    Simple Music Player Module
    musicaudioplayer
    41 Posts 19 Posters 55.4k Views 21 Watching
    • K Offline
      KirAsh4 Moderator
      For troubleshooting or HOWTO questions, please post in the Troubleshooting thread:
      https://forum.magicmirror.builders/topic/215/simple-music-player-module/1
      • G Offline
        glelan @EoF
        @EoF Work nice !! thanks. Could you update the module with M3U playlist and automatic start or keyboard short cut ? I plan to use to for webradio in bathroom ;-)
        Thanks !
          [[global:former-user]] @EoF
          @EoF said in Simple Music Player Module:
          Just for an update on this, I haven’t pushed this to git yet but the new module will now have a playlist where you can scroll through and choose which song to play.
          mm-music-player-update
          I’m also looking to make the volume scroll ball bigger, so it’s easier to grab. If you saw my demonstration video you can see I had a little bit of trouble grabbing it. Still working on this one though, as I want the size of the ball to remain the same visually but the actual to be larger. Unfortunately though, margin doesn’t seem to detect the dragging event.
          Hi not seeing this myself, (the list)
          • cowboysdudeC Offline
            cowboysdude Module Developer @Guest
            @wjdw87 said in Simple Music Player Module:
            Well that’s because the original doesn’t have it yet… he has updated but not made it available via ‘git pull’ yet :) He’s still tweaking it I believe but I’m sure it’ll be ready soon!
            • F Offline
              frodrd00
              I use the module voicecontrol.
              How can I change the following to raise the volume?
              if (notification === “VOLUME_UP”){
              if (notification === “VOLUME_DOWN”){
                AlessandroRa
                Hey @EoF thank you for this module! How is it going with the update?
                By the way, I’ve found that when I try to change the volume, it goes random up and down
                (for example: I click on the left and the volume goes up, then I click on the center and the volume goes down, then I click on the right and the volume goes up again…) any suggestion? Thanks!
                  codecook
                  Thanks for the great module. One problem I have is it plays for few seconds and stops automatically. Is there a reason? Please let me know.
                  Below is the code for the player from config
                                          module: 'mm-music-player',
                                          position: 'bottom_left',
                                                   startingVolume: 35,
                                                   fadeDuriation: 2000
                  • 1 Offline
                    1m2
                    Great work EoF.
                    Just came over from the YouTube channel to check out your shared knowledge. Pretty awesome stuff man! Thanks for sharing with us, I have not implemented this yet as I’m still working on other kinks in my MM2.
                    I wonder if any one has found a way to tie into Google Play Music since I have all my music on there already?
                    Cheers!
                    *** Hey EoF or anyone that’s possibly reading this, can anyone help with how to/where to load the “MM-Hide-All” files that EoF created to hide all text and make it reappear? All I was able to do was put the “module” text into the config.js and that’s it. LOL
                    Noob status…
                    • Y Offline
                      yawns Moderator
                      Are you talking about this one? https://github.com/masters1222/mm-hide-all
                      open a terminal:
                      cd ~/MagicMirror/modules
                      git clone https://github.com/masters1222/mm-hide-all.git
                      1 1 Reply Last reply Reply Quote 1
                      • 1 Offline
                        1m2 @yawns
                        @yawns
                        Dude, thanks a Mill!
                        So for this music one it would be
                        cd to my MagicMirror/modules directory and execute the below as well.
                        git clone https://github.com/masters1222/mm-music-player
                        Wow, doesn’t get easier than that! LOL
                        Thanks for the quick response man!
                        *** Did an EDIT correction on the which directory to CD to since @cowboysdude was nice enough to point that out, given that I didn’t pay attention. I didn’t want anyone else to find this later and have the same mistake happen to them because of me. LOL
                          cowboysdude Module Developer @1m2
                          @1m2 Don’t forget… it’s not the MagicMirror dir it’s the /MagicMirror/modules dir before you do a git clone or you’ll be putting it directly in the MM folder instead of the modules folder ;)
                          1 1 Reply Last reply Reply Quote 0
                          • 1 Offline
                            1m2 @cowboysdude
                            @cowboysdude
                            Funk it… I was already troubleshooting cause I had already did it! LOL!!!
                            Now I have to look up how to remove them, I haven’t done linux in 10 years.
                            That’s what happens when you get too excited and don’t pay attention. DOH.
                            Thanks!
                              @1m2 said in Simple Music Player Module:
                              @cowboysdude
                              Thanks!
                              Just open up a folder and delete it :)
                              OR from terminal window:
                              sudo rm -rf folderName
                              • T Offline
                                theusu5k
                                i really like this module,it can’t be done a web version,to control the music player from a web page?
                                cowboysdudeC 1 2 Replies Last reply Reply Quote 0
                                  cowboysdude Module Developer @theusu5k
                                  @theusu5k That gets a lot more difficult…
                                  You have to find an api that allows it…
                                    broberg Project Sponsor @cowboysdude
                                    @cowboysdude well, he should be able to send http get to the syslog module and then let the syslog send a notification to the player module.
                                    But, well, it’s a long way around 😀
                                    • 1 Offline
                                      1m2 @theusu5k
                                      @theusu5k Yeah, Google Music would be a bomb widget on here.
                                      • L Offline
                                        lucallmon
                                        Is there a way to link the music directory to a thumb drive instead of having it in the modules folder on the SD card?
                                          broberg Project Sponsor @lucallmon
                                          @lucallmon either you change the directory in the players .js file or you link the music folder to the thumbdrive
                                            dbaler
                                            If you have a nas / networked storage and want to use music files from there, how would you do that?
