    Calendar events broadcasting, nothing showing...
    14 Posts 3 Posters 5.7k Views 3 Watching
      sdetweil @BKeyport
      @BKeyport broadcasting is different than using
      Can you explain the setup and config you are running.
      Is this multiple systems to one server?
      We added a caching handler to reduce unnecessary sends to the same module
        sdetweil @BKeyport
        @BKeyport were you able to resolve this?? the 165 events could have been all in the past too
        • BKeyportB
          @sdetweil Sorry, I’ve been away due to work issues. It is multiple systems to one server, and still unsolved. Worked fine before “upgrade” to current MM version.
            sdetweil @BKeyport
            @BKeyport hmmm. I think the caching might be affecting
            Comment out these lines in calendar.js
            KristjanESPERANTOK BKeyportB 2 Replies Last reply Reply Quote 0
            • KristjanESPERANTOK
              I tracked this down to a likely root cause: after the HTTPFetcher 304 change, some consumers were trying to process empty responses. In PR #4180, I fixed that for calendar and other consumers.
              • BKeyportB
                @sdetweil does not seem to affect anything.
                            if (notification === "CALENDAR_EVENTS") {
                                        // have we received events for this url
                                        if (!this.calendarData[payload.url]) {
                                                // no, setup the structure to hold the info
                                                this.calendarData[payload.url] = { events: null, checksum: null };
                                        // save the event list
                                        this.calendarData[payload.url].events = payload.events;
                                        this.error = null;
                                        this.loaded = true;
                                        if (this.config.broadcastEvents) {
                                                this.broadcastEvents();
                                        // if the checksum is the same
                                        if (this.calendarData[payload.url].checksum === payload.checksum) {
                                                // then don't update the UI
                                                return;
                                        // haven't seen or the checksum is different
                                        this.calendarData[payload.url].checksum = payload.checksum;
                  sdetweil @BKeyport
                  @BKeyport thanks… I see an other change submitted today
                  https://github.com/MagicMirrorOrg/MagicMirror/pull/4180
                  which references this topic
                  if you want to try that do
                  # restore calendar.js
                  git checkout defaultmodules/calendar/calendar.js
                  git fetch origin pull/4180/head:_fix_304
                  rm package-lock.json
                  git switch _fix_304
                  npm run install-mm
                  restart MM
                  BKeyportB 1 Reply Last reply Reply Quote 1
                  • BKeyportB
                    @sdetweil That fixed it here.
                      sdetweil @BKeyport
                      @BKeyport awesome!! Thanks for the feedback
                      • BKeyportB
                        @sdetweil When we get to the quarterly update, I’ll need to know how to update back to the main. LOL
                          sdetweil @BKeyport
                          @BKeyport yes. If you use my upgrade script it will move you back to the mainline, or I’ll give you instructions
                          • BKeyportB
                            @sdetweil oh, cool that you built that in the scripts - I use that.
                              sdetweil @BKeyport
                              @BKeyport yes, if I discover you are not on the master branch, I move you to master, then update from there.
                              For exactly this situation. Trying a specific fix or all of develop branch.
