    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 15.4k Views 8 Watching
    • I Offline
      inteeraymee @sdetweil
      @sdetweil I have about 5 that are sourced in Google and another 2 or so that are subscription-based (i.e. sports teams).
      The way that I am starting MM is via ssh since my monitor is inside a frame up on a wall, making it a challenge to connect directly. The script I use is:
      sudo -u rudin-fam
      DISPLAY=:0
      XAUTHORITY=/home/rudin-fam/.Xauthority
      nohup chromium --kiosk http://localhost:8080
      –noerrdialogs
      –disable-infobars
      –disable-session-crashed-bubble
      –disable-restore-session-state
      >/dev/null 2>&1 &
        sdetweil @inteeraymee
        @inteeraymee that’s the display side, where is the server side?
        • H Offline
          hrt13 @sdetweil
          @sdetweil Hi, I am having the same problem since upgrading this morning (MM v2.35)
          5 calendars, all from Google
          Platform: Raspberry Pi3 B
          OS: Debian GNU/Linux 11 (bullseye)
          I haven’t tried regenerating the calendar links, should I?
            sdetweil @hrt13
            @hrt13 shouldn’t need to
            Are there any errors reported in the console log where you start MagicMirror?
            If using pm2, then
            pm2 logs —lines=xxx
            Xxx is the number of latest lines to display, default 15
            You might need 100
            • H Offline
              hrt13 @sdetweil
              @sdetweil Using pm2, I see a lot of “could not expand event” errors. Here’s one:
              " [2026-04-02 12:29:21.274] [ERROR] [calendar] Could not expand event “Hockey vs. C”: ical.expandRecurringEvent is not a function"
                sdetweil @hrt13
                @hrt13 awesome to help could you find that event
                curl -sL the_url_for_calendar >somefile.txt
                Then edit somefile.txt and search for that title
                Copy
                Begin:vevent
                End:vevent
                And paste here. In code block
                Edit Any info that might identify you, just dont delete any lines
                • H Offline
                  hrt13 @sdetweil
                  I think this is it, it may be in the past (I’ll look for a more current one, I didn’t think I was getting events from the past), also, sorry about the ^M’s:
                  BEGIN:VEVENT
                  DTSTART:20150228T005000Z
                  DTEND:20150228T022000Z
                  DTSTAMP:20260402T201324Z
                  UID:somenumber@google.com
                  CREATED:20150130T132500Z
                  LAST-MODIFIED:20150130T132500Z
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:Hockey vs. C
                  TRANSP:OPAQUE
                  END:VEVENT
                    sdetweil @hrt13
                    @hrt13 is there one on a repeating schedule?
                    We shouldn’t expand one if it doesn’t have an rrule
                    H 2 Replies Last reply Reply Quote 0
                    • H Offline
                      hrt13 @sdetweil
                      @sdetweil said:
                      There are some recent repeating events though I’m not sure any show in the logs. I’ll see if I can find some new events. Looking at the logs again, it seems it’s retrieving lots of past events which, of course, wouldn’t show on the calendar. The latest I’ve seen so far is an event from Jan 2026.
                      • H Offline
                        hrt13 @sdetweil
                        @sdetweil this is definitely a repeating schedule
                        Log file error:
                        [2026-04-02 19:59:16.671] [ERROR] [calendar] Could not expand event “Tax Day”: ical.expandRecurringEvent is not a function
                        curl -sL output
                        BEGIN:VCALENDAR
                        PRODID:-//Google Inc//Google Calendar 70.9054//EN
                        VERSION:2.0
                        CALSCALE:GREGORIAN
                        METHOD:PUBLISH
                        X-WR-CALNAME:Holidays in United States
                        X-WR-TIMEZONE:UTC
                        X-WR-CALDESC:Holidays and Observances in United States
                        BEGIN:VEVENT
                        DTSTART;VALUE=DATE:20220418
                        DTEND;VALUE=DATE:20220419
                        DTSTAMP:20260403T003912Z
                        UID:20220418_clveaq2fmqp95elk3vma4ifhcs@google.com
                        CLASS:PUBLIC
                        CREATED:20240603T101345Z
                        DESCRIPTION:Observance\nTo hide observances\, go to Google Calendar Setting
                         s > Holidays in United States
                        LAST-MODIFIED:20240603T101345Z
                        SEQUENCE:0
                        STATUS:CONFIRMED
                        SUMMARY:Tax Day
                        TRANSP:TRANSPARENT
                        END:VEVENT
                        BEGIN:VEVENT
                        DTSTART;VALUE=DATE:20260415
                        DTEND;VALUE=DATE:20260416
                        UID:20260415_fkehtfbgrr6j65q23flu2k5vu0@google.com
                        CLASS:PUBLIC
                        CREATED:20240603T101355Z
                        LAST-MODIFIED:20240603T101355Z
                        SEQUENCE:0
                        STATUS:CONFIRMED
                        SUMMARY:Tax Day
                        TRANSP:TRANSPARENT
                        END:VEVENT
                        S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                          sdetweil @hrt13
                          @hrt13 hmm. A repeating event has one vevent, with an rrule line that describes how it repeats
                          • KristjanESPERANTOK Offline
                            KristjanESPERANTO Module Developer @hrt13
                            Looks like you didn’t update the dependencies after you pulled the new MM version.
                            Please run node --run install-mm and check again.
                            • H Offline
                              hrt13 @KristjanESPERANTO
                              trying it now, it is taking a while. Will let you know.
                              I used mmpm to update, I guess it doesn’t update the dependencies.
                                A workaround for users still having issues with the calendar. There was a problem with the node-ical package for some events. This has just been fixed with a new node-ical release (v0.26.0).
                                To use the new version, run this command in the MagicMirror directory:
                                npm install node-ical@latest.
                                Note that this will change your package.json and package-lock.json files, which would cause conflicts during the next MagicMirror update. Therefore, also run the following to restore them:
                                git restore package*.json
                                You will then have v0.26.0 installed - the package.json file say otherwise, but that doesn’t matter.
                                Please give some feedback if that helps :-)
                                  doogy_rev
                                  I have just updated to the latest version and have the same issue of the Calendar not loading.
                                  I have tried the above suggestions but still not able to load gmail calendars
                                  I did use the script to update MM and all dependancies
                                  Any help appreciated
                                  DoogyRev
                                    sdetweil @doogy_rev
                                    @doogy_rev can you show me the ~/MagicMirror/installers/upgrade.log
                                    Maybe send it to me
                                    Same userid at gmail
                                    It is two part process, right?
                                      doogy_rev
                                      Hi Sam,
                                      Log sent to your gmail
                                      DoogyRev
                                        sdetweil @doogy_rev
                                        @doogy_rev it looks like you tried it manually, git pull, and the latest code was already present
                                        local version 2.35.0 already same as master 2.35.0
                                        The upgrade by default will not upgrade over the existing version
                                        To fix, rerun and change the parm from apply to force
                                          doogy_rev @sdetweil
                                          ok, so I know enough to be dangerous, what is the command I should be committing?
                                            sdetweil @doogy_rev
                                            @doogy_rev if you copy paste the second upgrade command from my script GitHub repo, you will see the word
                                            apply
                                            At the end
                                            Change that to
                                            force
                                            And hit enter
                                            • 1 / 4
