    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.3k Views 2 Watching
      1a2a3a
      uhm hi, its been awhile since i updated my MM.
      i ran sdetweil upgrade script and these were being upgrade.
      doing test run = false
      Minimum Node version: v22.21.1
      Installed Node version: v20.9.0
      installing correct version of node and npm, please wait
      Installed Node version: v22.21.1
      No Node.js upgrade necessary.
      Minimum npm version: V10.9.4
      Installed npm version: V10.9.4
      No npm upgrade necessary.
      saving custom.css
      upgrading from version 2.28.0 to 2.36.0
      fetching latest revisions
      > magicmirror@2.36.0 postinstall
      > git clean -df fonts vendor modules/default
      > magicmirror@2.36.0 prepare
      > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
      no husky installed.
      i then tried to pm2 start and ran into this error. Ok not exactly error, but the mirror just keep going to blackscreen and nothing then back to wall paper then blackscreen and keep looping this.
      (node:1971942) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      then i ran npm start and get the punycode error
      [ERROR] [unknown] (node:1970698) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
      (Use `electron --trace-deprecation ...` to show where the warning was created)
      [1970698:0501/224750.044913:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
      [1970698:0501/224750.044978:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
      [1970698:0501/224750.044995:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
      /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      i then read in another thread to do npm run start:x11
      this works but the punycode still appear but mirror runs.
      feels like theres multiple item for me to fix and im kinda lost.
      can some kind soul help me out?
        sdetweil @1a2a3a
        @1a2a3a yeh, fine, but no wayland info there
        I see a diff on my mm.sh
        if wayland_display is not set, then I set it to
        WAYLAND_DISPLAY=wayland-0
        but your scripts use wayland-1
        SO, lets try this
        edit mm.sh again
        change this line
          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
        back to
          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
        and change this line
        export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
        to
        export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-1}
        and save mm.sh
        then
        pm2 stop all
        pm2 start MagicMirror
        1 1 Reply Last reply
          sdetweil @1a2a3a
          @1a2a3a both of those errors are due to older not updated modules, nothing is broken. We don’t have a way to suppress those messages
          Just npm trying to be ‘helpful’
          Do this to see which module is forcing the error
          NODE_OPTIONS=--trace-deprecation npm run start:xxx
          Where xxx is x11 or wayland depending on which window manager your MagicMirror is running on
          Then look in the terminal window where you ran the command for the better debug info
          1 2 Replies Last reply
            1a2a3a @sdetweil
            @sdetweil hi there old friend! its been a really long while and i hope all is fine on your end? anyway thanks for the prompt response!
            anyway i dont quite get what you mean.
            so i ran NODE_OPTIONS=–trace-deprecation npm run start:x11, MM run
            when i ran NODE_OPTIONS=–trace-deprecation npm run start:wayland, MM doesnt run…
              1a2a3a @sdetweil
              @sdetweil my mm.sh is currently -
              #!/bin/bash
              # This file is still here to keep PM2 working on older installations.
              DISPLAY=:0 npm start
              should i change it to
              #!/bin/bash
              DISPLAY=:0 npm start:x11
                sdetweil @1a2a3a
                @1a2a3a your Linux/pi system uses a window manager to display the app session window on the screen
                In the past it was just x11 (xwindows)
                In the last couple years a new thing has appeared , Wayland
                We need two different commands to tell which wm is active
                If you look in the terminal window where you did the command above, you will see the debug output that will identify the module
                Here is mine for punycode
                [2026-04-08 19:03:13.384] [INFO]  [helpers] [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_20_MMM-HomeAssistantDisplay' ]
                [2026-04-08 19:03:13.391] [ERROR] [unknown] (node:936571) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                    at node:punycode:7:10
                So MMM-HomeAssistantDisplay is the module that is causing the message
                  sdetweil @1a2a3a
                  @1a2a3a no, if it works w npm start, leave it alone
                    1a2a3a @sdetweil
                    @sdetweil it didnt show any module error.
                    [2026-05-01 23:53:38.898] [LOG]   [app] All module helpers loaded.
                    [2026-05-01 23:53:38.901] [LOG]   [server] Starting server on port 8080 ...
                    [2026-05-01 23:53:38.911] [ERROR] [unknown] (node:1979206) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                    [2026-05-01 23:53:39.001] [LOG]   [app] Server started ...
                      1a2a3a @sdetweil
                      @sdetweil my pm2 is currently not working at the moment.
                        sdetweil @1a2a3a
                        @1a2a3a you did this right?
                        Replace xxx with x11, the whole line
                        On your system
                        That’s 2. — in front of of trace-deprecation
                          1a2a3a @sdetweil
                          @sdetweil yes correct
                          i also manually git pull all the modules and all are up to dates as well.
                            1a2a3a @sdetweil
                            @sdetweil how do i fix my pm2 issue?
                              sdetweil @1a2a3a
                              @1a2a3a need 2 dashes in front of trace
                                sdetweil @1a2a3a
                                @1a2a3a change the npm start to npm run start:x11
                                If you had used my upgrade script it would have fixed that
                                  1a2a3a @sdetweil
                                  @sdetweil i did use your upgrade script.
                                  do you mean change it inside mm.sh?
                                  currently its
                                  #!/bin/bash
                                  change it to
                                  #!/bin/bash
                                  DISPLAY=:0 npm run start:x11
                                  correct?
                                    sdetweil @1a2a3a
                                    @1a2a3a correct…
                                    in version 2.35 we documented that we changed the default to
                                    for npm start
                                    see package,json, scripts: section for the command options
                                      1a2a3a @sdetweil
                                      @sdetweil same thing
                                      NODE_OPTIONS=--trace-deprecation npm run start:x11
                                      [2026-05-02 00:31:24.574] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                                      [2026-05-02 00:31:24.574] [LOG]   [app] All module helpers loaded.
                                      [2026-05-02 00:31:24.592] [LOG]   [server] Starting server on port 8080 ...
                                      [2026-05-02 00:31:24.602] [ERROR] [unknown] (node:1985687) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                          at BuiltinModule.compileForInternalLoader (node:internal/bootstrap/realm:398:7)
                                          at BuiltinModule.compileForPublicLoader (node:internal/bootstrap/realm:337:10)
                                          at loadBuiltinModule (node:internal/modules/helpers:126:7)
                                          at loadBuiltinWithHooks (node:internal/modules/cjs/loader:1229:15)
                                          at Module._load (node:internal/modules/cjs/loader:1320:48)
                                          at c._load (node:electron/js2c/node_init:2:18060)
                                          at wrapModuleLoad (node:internal/modules/cjs/loader:262:19)
                                          at Module.require (node:internal/modules/cjs/loader:1583:12)
                                          at require (node:internal/modules/helpers:153:16)
                                      [2026-05-02 00:31:24.702] [LOG]   [app] Server started ...
                                      [2026-05-02 00:31:24.703] [LOG]   [node_helper] Connectin```
                                      code_text
                                        1a2a3a @sdetweil
                                        @sdetweil i have change my mm.sh to
                                        #!/bin/bash
                                        but when i do pm2 start MagicMirror, it doesnt start still.
                                          sdetweil @1a2a3a
                                          @1a2a3a SO much fun
                                          do this and give me the output
                                          grep "module:" ~/MagicMirror/config/config.js | sort | uniq
                                          and I’ll look thru them
                                            1a2a3a @sdetweil
                                            @sdetweil here you go
                                            [hsa@HSA:~ $ grep "module:" ~/MagicMirror/config/config.js
        module: "alert",
        module: "updatenotification",
        module: "clock",
                                                    module: "MMM-Jast",
                                              module: 'MMM-GoogleDocs-Notes',
        module: "newsfeed",
                                                            module: "MMM-NewsAPI",
                                              module: "MMM-MyScoreboard",
                                              module: "MMM-SoccerLiveScore",
                                            //  module: "MMM-GooglePhotos",
                                            // module: "MMM-ImagesPhotos",
                                            //   module: "MMM-Wallpaper",
                                            //    module: 'MMM-BackgroundSlideshow',
                                              module: "MMM-OneDrive",
                                              module: "MMM-CalendarExt3Agenda",
        module: "MMM-CalendarExt3",
        module: "calendar",](link url)
                                              sdetweil @1a2a3a
                                              @1a2a3a ok, I didn’t find it the easy way
                                              lets try the easier way
                                              find ~/MagicMirror/modules -type d | grep punycode | sort
                                              each module listed has it as a dependency either directly or indirectly
                                              on my system (with a lot of modules installed, but most not used)
                                              /home/sam/MagicMirror/modules/Hello-Lucy/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-BMI/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-CalvinAndHobbes/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-FinParcel/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-GoogleCalendar/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-HomeAssistantDisplay/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/uri-js/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-json/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Lottery/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-MARS/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-NOAA3/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-OnSpotify/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/psl/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/request/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/uri-js/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-SmartWebDisplay/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Strava/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Surf/node_modules/punycode
                                              /home/sam/MagicMirror/modules/MMM-Todoist/node_modules/punycode
                                              because its not listed in one of the modules directly, its a dependency of a dependency
                                              • 1 / 4
