    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 8.5k Views 2 Watching
    • 1 Offline
      1a2a3a @sdetweil
      @sdetweil my mm.sh is currently -
      #!/bin/bash
      # This file is still here to keep PM2 working on older installations.
      DISPLAY=:0 npm start
      should i change it to
      #!/bin/bash
      DISPLAY=:0 npm start:x11
        sdetweil @1a2a3a
        @1a2a3a your Linux/pi system uses a window manager to display the app session window on the screen
        In the past it was just x11 (xwindows)
        In the last couple years a new thing has appeared , Wayland
        We need two different commands to tell which wm is active
        If you look in the terminal window where you did the command above, you will see the debug output that will identify the module
        Here is mine for punycode
        [2026-04-08 19:03:13.384] [INFO]  [helpers] [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_20_MMM-HomeAssistantDisplay' ]
        [2026-04-08 19:03:13.391] [ERROR] [unknown] (node:936571) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
            at node:punycode:7:10
        So MMM-HomeAssistantDisplay is the module that is causing the message
        1 1 Reply Last reply Reply Quote 0
          sdetweil @1a2a3a
          @1a2a3a no, if it works w npm start, leave it alone
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil it didnt show any module error.
            [2026-05-01 23:53:38.898] [LOG]   [app] All module helpers loaded.
            [2026-05-01 23:53:38.901] [LOG]   [server] Starting server on port 8080 ...
            [2026-05-01 23:53:38.911] [ERROR] [unknown] (node:1979206) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
            (Use `electron --trace-deprecation ...` to show where the warning was created)
            [2026-05-01 23:53:39.001] [LOG]   [app] Server started ...
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil my pm2 is currently not working at the moment.
              i then tried to pm2 start and ran into this error. Ok not exactly error, but the mirror just keep going to blackscreen and nothing then back to wall paper then blackscreen and keep looping this.
              (node:1971942) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
              (Use `node --trace-deprecation ...` to show where the warning was created)
                sdetweil @1a2a3a
                @1a2a3a you did this right?
                NODE_OPTIONS=--trace-deprecation npm run start:xxx
                Replace xxx with x11, the whole line
                On your system
                That’s 2. — in front of of trace-deprecation
                1 2 Replies Last reply Reply Quote 0
                • 1 Offline
                  1a2a3a @sdetweil
                  @sdetweil yes correct
                  NODE_OPTIONS=–trace-deprecation npm run start:x11
                  i also manually git pull all the modules and all are up to dates as well.
                  • 1 Offline
                    1a2a3a @sdetweil
                    @sdetweil how do i fix my pm2 issue?
                      sdetweil @1a2a3a
                      @1a2a3a need 2 dashes in front of trace
                        sdetweil @1a2a3a
                        @1a2a3a change the npm start to npm run start:x11
                        If you had used my upgrade script it would have fixed that
                        • 1 Offline
                          1a2a3a @sdetweil
                          @sdetweil i did use your upgrade script.
                          do you mean change it inside mm.sh?
                          currently its
                          #!/bin/bash
                          change it to
                          #!/bin/bash
                          DISPLAY=:0 npm run start:x11
                          correct?
                            sdetweil @1a2a3a
                            @1a2a3a correct…
                            in version 2.35 we documented that we changed the default to
                            npm run start:wayland
                            for npm start
                            see package,json, scripts: section for the command options
                            • 1 Offline
                              1a2a3a @sdetweil
                              @sdetweil same thing
                              NODE_OPTIONS=--trace-deprecation npm run start:x11
                              [2026-05-02 00:31:24.574] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                              [2026-05-02 00:31:24.574] [LOG]   [app] All module helpers loaded.
                              [2026-05-02 00:31:24.592] [LOG]   [server] Starting server on port 8080 ...
                              [2026-05-02 00:31:24.602] [ERROR] [unknown] (node:1985687) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                  at BuiltinModule.compileForInternalLoader (node:internal/bootstrap/realm:398:7)
                                  at BuiltinModule.compileForPublicLoader (node:internal/bootstrap/realm:337:10)
                                  at loadBuiltinModule (node:internal/modules/helpers:126:7)
                                  at loadBuiltinWithHooks (node:internal/modules/cjs/loader:1229:15)
                                  at Module._load (node:internal/modules/cjs/loader:1320:48)
                                  at c._load (node:electron/js2c/node_init:2:18060)
                                  at wrapModuleLoad (node:internal/modules/cjs/loader:262:19)
                                  at Module.require (node:internal/modules/cjs/loader:1583:12)
                                  at require (node:internal/modules/helpers:153:16)
                              [2026-05-02 00:31:24.702] [LOG]   [app] Server started ...
                              [2026-05-02 00:31:24.703] [LOG]   [node_helper] Connectin```
                              code_text
                              • 1 Offline
                                1a2a3a @sdetweil
                                @sdetweil i have change my mm.sh to
                                #!/bin/bash
                                but when i do pm2 start MagicMirror, it doesnt start still.
                                  sdetweil @1a2a3a
                                  @1a2a3a SO much fun
                                  do this and give me the output
                                  grep "module:" ~/MagicMirror/config/config.js | sort | uniq
                                  and I’ll look thru them
                                  • 1 Offline
                                    1a2a3a @sdetweil
                                    @sdetweil here you go
                                    [hsa@HSA:~ $ grep "module:" ~/MagicMirror/config/config.js
                                                            module: "alert",
                                                            module: "updatenotification",
                                                            module: "clock",
                                            module: "MMM-Jast",
                                      module: 'MMM-GoogleDocs-Notes',
                                                            module: "newsfeed",
                                                    module: "MMM-NewsAPI",
                                      module: "MMM-MyScoreboard",
                                      module: "MMM-SoccerLiveScore",
                                    //  module: "MMM-GooglePhotos",
                                    // module: "MMM-ImagesPhotos",
                                    //   module: "MMM-Wallpaper",
                                    //    module: 'MMM-BackgroundSlideshow',
                                      module: "MMM-OneDrive",
                                      module: "MMM-CalendarExt3Agenda",
                                                             module: "MMM-CalendarExt3",
                                                            module: "calendar",](link url)
                                      sdetweil @1a2a3a
                                      @1a2a3a ok, I didn’t find it the easy way
                                      lets try the easier way
                                      find ~/MagicMirror/modules -type d | grep punycode | sort
                                      each module listed has it as a dependency either directly or indirectly
                                      on my system (with a lot of modules installed, but most not used)
                                      /home/sam/MagicMirror/modules/Hello-Lucy/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-BMI/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-CalvinAndHobbes/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-FinParcel/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-GoogleCalendar/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-HomeAssistantDisplay/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/uri-js/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-json/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Lottery/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-MARS/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-NOAA3/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-OnSpotify/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/psl/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/request/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/uri-js/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-SmartWebDisplay/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Strava/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Surf/node_modules/punycode
                                      /home/sam/MagicMirror/modules/MMM-Todoist/node_modules/punycode
                                      because its not listed in one of the modules directly, its a dependency of a dependency
                                      • 1 Offline
                                        1a2a3a @1a2a3a
                                        @sdetweil can we fix the pm2 please?
                                          sdetweil @1a2a3a
                                          @1a2a3a use my mm.sh
                                          #!/bin/bash
                                          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                             # if WAYLAND_DISPLAYis set, use it, else set to -0
                                             export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                          else
                                          fi
                                          • 1 Offline
                                            1a2a3a @sdetweil
                                            hsa@HSA:~ $ find ~/MagicMirror/modules -type d | grep punycode | sort
                                            /home/hsa/MagicMirror/modules/MMM-Jast/node_modules/punycode
                                            • 1 / 4
