go to Google Calendar Setting
                                   s > Holidays in United States
                                  LAST-MODIFIED:20240603T101345Z
                                  SEQUENCE:0
                                  STATUS:CONFIRMED
                                  SUMMARY:Tax Day
                                  TRANSP:TRANSPARENT
                                  END:VEVENT
                                  BEGIN:VEVENT
                                  DTSTART;VALUE=DATE:20260415
                                  DTEND;VALUE=DATE:20260416
                                  UID:20260415_fkehtfbgrr6j65q23flu2k5vu0@google.com
                                  CLASS:PUBLIC
                                  CREATED:20240603T101355Z
                                  LAST-MODIFIED:20240603T101355Z
                                  SEQUENCE:0
                                  STATUS:CONFIRMED
                                  SUMMARY:Tax Day
                                  TRANSP:TRANSPARENT
                                  END:VEVENT
                                  S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                    sdetweil @hrt13
                                    @hrt13 hmm. A repeating event has one vevent, with an rrule line that describes how it repeats
                                    • KristjanESPERANTOK Offline
                                      KristjanESPERANTO Module Developer @hrt13
                                      Looks like you didn’t update the dependencies after you pulled the new MM version.
                                      Please run node --run install-mm and check again.
                                      • H Offline
                                        hrt13 @KristjanESPERANTO
                                        trying it now, it is taking a while. Will let you know.
                                        I used mmpm to update, I guess it doesn’t update the dependencies.
                                          A workaround for users still having issues with the calendar. There was a problem with the node-ical package for some events. This has just been fixed with a new node-ical release (v0.26.0).
                                          To use the new version, run this command in the MagicMirror directory:
                                          npm install node-ical@latest.
                                          Note that this will change your package.json and package-lock.json files, which would cause conflicts during the next MagicMirror update. Therefore, also run the following to restore them:
                                          git restore package*.json
                                          You will then have v0.26.0 installed - the package.json file say otherwise, but that doesn’t matter.
                                          Please give some feedback if that helps :-)
                                            doogy_rev
                                            I have just updated to the latest version and have the same issue of the Calendar not loading.
                                            I have tried the above suggestions but still not able to load gmail calendars
                                            I did use the script to update MM and all dependancies
                                            Any help appreciated
                                            DoogyRev
