    remote control help needed
    28 Posts 4 Posters 9.1k Views 4 Watching
    • T Offline
      tommyk
      hello
      this might be a hard one but could anyone please help me with this module
      I have been trying to add a module to the phone app but it is way beyond my understanding
      I want to add my mmm jukebox to the module controls on phone
      so that I can play/stop/next/previous /etc on my jukebox
      I added the custom menu and it added menu items 1.2.3
      but they do nothing…
      any help really appreciated
      thanks
      • T Offline
        tommyk @tommyk
        no joy at posting url in browser…
        but the good news is… the app is now on my phone and jukebox is working
        i was messing about on phone and config and I have no idea what i done
        but I scanned the QR again and it connected.
        only trouble is ,now I am afraid I might mess it up again…
        without your help there is no way I would have gotten this thing to work
        so thank you so much sam, you are a genius
        ps … I have two MM setups, one in living room and one in bedroom
        so now I am goin to try and put RC on other one…lol
        wish me luck
        thanks again
        tommyk
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @tommyk
          @tommyk Update MMM-JukeBox and it should work now :)
          • E Offline
            eddiebrok
            It sounds like the menu is being added correctly, but the actions aren’t linked to MMM-Jukebox commands. Double-check that the menu items are sending the correct notifications or commands that MMM-Jukebox expects. Sharing your config would make it easier to spot the issue.
              KristjanESPERANTO Module Developer @eddiebrok
              @eddiebrok
              This minimal config works for me:
              let config = {
                address: "0.0.0.0",
                port: 8080,
                ipWhitelist: [],
                    module: "MMM-Remote-Control",
                    module: "MMM-JukeBox",
              • T Offline
                tommyk @KristjanESPERANTO
                @KristjanESPERANTO hi there
                thanks for your reply and help.
                well i got this working for 5 mins and it was just what i wanted
                I played music and stopped it
                then I refreshed the mirror and now the app wont work
                it says there is an error with javascript
                tried rescanning the qr code but same error
                any ideas ?
                thanks for helping
                tommyk
                S T 2 Replies Last reply Reply Quote 0
                  sdetweil @tommyk
                  @tommyk can you go to the MM folder and do
                  npm run config:check
                  and show the output
                  • T Offline
                    tommyk @tommyk
                    pig@raspberrypi:~ $ cd MagicMirror
                    pig@raspberrypi:~/MagicMirror $ npm run config:check
                    magicmirror@2.36.0 config:check
                    node js/check_config.js
                    [2026-06-09 05:20:06.900] [LOG] [utils] Loading config …
                    [2026-06-09 05:20:06.913] [INFO] [utils] Checking config file /home/pig/MagicMirror/config/config.js …
                    [2026-06-09 05:20:07.104] [INFO] [utils] Your configuration file doesn’t contain syntax errors :)
                    [2026-06-09 05:20:07.105] [INFO] [utils] Checking modules structure configuration …
                    [2026-06-09 05:20:07.228] [INFO] [utils] Your modules structure configuration doesn’t contain errors :)
                    • T Offline
                      tommyk @sdetweil
                      hi, will this help
                      let config = {
                      		address: "0.0.0.0",	// Address to listen on, can be:
                      	port: 8080,
                      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                      	ipWhitelist: [],
                      	// Set [] to allow all IP addresses
                      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                      	language: "en",
                      	locale: "en-US",   // this variable is provided as a consistent location
                      			   // it is currently only used by 3rd party modules. no MagicMirror code uses this value
                      			   // as we have no usage, we  have no constraints on what this field holds
                      			   // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_left"
                      			module: 'MMM-Facts',
                      			position: 'middle_center',
                      					updateInterval: 25,
                      					fadeSpeed: 4,
                      					category: 'random',
                          module: 'MMM-Remote-Control',
                          position: 'top_right', // Required to show URL/QR code on mirror
                              customCommand: {},  // Optional, See "Using Custom Commands" below
                              secureEndpoints: true, // Optional, See API/README.md
                              // uncomment any of the lines below if you're gonna use it
                              customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                              apiKey: "9f233797-d0e5-42c2-bbcd-c92aa98b33e2"
                       // Optional, See API/README.md for details
                              // classes: {}, // Optional, See "Custom Classes" below
                              // showModuleApiMenu: false, // Optional, disable the Module Controls menu
                              // showNotificationMenu: true, // Optional, disable the Notification menu
                              // QR Code options (new!)
                              // showQRCode: true, // Optional, display QR code for easy mobile access (default: true)
                           // QRCodeSize: 50, // Optional, size of QR code in pixels (default: 150)
                             //  qrCodePosition: "below" // Optional:
                              //   "below" - Show URL above, QR code below (default)
                              //   "above" - Show QR code above, URL below
                              //   "replace" - Show only QR code, no URL text
                            module: "MMM-Carousel",
                            position: "bottom_bar",
                              transitionInterval: 10000,
                              showPageIndicators: true,
                              showPageControls: true,
                              ignoreModules: ["clock","newsfeed" , "MMM-JukeBox","Hello-Lucy", ],
                              mode: "slides",
                              slides: {
                                main: ["calendar", "weather",  ],
                                "Slide 2": [
                                  'MMM-Pinfo',
                              "MMM-ImagesPhotos",
                                "Slide 3": ["MMM-WeeklySchedule","MMM-EasyPix",],
                      		"Slide 4": ['MMM-Facts','MMM-Remote-Control',],
                          module: "MMM-WeeklySchedule",
                          header: "The Rowans, weeklys events",
                              schedule: {
                                  timeslots: [ "morning", "time", "price",  "afternoon", "time", "price"],
                                  lessons: {
                                      mon: [ "breakfast, bacon/sausage balm", "9.30-10.30", "£2.00","?","?", "?" ],
                                      tue: [ "butty van, pies, sandwich"," 12.00", "varied","?","?", "?" ],
                                      wed: [ "coffee morning, toast,tea cake", "9.30-10.30", "£1.50",
                      		 "knit and knatter", "2.00-4.00", " free"],
                                      thu: [ "Chair yoga", "11.15-12.15", "£5.00", "dominos", " 2.00-4.00","£1.00" ],
                                      fri: [ "lunchoen club,- £5", "12pm", "bingo", "2pm-4pm" ],
                                     sat: [  "w/e , no staff" , "nothing" ],
                                     sun: [ "w/e ,no staff", "nothing"],
                              updateInterval: 1 * 60 * 60 * 1000, // every hour
                              showNextDayAfter: "24:00"
                          module: 'MMM-Pinfo',
                            debug: true,
                            refresh: 5000,
                            itemAlign: 'left',
                            labelAlign: 'left',
                            valueAlign: 'center',
                            labelSize: null,
                            containerSize: null,
                            DEVICE: {
                              labelModel: "Model",
                              displayModel: true,
                              orderModel: 1,
                              labelSerial: 'Serial',
                              displaySerial: true,
                              orderSerial: 2
                            OS: {
                              labelOs: 'OS',
                              displayOs: true,
                              orderOs: 3
                            NETWORK: {
                              labelType: 'NET Type',
                              displayType: false,
                              orderType: 4,
                              labelIPv4: 'IPv4',
                              displayIPv4: true,
                              orderIPv4: 5,
                              labelIPv6: 'IPv6',
                              displayIPv6: false,
                              orderIPv6: 6,
                              labelMac: 'MAC',
                              displayMac: false,
                              orderMac: 7
                            RAM: {
                              labelRam: 'RAM',
                              displayRam: true,
                              orderRam: 8
                            STORAGE: {
                              labelStorage: 'Storage',
                              displayStorage: true,
                              orderStorage: 9,
                            CPU: {
                              labelType: 'CPU Type',
                              displayType: false,
                              orderType: 10,
                              labelUsage: 'CPU Usage',
                              displayUsage: true,
                              orderUsage: 11,
                              labelTemp: 'CPU Temp',
                              displayTemp: true,
                              orderTemp: 12
                            UPTIME: {
                                labelUptime: 'Uptime',
                                displayUptime: true,
                                orderUptime: 13
                            WARNING: {
                              enable: false,
                              interval: 1000 * 60 * 5,
                              check: {
                                CPU_TEMP: 65,
                                CPU_USAGE: 75,
                                RAM_USED: 80,
                                STORAGE_USED: 80
                       module: "MMM-ImagesPhotos",
                       position: "middle_center",
                        opacity: 0.9,
                        animationSpeed: 500,
                        updateInterval: 5000,
                        maxHeight: "700px",
                        maxWidth:"700px",
                        sequential: false  // process the image list randomly
                            module: "MMM-EasyPix",
                              picName: "candle2.webp",  // Enter the picture file name. You can even use a direct internet URL to an image.
                              maxWidth: "75%"       // Size picture precisely. Retains aspect ratio.
                      disabled: false,
                      module: "Hello-Lucy",
                      //position: "top_center",
                          keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                          timeout: 15,                        // timeout listening for a command/sentence
                          standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                          microphone: "1,2",                  // run "arecord -l" card # and device # mine is "0,0"
                          sounds: ["nolly4.mp3", "llucy.mp3"],        // welcome sound at startup. Add several for a random greetings
                          confirmationSound: "ding.mp3",      // name and extension of sound file
                          //startHideAll: true,                 // All modules start as hidden EXCEPT PAGE ONE
                          // *** Page One is your default startup page *** This overrides startHideAll: true,
                         // pageOneModules: ["Hello-Lucy","MMM-EasyPix"],                     // default modules to show on page one/startup
                         // pageTwoModules: ["Hello-Lucy", "MMM-BMW-DS", "MMM-EventHorizon"], // modules to show on page two
                         // pageThreeModules: ["Hello-Lucy", "MMM-Lunartic"],                 // modules to show on page three
                         // pageFourModules: ["Hello-Lucy", "MMM-PC-Stats"],                  // modules to show on page four
                         // pageFiveModules: ["Hello-Lucy", "MMM-Searchlight"],               // modules to show on page five
                         // pageSixModules: ["Hello-Lucy", "MMM-NOAA3"],                      // modules to show on page six
                          //pageSevenModules: ["Hello-Lucy", "MMM-Recipe"],                   // modules to show on page seven
                         // pageEightModules: ["Hello-Lucy", "MMM-rfacts"],                   // modules to show on page eight
                         // pageNineModules: ["Hello-Lucy", "MMM-History"],                   // modules to show on page nine
                         // pageTenModules: ["Hello-Lucy", "MMM-HardwareMonitor"]             // modules to show on page ten
                        position: "bottom_center", // Explanation: choose any MagicMirror position
                          source: "file",                 // "file" | "USB" | "URL"
                          usbPath: "D:/soundFiles",       // Explanation: only used when source === "USB"
                          allowedExtensions: [".mp3", ".wav", ".ogg", ".m4a"],
                          pageSize: 20,                    // Explanation: number of buttons per page
                          showControlBar: true,            // NEW: use symbol bar; hides legacy Random button
                          randomButtonText: "Random Play", // Explanation: label for the legacy random button (when control bar is off)
                          stopButtonText: "Stop",          // Explanation: label for the stop button
                          infoText: "Select a number or use Random Play.",
                          continueOnHide: true,            // Explanation: true = audio continues when module hides
                          syncUsbToLocal: false,           // Explanation: optional backend copy from USB to ./soundFiles
                          autostartRandomLoop: false       // Explanation: true = auto start random loop on startup
                      			module: "newsfeed",
                      				feeds: [
                      						title: "BBC News",
                      						url: "http://feeds.bbci.co.uk/news/rss.xml"
                      				showSourceTitle: true,
                      				showPublishDate: true,
                      				broadcastNewsFeeds: true,
                      				broadcastNewsUpdates: true
                      			module: "weather",
                      				weatherProvider: "openmeteo",
                      				type: "current",
                      				lat: 53.48333,
                      				lon: -2.51667,
                      			module: "weather",
                      			header: "Weather Forecast",
                      				type: "forecast",
                      				lat: 53.48333,
                      				lon: -2.51667,
                      			header: "US Holidays",
                      						symbol: "calendar-check",
                      						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                      			header: "UK Holidays",
                      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
                        sdetweil @tommyk
                        @tommyk the app on phone says syntax error?
                        can you open the app on a computer web browser so we can examine the browser logs?
                        once loaded(or not) open the developers window, console
                        ctrl-shift-i, then select the console tab, maybe the javascript error is listed there
                        • T Offline
                          tommyk @sdetweil
                          @sdetweil hi sam
                          how do I open app in pc browser ?
                          told you I was stupid lol
                          thanks for helping me
                          • T Offline
                            tommyk @tommyk
                            sorry . think this is it
                            (index):1 Refused to apply style from ‘http://localhost:8080/config/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                            loader.js:230 Error on loading stylesheet: config/custom.css
                            (anonymous) @ loader.js:230
                            alert.js:45 Starting module: alert
                            updatenotification.js:19 Starting module: updatenotification
                              sdetweil @tommyk
                              @tommyk the module instructions, step 5
                                sdetweil @tommyk
                                @tommyk you can get rid of these noise errors
                                Open a terminal window, and do
                                cd config
                                touch custom.css
                                Next time you start MagicMirror you won’t get those errors reported
                                If you use my/the scripted install, it does this for you
                                • T Offline
                                  tommyk @sdetweil
                                  thanks for all your help guys but it just wont work for me ,which is a shame
                                  because it looked like just what I was looking for, but I have tried and tried
                                  I uninstalled the remote control module and reinstalled it but It wont open on my phone
                                  for some reason, so its beginning to look like I am stuck with the keyboard.
                                  of course I will keep trying because it is doin my head in…it worked for 5 minutes and then
                                  stopped.
                                  I may end up starting from scratch. with a new memory card and fresh OS install
                                  but it wont beat me lol
                                  cheers
                                    sdetweil @tommyk
                                    @tommyk I installed RC, and used the default config…
                                    then started mm and used my MM address and port, from the same machine
                                    http://localhost:8090/remote.html
                                    and from my phone
                                    http://sams:8090/remote.html
                                    both worked find
                                    you DO have address and ipWhitelist set as “0.0.0.0”, and [], respectively, correct…
                                    this allows any host (phone, laptop,… system other than MM machine) to connect to the MM server
                                    otherwise the connection will be refused/blocked
                                    • T Offline
                                      tommyk @tommyk
                                      yeah sam,
                                      I am so confused, dont understand it
                                      but thanks for all your help
                                        sdetweil @tommyk
                                        @tommyk mm is meant to be a closed system on the wall…
                                        no one needs to access this, as its output only… SO
                                        the default config says ONLY apps INSIDE this SAME machine can access the MM server
                                        localhost is the name of the network connection (loop back)
                                        now, it so happens one could add controls to limit JUST ONE (or a few) machines too…
                                        this is the ipWhitelist
                                        but as we’ve seen that (output only with no external access) doesn’t work for a number of use cases.
                                        remote control, my mmm-config, …
                                        SO, changing the config
                                        address means listen for incoming requests on A network adapter, wifi OR ethernet…
                                        address=“192.168.2.106” (for my desktop ethernet address)
                                        but what if you have both? or more than one…
                                        you can ONLY put ONE address there…
                                        so there is a shortcut , “0.0.0.0”, means listen on ALL adapters, regardless their address…
                                        now… i’ll just make an example, not implying anything…
                                        you built this thing, and if ANYONE in your house could get in and fiddle with the MM parts, or others,
                                        they might take the system down or something else…
                                        kids that don’t know, but LOVE to explore…!!
                                        how can i keep THEM out…
                                        we I could limit access to ONLY MY phone, laptop,… then they couldn’t get in…
                                        so you could put your phone and laptop ip addresses in the ipWhitelist:[] list
                                        and then only YOU can get into the MM app system …
                                        the RemoteControl readme, mentions this change in the config…
                                        • T Offline
                                          tommyk @sdetweil
                                          @sdetweil yes, I understand what you are saying sam
                                          but if I put 0.0.0.0 as per instructions anyone can access it, right ?
                                          so I dont get why I cant
                                          phone app says error with javascript
                                          I am at my wits end lol
                                            sdetweil @tommyk
                                            @tommyk only anyone on your home network… not anyone in the world…
                                            I don’t know on the phone app… I didnt install the app…
                                            • T Offline
                                              tommyk @sdetweil
                                              @sdetweil yep right
                                              there is only me using the mirror
                                              so when I run MM
                                              RC shows the bar code and ip address
                                              when I scan code it tries to connect to app
                                              it says… error when trying to to load javascript file
