    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.2k Views 2 Watching
      sdetweil @1a2a3a
      @1a2a3a you did this right?
      NODE_OPTIONS=--trace-deprecation npm run start:xxx
      Replace xxx with x11, the whole line
      On your system
      That’s 2. — in front of of trace-deprecation
      1 2 Replies Last reply
        1a2a3a @sdetweil
        @sdetweil yes correct
        NODE_OPTIONS=–trace-deprecation npm run start:x11
        i also manually git pull all the modules and all are up to dates as well.
          1a2a3a @sdetweil
          @sdetweil how do i fix my pm2 issue?
            sdetweil @1a2a3a
            @1a2a3a need 2 dashes in front of trace
            1 1 Reply Last reply
              sdetweil @1a2a3a
              @1a2a3a change the npm start to npm run start:x11
              If you had used my upgrade script it would have fixed that
                1a2a3a @sdetweil
                @sdetweil i did use your upgrade script.
                do you mean change it inside mm.sh?
                currently its
                #!/bin/bash
                # This file is still here to keep PM2 working on older installations.
                DISPLAY=:0 npm start
                change it to
                #!/bin/bash
                DISPLAY=:0 npm run start:x11
                correct?
                  sdetweil @1a2a3a
                  @1a2a3a correct…
                  in version 2.35 we documented that we changed the default to
                  npm run start:wayland
                  for npm start
                  see package,json, scripts: section for the command options
                    1a2a3a @sdetweil
                    @sdetweil same thing
                    NODE_OPTIONS=--trace-deprecation npm run start:x11
                    [2026-05-02 00:31:24.574] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                    [2026-05-02 00:31:24.574] [LOG]   [app] All module helpers loaded.
                    [2026-05-02 00:31:24.592] [LOG]   [server] Starting server on port 8080 ...
                    [2026-05-02 00:31:24.602] [ERROR] [unknown] (node:1985687) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                        at node:punycode:7:10
                        at BuiltinModule.compileForInternalLoader (node:internal/bootstrap/realm:398:7)
                        at BuiltinModule.compileForPublicLoader (node:internal/bootstrap/realm:337:10)
                        at loadBuiltinModule (node:internal/modules/helpers:126:7)
                        at loadBuiltinWithHooks (node:internal/modules/cjs/loader:1229:15)
                        at Module._load (node:internal/modules/cjs/loader:1320:48)
                        at c._load (node:electron/js2c/node_init:2:18060)
                        at wrapModuleLoad (node:internal/modules/cjs/loader:262:19)
                        at Module.require (node:internal/modules/cjs/loader:1583:12)
                        at require (node:internal/modules/helpers:153:16)
                    [2026-05-02 00:31:24.702] [LOG]   [app] Server started ...
                    [2026-05-02 00:31:24.703] [LOG]   [node_helper] Connectin```
                    code_text
                      1a2a3a @sdetweil
                      @sdetweil i have change my mm.sh to
                      #!/bin/bash
                      but when i do pm2 start MagicMirror, it doesnt start still.
                        sdetweil @1a2a3a
                        @1a2a3a SO much fun
                        do this and give me the output
                        grep "module:" ~/MagicMirror/config/config.js | sort | uniq
                        and I’ll look thru them
                          1a2a3a @sdetweil
                          @sdetweil here you go
                          [hsa@HSA:~ $ grep "module:" ~/MagicMirror/config/config.js
                                                  module: "alert",
                                                  module: "updatenotification",
                                                  module: "clock",
                                  module: "MMM-Jast",
                            module: 'MMM-GoogleDocs-Notes',
                                                  module: "newsfeed",
                                          module: "MMM-NewsAPI",
                            module: "MMM-MyScoreboard",
                            module: "MMM-SoccerLiveScore",
                          //  module: "MMM-GooglePhotos",
                          // module: "MMM-ImagesPhotos",
                          //   module: "MMM-Wallpaper",
                          //    module: 'MMM-BackgroundSlideshow',
                            module: "MMM-OneDrive",
                            module: "MMM-CalendarExt3Agenda",
                                                   module: "MMM-CalendarExt3",
                                                  module: "calendar",](link url)
                            sdetweil @1a2a3a
                            @1a2a3a ok, I didn’t find it the easy way
                            lets try the easier way
                            find ~/MagicMirror/modules -type d | grep punycode | sort
                            each module listed has it as a dependency either directly or indirectly
                            on my system (with a lot of modules installed, but most not used)
                            /home/sam/MagicMirror/modules/Hello-Lucy/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-BMI/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-CalvinAndHobbes/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-FinParcel/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-GoogleCalendar/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-HomeAssistantDisplay/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/uri-js/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-json/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Lottery/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-MARS/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-NOAA3/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-OnSpotify/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/psl/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/request/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/uri-js/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-SmartWebDisplay/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Strava/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Surf/node_modules/punycode
                            /home/sam/MagicMirror/modules/MMM-Todoist/node_modules/punycode
                            because its not listed in one of the modules directly, its a dependency of a dependency
                              1a2a3a @1a2a3a
                              @sdetweil can we fix the pm2 please?
                                sdetweil @1a2a3a
                                @1a2a3a use my mm.sh
                                #!/bin/bash
                                if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                   # if WAYLAND_DISPLAYis set, use it, else set to -0
                                   export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                else
                                fi
                                  1a2a3a @sdetweil
                                  hsa@HSA:~ $ find ~/MagicMirror/modules -type d | grep punycode | sort
                                  /home/hsa/MagicMirror/modules/MMM-Jast/node_modules/punycode
                                    1a2a3a @sdetweil
                                    @sdetweil it doesnt work still unfortunately. it goes into a black screen then back to wallpaper and keep looping in this manner…
                                      sdetweil @1a2a3a
                                      @1a2a3a yep, its a dependency 3 layers down…
                                      “node_modules/yahoo-finance2”
                                      only thing is to open an issue on the module github page and see if the author can/will fix it
                                        1a2a3a @sdetweil
                                        @sdetweil ok got it. thanks. since the punycode is not material lets ignore it for now and focus on the pm2 haha.
                                          sdetweil @1a2a3a
                                            1a2a3a @sdetweil
                                            @sdetweil i did. i copied your code as suggest and paste it into my mm.sh and it the same issue.
                                            • 1 / 4
