    Simple Music Player Module
    musicaudioplayer
    41 Posts 19 Posters 52.4k Views 21 Watching
    • EoFE Offline
      EoF
      MM Music Player
      First module, first time using node, go easy on me ;)
      I made this for the original MagicMirror that used the standard xampp stack, so this was originally made using PHP for the back end part of it. I basically ported this over to MagicMirror2 from there.
      [card:masters1222/mm-music-player]
      Basically, this is a simple music player. Add your music (must be .mp3) to the music directory in the module and it will automatically detect them. No need to manage a list of file names or anything like that. After that, simply click play.
      Note: You do need to be able to click the buttons, otherwise the music won’t start. I may apply an option to the config to auto play on launch if anyone is interested. I have made it this way as I am working on a MagicMirror that I plan to make touch screen (well, try it).
      • EoFE Offline
        EoF
        Just for an update on this, I haven’t pushed this to git yet but the new module will now have a playlist where you can scroll through and choose which song to play.
        mm-music-player-update
        I’m also looking to make the volume scroll ball bigger, so it’s easier to grab. If you saw my demonstration video you can see I had a little bit of trouble grabbing it. Still working on this one though, as I want the size of the ball to remain the same visually but the actual to be larger. Unfortunately though, margin doesn’t seem to detect the dragging event.
        G ? 2 Replies Last reply Reply Quote 1
        • KirAsh4K Offline
          KirAsh4 Moderator
          For troubleshooting or HOWTO questions, please post in the Troubleshooting thread:
          https://forum.magicmirror.builders/topic/215/simple-music-player-module/1
          • G Offline
            glelan @EoF
            @EoF Work nice !! thanks. Could you update the module with M3U playlist and automatic start or keyboard short cut ? I plan to use to for webradio in bathroom ;-)
            Thanks !
              A Former User @EoF
              @EoF said in Simple Music Player Module:
              Hi not seeing this myself, (the list)
              • cowboysdudeC Offline
                cowboysdude Module Developer @Guest
                @wjdw87 said in Simple Music Player Module:
                Well that’s because the original doesn’t have it yet… he has updated but not made it available via ‘git pull’ yet :) He’s still tweaking it I believe but I’m sure it’ll be ready soon!
                • F Offline
                  frodrd00
                  I use the module voicecontrol.
                  How can I change the following to raise the volume?
                  if (notification === “VOLUME_UP”){
                  if (notification === “VOLUME_DOWN”){
                  • AlessandroRaA Offline
                    AlessandroRa
                    Hey @EoF thank you for this module! How is it going with the update?
                    By the way, I’ve found that when I try to change the volume, it goes random up and down
                    (for example: I click on the left and the volume goes up, then I click on the center and the volume goes down, then I click on the right and the volume goes up again…) any suggestion? Thanks!
                      codecook
                      Thanks for the great module. One problem I have is it plays for few seconds and stops automatically. Is there a reason? Please let me know.
                      Below is the code for the player from config
                                              module: 'mm-music-player',
                                              position: 'bottom_left',
                                                       startingVolume: 35,
                                                       fadeDuriation: 2000
                      • 1m21 Offline
                        1m2
                        Great work EoF.
                        Just came over from the YouTube channel to check out your shared knowledge. Pretty awesome stuff man! Thanks for sharing with us, I have not implemented this yet as I’m still working on other kinks in my MM2.
                        I wonder if any one has found a way to tie into Google Play Music since I have all my music on there already?
                        Cheers!
                        *** Hey EoF or anyone that’s possibly reading this, can anyone help with how to/where to load the “MM-Hide-All” files that EoF created to hide all text and make it reappear? All I was able to do was put the “module” text into the config.js and that’s it. LOL
                        Noob status…
                        • 1 / 5
