    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 17.3k Views 8 Watching
      sdetweil @hrt13
      @hrt13 shouldn’t need to
      Are there any errors reported in the console log where you start MagicMirror?
      If using pm2, then
      pm2 logs —lines=xxx
      Xxx is the number of latest lines to display, default 15
      You might need 100
      • H Offline
        hrt13 @sdetweil
        @sdetweil Using pm2, I see a lot of “could not expand event” errors. Here’s one:
        " [2026-04-02 12:29:21.274] [ERROR] [calendar] Could not expand event “Hockey vs. C”: ical.expandRecurringEvent is not a function"
          sdetweil @hrt13
          @hrt13 awesome to help could you find that event
          curl -sL the_url_for_calendar >somefile.txt
          Then edit somefile.txt and search for that title
          Copy
          Begin:vevent
          End:vevent
          And paste here. In code block
          Edit Any info that might identify you, just dont delete any lines
          • H Offline
            hrt13 @sdetweil
            I think this is it, it may be in the past (I’ll look for a more current one, I didn’t think I was getting events from the past), also, sorry about the ^M’s:
            BEGIN:VEVENT
            DTSTART:20150228T005000Z
            DTEND:20150228T022000Z
            DTSTAMP:20260402T201324Z
            UID:somenumber@google.com
            CREATED:20150130T132500Z
            LAST-MODIFIED:20150130T132500Z
            SEQUENCE:0
            STATUS:CONFIRMED
            SUMMARY:Hockey vs. C
            TRANSP:OPAQUE
            END:VEVENT
              sdetweil @hrt13
              @hrt13 is there one on a repeating schedule?
              We shouldn’t expand one if it doesn’t have an rrule
              H 2 Replies Last reply Reply Quote 0
              • H Offline
                hrt13 @sdetweil
                @sdetweil said:
                There are some recent repeating events though I’m not sure any show in the logs. I’ll see if I can find some new events. Looking at the logs again, it seems it’s retrieving lots of past events which, of course, wouldn’t show on the calendar. The latest I’ve seen so far is an event from Jan 2026.
                • H Offline
                  hrt13 @sdetweil
                  @sdetweil this is definitely a repeating schedule
                  Log file error:
                  [2026-04-02 19:59:16.671] [ERROR] [calendar] Could not expand event “Tax Day”: ical.expandRecurringEvent is not a function
                  curl -sL output
                  BEGIN:VCALENDAR
                  PRODID:-//Google Inc//Google Calendar 70.9054//EN
                  VERSION:2.0
                  CALSCALE:GREGORIAN
                  METHOD:PUBLISH
                  X-WR-CALNAME:Holidays in United States
                  X-WR-TIMEZONE:UTC
                  X-WR-CALDESC:Holidays and Observances in United States
                  BEGIN:VEVENT
                  DTSTART;VALUE=DATE:20220418
                  DTEND;VALUE=DATE:20220419
                  DTSTAMP:20260403T003912Z
                  UID:20220418_clveaq2fmqp95elk3vma4ifhcs@google.com
                  CLASS:PUBLIC
                  CREATED:20240603T101345Z
                  DESCRIPTION:Observance\nTo hide observances\, go to Google Calendar Setting
                   s > Holidays in United States
                  LAST-MODIFIED:20240603T101345Z
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:Tax Day
                  TRANSP:TRANSPARENT
                  END:VEVENT
                  BEGIN:VEVENT
                  DTSTART;VALUE=DATE:20260415
                  DTEND;VALUE=DATE:20260416
                  UID:20260415_fkehtfbgrr6j65q23flu2k5vu0@google.com
                  CLASS:PUBLIC
                  CREATED:20240603T101355Z
                  LAST-MODIFIED:20240603T101355Z
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:Tax Day
                  TRANSP:TRANSPARENT
                  END:VEVENT
                  S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                    sdetweil @hrt13
                    @hrt13 hmm. A repeating event has one vevent, with an rrule line that describes how it repeats
                    • KristjanESPERANTOK Offline
                      KristjanESPERANTO Module Developer @hrt13
                      Looks like you didn’t update the dependencies after you pulled the new MM version.
                      Please run node --run install-mm and check again.
                      • H Offline
                        hrt13 @KristjanESPERANTO
                        trying it now, it is taking a while. Will let you know.
                        I used mmpm to update, I guess it doesn’t update the dependencies.
                          A workaround for users still having issues with the calendar. There was a problem with the node-ical package for some events. This has just been fixed with a new node-ical release (v0.26.0).
                          To use the new version, run this command in the MagicMirror directory:
                          npm install node-ical@latest.
                          Note that this will change your package.json and package-lock.json files, which would cause conflicts during the next MagicMirror update. Therefore, also run the following to restore them:
                          git restore package*.json
                          You will then have v0.26.0 installed - the package.json file say otherwise, but that doesn’t matter.
                          Please give some feedback if that helps :-)
                            doogy_rev
                            I have just updated to the latest version and have the same issue of the Calendar not loading.
                            I have tried the above suggestions but still not able to load gmail calendars
                            I did use the script to update MM and all dependancies
                            Any help appreciated
                            DoogyRev
                              sdetweil @doogy_rev
                              @doogy_rev can you show me the ~/MagicMirror/installers/upgrade.log
                              Maybe send it to me
                              Same userid at gmail
                              It is two part process, right?
                                doogy_rev
                                Hi Sam,
                                Log sent to your gmail
                                DoogyRev
                                  sdetweil @doogy_rev
                                  @doogy_rev it looks like you tried it manually, git pull, and the latest code was already present
                                  local version 2.35.0 already same as master 2.35.0
                                  The upgrade by default will not upgrade over the existing version
                                  To fix, rerun and change the parm from apply to force
                                    doogy_rev @sdetweil
                                    ok, so I know enough to be dangerous, what is the command I should be committing?
                                      sdetweil @doogy_rev
                                      @doogy_rev if you copy paste the second upgrade command from my script GitHub repo, you will see the word
                                      apply
                                      At the end
                                      Change that to
                                      force
                                      And hit enter
                                        doogy_rev
                                        @sdetweil That worked, thanks very much.
                                          sdetweil @doogy_rev
                                          @doogy_rev awesome… thanks for the feedback
                                            Athlon @sdetweil
                                            My calendar also stopped showing events (from my Google calendar).
                                            Running
                                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                            fixed it for me. It worked like ‘Magic’ - pun intended.
                                            Thank you!!
                                            • 1 / 4
