    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 9.2k Views 2 Watching
      1a2a3a @sdetweil
      @sdetweil it didnt show any module error.
      [2026-05-01 23:53:38.898] [LOG]   [app] All module helpers loaded.
      [2026-05-01 23:53:38.901] [LOG]   [server] Starting server on port 8080 ...
      [2026-05-01 23:53:38.911] [ERROR] [unknown] (node:1979206) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
      (Use `electron --trace-deprecation ...` to show where the warning was created)
      [2026-05-01 23:53:39.001] [LOG]   [app] Server started ...
        1a2a3a @sdetweil
        @sdetweil my pm2 is currently not working at the moment.
        i then tried to pm2 start and ran into this error. Ok not exactly error, but the mirror just keep going to blackscreen and nothing then back to wall paper then blackscreen and keep looping this.
        (node:1971942) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
        (Use `node --trace-deprecation ...` to show where the warning was created)
          sdetweil @1a2a3a
          @1a2a3a you did this right?
          NODE_OPTIONS=--trace-deprecation npm run start:xxx
          Replace xxx with x11, the whole line
          On your system
          That’s 2. — in front of of trace-deprecation
          1 2 Replies Last reply
            1a2a3a @sdetweil
            @sdetweil yes correct
            NODE_OPTIONS=–trace-deprecation npm run start:x11
            i also manually git pull all the modules and all are up to dates as well.
              1a2a3a @sdetweil
              @sdetweil how do i fix my pm2 issue?
                sdetweil @1a2a3a
                @1a2a3a need 2 dashes in front of trace
                1 1 Reply Last reply
                  sdetweil @1a2a3a
                  @1a2a3a change the npm start to npm run start:x11
                  If you had used my upgrade script it would have fixed that
                    1a2a3a @sdetweil
                    @sdetweil i did use your upgrade script.
                    do you mean change it inside mm.sh?
                    currently its
                    #!/bin/bash
                    # This file is still here to keep PM2 working on older installations.
                    DISPLAY=:0 npm start
                    change it to
                    #!/bin/bash
                    DISPLAY=:0 npm run start:x11
                    correct?
                      sdetweil @1a2a3a
                      @1a2a3a correct…
                      in version 2.35 we documented that we changed the default to
                      npm run start:wayland
                      for npm start
                      see package,json, scripts: section for the command options
                        1a2a3a @sdetweil
                        @sdetweil same thing
                        NODE_OPTIONS=--trace-deprecation npm run start:x11
                        [2026-05-02 00:31:24.574] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                        [2026-05-02 00:31:24.574] [LOG]   [app] All module helpers loaded.
                        [2026-05-02 00:31:24.592] [LOG]   [server] Starting server on port 8080 ...
                        [2026-05-02 00:31:24.602] [ERROR] [unknown] (node:1985687) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                            at node:punycode:7:10
                            at BuiltinModule.compileForInternalLoader (node:internal/bootstrap/realm:398:7)
                            at BuiltinModule.compileForPublicLoader (node:internal/bootstrap/realm:337:10)
                            at loadBuiltinModule (node:internal/modules/helpers:126:7)
                            at loadBuiltinWithHooks (node:internal/modules/cjs/loader:1229:15)
                            at Module._load (node:internal/modules/cjs/loader:1320:48)
                            at c._load (node:electron/js2c/node_init:2:18060)
                            at wrapModuleLoad (node:internal/modules/cjs/loader:262:19)
                            at Module.require (node:internal/modules/cjs/loader:1583:12)
                            at require (node:internal/modules/helpers:153:16)
                        [2026-05-02 00:31:24.702] [LOG]   [app] Server started ...
                        [2026-05-02 00:31:24.703] [LOG]   [node_helper] Connectin```
                        code_text
                          1a2a3a @sdetweil
                          @sdetweil i have change my mm.sh to
                          #!/bin/bash
                          but when i do pm2 start MagicMirror, it doesnt start still.
                            sdetweil @1a2a3a
                            @1a2a3a SO much fun
                            do this and give me the output
                            grep "module:" ~/MagicMirror/config/config.js | sort | uniq
                            and I’ll look thru them
                              1a2a3a @sdetweil
                              @sdetweil here you go
                              [hsa@HSA:~ $ grep "module:" ~/MagicMirror/config/config.js
                                                      module: "alert",
                                                      module: "updatenotification",
                                                      module: "clock",
                                      module: "MMM-Jast",
                                module: 'MMM-GoogleDocs-Notes',
                                                      module: "newsfeed",
                                              module: "MMM-NewsAPI",
                                module: "MMM-MyScoreboard",
                                module: "MMM-SoccerLiveScore",
                              //  module: "MMM-GooglePhotos",
                              // module: "MMM-ImagesPhotos",
                              //   module: "MMM-Wallpaper",
                              //    module: 'MMM-BackgroundSlideshow',
                                module: "MMM-OneDrive",
                                module: "MMM-CalendarExt3Agenda",
                                                       module: "MMM-CalendarExt3",
                                                      module: "calendar",](link url)
                                sdetweil @1a2a3a
                                @1a2a3a ok, I didn’t find it the easy way
                                lets try the easier way
                                find ~/MagicMirror/modules -type d | grep punycode | sort
                                each module listed has it as a dependency either directly or indirectly
                                on my system (with a lot of modules installed, but most not used)
                                /home/sam/MagicMirror/modules/Hello-Lucy/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-BMI/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-CalvinAndHobbes/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-FinParcel/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-GoogleCalendar/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-HomeAssistantDisplay/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-json/node_modules/npm/node_modules/uri-js/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-json/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Lottery/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-MARS/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-NOAA3/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-OnSpotify/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/psl/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/request/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Reddit/node_modules/uri-js/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-SmartWebDisplay/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Strava/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Surf/node_modules/punycode
                                /home/sam/MagicMirror/modules/MMM-Todoist/node_modules/punycode
                                because its not listed in one of the modules directly, its a dependency of a dependency
                                  1a2a3a @1a2a3a
                                  @sdetweil can we fix the pm2 please?
                                    sdetweil @1a2a3a
                                    @1a2a3a use my mm.sh
                                    #!/bin/bash
                                    if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                       # if WAYLAND_DISPLAYis set, use it, else set to -0
                                       export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                    else
                                    fi
                                      1a2a3a @sdetweil
                                      hsa@HSA:~ $ find ~/MagicMirror/modules -type d | grep punycode | sort
                                      /home/hsa/MagicMirror/modules/MMM-Jast/node_modules/punycode
                                        1a2a3a @sdetweil
                                        @sdetweil it doesnt work still unfortunately. it goes into a black screen then back to wallpaper and keep looping in this manner…
                                          sdetweil @1a2a3a
                                          @1a2a3a yep, its a dependency 3 layers down…
                                          “node_modules/yahoo-finance2”
                                          only thing is to open an issue on the module github page and see if the author can/will fix it
                                            1a2a3a @sdetweil
                                            @sdetweil ok got it. thanks. since the punycode is not material lets ignore it for now and focus on the pm2 haha.
                                            • 1 / 4
