    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.2k Views 2 Watching
      sdetweil @1a2a3a
      @1a2a3a your Linux/pi system uses a window manager to display the app session window on the screen
      In the past it was just x11 (xwindows)
      In the last couple years a new thing has appeared , Wayland
      We need two different commands to tell which wm is active
      If you look in the terminal window where you did the command above, you will see the debug output that will identify the module
      Here is mine for punycode
      [2026-04-08 19:03:13.384] [INFO]  [helpers] [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_20_MMM-HomeAssistantDisplay' ]
      [2026-04-08 19:03:13.391] [ERROR] [unknown] (node:936571) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
          at node:punycode:7:10
      So MMM-HomeAssistantDisplay is the module that is causing the message
      1 1 Reply Last reply
        sdetweil @1a2a3a
        @1a2a3a no, if it works w npm start, leave it alone
          1a2a3a @sdetweil
          @sdetweil it didnt show any module error.
          [2026-05-01 23:53:38.898] [LOG]   [app] All module helpers loaded.
          [2026-05-01 23:53:38.901] [LOG]   [server] Starting server on port 8080 ...
          [2026-05-01 23:53:38.911] [ERROR] [unknown] (node:1979206) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
          (Use `electron --trace-deprecation ...` to show where the warning was created)
          [2026-05-01 23:53:39.001] [LOG]   [app] Server started ...
            1a2a3a @sdetweil
            @sdetweil my pm2 is currently not working at the moment.
            i then tried to pm2 start and ran into this error. Ok not exactly error, but the mirror just keep going to blackscreen and nothing then back to wall paper then blackscreen and keep looping this.
            (node:1971942) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
            (Use `node --trace-deprecation ...` to show where the warning was created)
              sdetweil @1a2a3a
              @1a2a3a you did this right?
              NODE_OPTIONS=--trace-deprecation npm run start:xxx
              Replace xxx with x11, the whole line
              On your system
              That’s 2. — in front of of trace-deprecation
              1 2 Replies Last reply
                1a2a3a @sdetweil
                @sdetweil yes correct
                NODE_OPTIONS=–trace-deprecation npm run start:x11
                i also manually git pull all the modules and all are up to dates as well.
                  1a2a3a @sdetweil
                  @sdetweil how do i fix my pm2 issue?
                    sdetweil @1a2a3a
                    @1a2a3a need 2 dashes in front of trace
                      sdetweil @1a2a3a
                      @1a2a3a change the npm start to npm run start:x11
                      If you had used my upgrade script it would have fixed that
                        1a2a3a @sdetweil
                        @sdetweil i did use your upgrade script.
                        do you mean change it inside mm.sh?
                        currently its
                        #!/bin/bash
                        # This file is still here to keep PM2 working on older installations.
                        DISPLAY=:0 npm start
                        change it to
                        #!/bin/bash
                        DISPLAY=:0 npm run start:x11
                        correct?
                          sdetweil @1a2a3a
                          @1a2a3a correct…
                          in version 2.35 we documented that we changed the default to
                          npm run start:wayland
                          for npm start
                          see package,json, scripts: section for the command options
                            1a2a3a @sdetweil
                            @sdetweil same thing
                            NODE_OPTIONS=--trace-deprecation npm run start:x11
                            [2026-05-02 00:31:24.574] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                            [2026-05-02 00:31:24.574] [LOG]   [app] All module helpers loaded.
                            [2026-05-02 00:31:24.592] [LOG]   [server] Starting server on port 8080 ...
                            [2026-05-02 00:31:24.602] [ERROR] [unknown] (node:1985687) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                at BuiltinModule.compileForInternalLoader (node:internal/bootstrap/realm:398:7)
                                at BuiltinModule.compileForPublicLoader (node:internal/bootstrap/realm:337:10)
                                at loadBuiltinModule (node:internal/modules/helpers:126:7)
                                at loadBuiltinWithHooks (node:internal/modules/cjs/loader:1229:15)
                                at Module._load (node:internal/modules/cjs/loader:1320:48)
                                at c._load (node:electron/js2c/node_init:2:18060)
                                at wrapModuleLoad (node:internal/modules/cjs/loader:262:19)
                                at Module.require (node:internal/modules/cjs/loader:1583:12)
                                at require (node:internal/modules/helpers:153:16)
                            [2026-05-02 00:31:24.702] [LOG]   [app] Server started ...
                            [2026-05-02 00:31:24.703] [LOG]   [node_helper] Connectin```
                            code_text
                              1a2a3a @sdetweil
                              @sdetweil i have change my mm.sh to
                              #!/bin/bash
                              but when i do pm2 start MagicMirror, it doesnt start still.
                                sdetweil @1a2a3a
                                @1a2a3a SO much fun
                                do this and give me the output
                                grep "module:" ~/MagicMirror/config/config.js | sort | uniq
                                and I’ll look thru them
                                  1a2a3a @sdetweil
                                  @sdetweil here you go
                                  [hsa@HSA:~ $ grep "module:" ~/MagicMirror/config/config.js
                                                          module: "alert",
                                                          module: "updatenotification",
                                                          module: "clock",
                                          module: "MMM-Jast",
                                    module: 'MMM-GoogleDocs-Notes',
                                                          module: "newsfeed",
                                                  module: "MMM-NewsAPI",
                                    module: "MMM-MyScoreboard",
                                    module: "MMM-SoccerLiveScore",
                                  //  module: "MMM-GooglePhotos",
                                  // module: "MMM-ImagesPhotos",
                                  //   module: "MMM-Wallpaper",
                                  //    module: 'MMM-BackgroundSlideshow',
                                    module: "MMM-OneDrive",
                                    module: "MMM-CalendarExt3Agenda",
                                                           module: "MMM-CalendarExt3",
                                                          module: "calendar",](link url)
                                    sdetweil @1a2a3a
                                    @1a2a3a ok, I didn’t find it the easy way
                                    lets try the easier way
                                    find ~/MagicMirror/modules -type d | grep punycode | sort
                                    each module listed has it as a dependency either directly or indirectly
                                    on my system (with a lot of modules installed, but most not used)
                                    /home/sam/MagicMirror/modules/Hello-Lucy/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-BMI/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-CalvinAndHobbes/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-FinParcel/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-GoogleCalendar/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-HomeAssistantDisplay/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/uri-js/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-json/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Lottery/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-MARS/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-NOAA3/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-OnSpotify/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/psl/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/request/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/uri-js/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-SmartWebDisplay/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Strava/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Surf/node_modules/punycode
                                    /home/sam/MagicMirror/modules/MMM-Todoist/node_modules/punycode
                                    because its not listed in one of the modules directly, its a dependency of a dependency
                                      1a2a3a @1a2a3a
                                      @sdetweil can we fix the pm2 please?
                                        sdetweil @1a2a3a
                                        @1a2a3a use my mm.sh
                                        #!/bin/bash
                                        if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                           # if WAYLAND_DISPLAYis set, use it, else set to -0
                                           export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                        else
                                        fi
                                          1a2a3a @sdetweil
                                          hsa@HSA:~ $ find ~/MagicMirror/modules -type d | grep punycode | sort
                                          /home/hsa/MagicMirror/modules/MMM-Jast/node_modules/punycode
                                            1a2a3a @sdetweil
                                            @sdetweil it doesnt work still unfortunately. it goes into a black screen then back to wallpaper and keep looping in this manner…
                                            • 1 / 4
