    Calendar events broadcasting, nothing showing...
    14 Posts 3 Posters 736 Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      0|run8080  | [2026-05-27 08:48:46.741] [DEBUG] [calendar] title: Winlink Wednesday Zoom class
      0|run8080  | [2026-05-27 08:48:46.741] [DEBUG] [calendar] Event: Winlink Wednesday Zoom class | start: Wed Sep 16 2020 20:30:00 GMT-0700 (Pacific Daylight Time) | end: Wed Sep 16 2020 21:30:00 GMT-0700 (Pacific Daylight Time) | recurring: true
      0|run8080  | [2026-05-27 08:48:46.743] [INFO]  [calendar] Broadcasting 165 events from https://calendar.google.com/calendar/ical/b7jirihj85d3klbcvja8im40fk%40group.calendar.google.com/public/basic.ics.
      Running newest Magic Mirror, installed April 27, using Sam’s scripts.
      I’m getting broadcasts as you can see, but default calendar and all modules that depend on it show nothing.
      any clue what’s going on?
        sdetweil @BKeyport
        @BKeyport thanks… I see an other change submitted today
        https://github.com/MagicMirrorOrg/MagicMirror/pull/4180
        which references this topic
        if you want to try that do
        # restore calendar.js
        git checkout defaultmodules/calendar/calendar.js
        git fetch origin pull/4180/head:_fix_304
        rm package-lock.json
        git switch _fix_304
        npm run install-mm
        restart MM
        BKeyportB 1 Reply Last reply Reply Quote 1
          sdetweil @BKeyport
          @BKeyport broadcasting is different than using
          Can you explain the setup and config you are running.
          Is this multiple systems to one server?
          We added a caching handler to reduce unnecessary sends to the same module
            sdetweil @BKeyport
            @BKeyport were you able to resolve this?? the 165 events could have been all in the past too
            • BKeyportB Offline
              @sdetweil Sorry, I’ve been away due to work issues. It is multiple systems to one server, and still unsolved. Worked fine before “upgrade” to current MM version.
                sdetweil @BKeyport
                @BKeyport hmmm. I think the caching might be affecting
                Comment out these lines in calendar.js
                KristjanESPERANTOK BKeyportB 2 Replies Last reply Reply Quote 0
                • KristjanESPERANTOK Offline
                  I tracked this down to a likely root cause: after the HTTPFetcher 304 change, some consumers were trying to process empty responses. In PR #4180, I fixed that for calendar and other consumers.
                  • BKeyportB Offline
                    @sdetweil does not seem to affect anything.
                                if (notification === "CALENDAR_EVENTS") {
                                            // have we received events for this url
                                            if (!this.calendarData[payload.url]) {
                                                    // no, setup the structure to hold the info
                                                    this.calendarData[payload.url] = { events: null, checksum: null };
                                            // save the event list
                                            this.calendarData[payload.url].events = payload.events;
                                            this.error = null;
                                            this.loaded = true;
                                            if (this.config.broadcastEvents) {
                                                    this.broadcastEvents();
                                            // if the checksum is the same
                                            if (this.calendarData[payload.url].checksum === payload.checksum) {
                                                    // then don't update the UI
                                                    return;
                                            // haven't seen or the checksum is different
                                            this.calendarData[payload.url].checksum = payload.checksum;
                      sdetweil @BKeyport
                      git switch _fix_304
                      npm run install-mm
                      restart MM
                      • BKeyportB Offline
                        @sdetweil That fixed it here.
                          sdetweil @BKeyport
                          @BKeyport awesome!! Thanks for the feedback
                          • S sdetweil has marked this topic as solved
                          • BKeyportB Offline
                            @sdetweil When we get to the quarterly update, I’ll need to know how to update back to the main. LOL
                              sdetweil @BKeyport
                              @BKeyport yes. If you use my upgrade script it will move you back to the mainline, or I’ll give you instructions
                              • BKeyportB Offline
                                @sdetweil oh, cool that you built that in the scripts - I use that.
                                  sdetweil @BKeyport
                                  @BKeyport yes, if I discover you are not on the master branch, I move you to master, then update from there.
                                  For exactly this situation. Trying a specific fix or all of develop branch.
