    remote control help needed
    28 Posts 4 Posters 9.9k Views 4 Watching
    • E Offline
      eddiebrok
      It sounds like the menu is being added correctly, but the actions aren’t linked to MMM-Jukebox commands. Double-check that the menu items are sending the correct notifications or commands that MMM-Jukebox expects. Sharing your config would make it easier to spot the issue.
      • KristjanESPERANTOK Online
        KristjanESPERANTO Module Developer @eddiebrok
        @eddiebrok
        This minimal config works for me:
        let config = {
          address: "0.0.0.0",
          port: 8080,
          ipWhitelist: [],
              module: "MMM-Remote-Control",
              module: "MMM-JukeBox",
        • T Offline
          tommyk @KristjanESPERANTO
          @KristjanESPERANTO hi there
          thanks for your reply and help.
          well i got this working for 5 mins and it was just what i wanted
          I played music and stopped it
          then I refreshed the mirror and now the app wont work
          it says there is an error with javascript
          tried rescanning the qr code but same error
          any ideas ?
          thanks for helping
          tommyk
          S T 2 Replies Last reply Reply Quote 0
            sdetweil @tommyk
            @tommyk can you go to the MM folder and do
            npm run config:check
            and show the output
            • T Offline
              tommyk @tommyk
              pig@raspberrypi:~ $ cd MagicMirror
              pig@raspberrypi:~/MagicMirror $ npm run config:check
              magicmirror@2.36.0 config:check
              node js/check_config.js
              [2026-06-09 05:20:06.900] [LOG] [utils] Loading config …
              [2026-06-09 05:20:06.913] [INFO] [utils] Checking config file /home/pig/MagicMirror/config/config.js …
              [2026-06-09 05:20:07.104] [INFO] [utils] Your configuration file doesn’t contain syntax errors :)
              [2026-06-09 05:20:07.105] [INFO] [utils] Checking modules structure configuration …
              [2026-06-09 05:20:07.228] [INFO] [utils] Your modules structure configuration doesn’t contain errors :)
              • T Offline
                tommyk @sdetweil
                hi, will this help
                let config = {
                		address: "0.0.0.0",	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                	ipWhitelist: [],
                	// Set [] to allow all IP addresses
                	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                	language: "en",
                	locale: "en-US",   // this variable is provided as a consistent location
                			   // it is currently only used by 3rd party modules. no MagicMirror code uses this value
                			   // as we have no usage, we  have no constraints on what this field holds
                			   // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			module: 'MMM-Facts',
                			position: 'middle_center',
                					updateInterval: 25,
                					fadeSpeed: 4,
                					category: 'random',
                    module: 'MMM-Remote-Control',
                    position: 'top_right', // Required to show URL/QR code on mirror
                        customCommand: {},  // Optional, See "Using Custom Commands" below
                        secureEndpoints: true, // Optional, See API/README.md
                        // uncomment any of the lines below if you're gonna use it
                        customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                        apiKey: "9f233797-d0e5-42c2-bbcd-c92aa98b33e2"
                 // Optional, See API/README.md for details
                        // classes: {}, // Optional, See "Custom Classes" below
                        // showModuleApiMenu: false, // Optional, disable the Module Controls menu
                        // showNotificationMenu: true, // Optional, disable the Notification menu
                        // QR Code options (new!)
                        // showQRCode: true, // Optional, display QR code for easy mobile access (default: true)
                     // QRCodeSize: 50, // Optional, size of QR code in pixels (default: 150)
                       //  qrCodePosition: "below" // Optional:
                        //   "below" - Show URL above, QR code below (default)
                        //   "above" - Show QR code above, URL below
                        //   "replace" - Show only QR code, no URL text
                      module: "MMM-Carousel",
                      position: "bottom_bar",
                        transitionInterval: 10000,
                        showPageIndicators: true,
                        showPageControls: true,
                        ignoreModules: ["clock","newsfeed" , "MMM-JukeBox","Hello-Lucy", ],
                        mode: "slides",
                        slides: {
                          main: ["calendar", "weather",  ],
                          "Slide 2": [
                            'MMM-Pinfo',
                        "MMM-ImagesPhotos",
                          "Slide 3": ["MMM-WeeklySchedule","MMM-EasyPix",],
                		"Slide 4": ['MMM-Facts','MMM-Remote-Control',],
                    module: "MMM-WeeklySchedule",
                    header: "The Rowans, weeklys events",
                        schedule: {
                            timeslots: [ "morning", "time", "price",  "afternoon", "time", "price"],
                            lessons: {
                                mon: [ "breakfast, bacon/sausage balm", "9.30-10.30", "£2.00","?","?", "?" ],
                                tue: [ "butty van, pies, sandwich"," 12.00", "varied","?","?", "?" ],
                                wed: [ "coffee morning, toast,tea cake", "9.30-10.30", "£1.50",
                		 "knit and knatter", "2.00-4.00", " free"],
                                thu: [ "Chair yoga", "11.15-12.15", "£5.00", "dominos", " 2.00-4.00","£1.00" ],
                                fri: [ "lunchoen club,- £5", "12pm", "bingo", "2pm-4pm" ],
                               sat: [  "w/e , no staff" , "nothing" ],
                               sun: [ "w/e ,no staff", "nothing"],
                        updateInterval: 1 * 60 * 60 * 1000, // every hour
                        showNextDayAfter: "24:00"
                    module: 'MMM-Pinfo',
                      debug: true,
                      refresh: 5000,
                      itemAlign: 'left',
                      labelAlign: 'left',
                      valueAlign: 'center',
                      labelSize: null,
                      containerSize: null,
                      DEVICE: {
                        labelModel: "Model",
                        displayModel: true,
                        orderModel: 1,
                        labelSerial: 'Serial',
                        displaySerial: true,
                        orderSerial: 2
                      OS: {
                        labelOs: 'OS',
                        displayOs: true,
                        orderOs: 3
                      NETWORK: {
                        labelType: 'NET Type',
                        displayType: false,
                        orderType: 4,
                        labelIPv4: 'IPv4',
                        displayIPv4: true,
                        orderIPv4: 5,
                        labelIPv6: 'IPv6',
                        displayIPv6: false,
                        orderIPv6: 6,
                        labelMac: 'MAC',
                        displayMac: false,
                        orderMac: 7
                      RAM: {
                        labelRam: 'RAM',
                        displayRam: true,
                        orderRam: 8
                      STORAGE: {
                        labelStorage: 'Storage',
                        displayStorage: true,
                        orderStorage: 9,
                      CPU: {
                        labelType: 'CPU Type',
                        displayType: false,
                        orderType: 10,
                        labelUsage: 'CPU Usage',
                        displayUsage: true,
                        orderUsage: 11,
                        labelTemp: 'CPU Temp',
                        displayTemp: true,
                        orderTemp: 12
                      UPTIME: {
                          labelUptime: 'Uptime',
                          displayUptime: true,
                          orderUptime: 13
                      WARNING: {
                        enable: false,
                        interval: 1000 * 60 * 5,
                        check: {
                          CPU_TEMP: 65,
                          CPU_USAGE: 75,
                          RAM_USED: 80,
                          STORAGE_USED: 80
                 module: "MMM-ImagesPhotos",
                 position: "middle_center",
                  opacity: 0.9,
                  animationSpeed: 500,
                  updateInterval: 5000,
                  maxHeight: "700px",
                  maxWidth:"700px",
                  sequential: false  // process the image list randomly
                      module: "MMM-EasyPix",
                        picName: "candle2.webp",  // Enter the picture file name. You can even use a direct internet URL to an image.
                        maxWidth: "75%"       // Size picture precisely. Retains aspect ratio.
                disabled: false,
                module: "Hello-Lucy",
                //position: "top_center",
                    keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                    timeout: 15,                        // timeout listening for a command/sentence
                    standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                    microphone: "1,2",                  // run "arecord -l" card # and device # mine is "0,0"
                    sounds: ["nolly4.mp3", "llucy.mp3"],        // welcome sound at startup. Add several for a random greetings
                    confirmationSound: "ding.mp3",      // name and extension of sound file
                    //startHideAll: true,                 // All modules start as hidden EXCEPT PAGE ONE
                    // *** Page One is your default startup page *** This overrides startHideAll: true,
                   // pageOneModules: ["Hello-Lucy","MMM-EasyPix"],                     // default modules to show on page one/startup
                   // pageTwoModules: ["Hello-Lucy", "MMM-BMW-DS", "MMM-EventHorizon"], // modules to show on page two
                   // pageThreeModules: ["Hello-Lucy", "MMM-Lunartic"],                 // modules to show on page three
                   // pageFourModules: ["Hello-Lucy", "MMM-PC-Stats"],                  // modules to show on page four
                   // pageFiveModules: ["Hello-Lucy", "MMM-Searchlight"],               // modules to show on page five
                   // pageSixModules: ["Hello-Lucy", "MMM-NOAA3"],                      // modules to show on page six
                    //pageSevenModules: ["Hello-Lucy", "MMM-Recipe"],                   // modules to show on page seven
                   // pageEightModules: ["Hello-Lucy", "MMM-rfacts"],                   // modules to show on page eight
                   // pageNineModules: ["Hello-Lucy", "MMM-History"],                   // modules to show on page nine
                   // pageTenModules: ["Hello-Lucy", "MMM-HardwareMonitor"]             // modules to show on page ten
                  position: "bottom_center", // Explanation: choose any MagicMirror position
                    source: "file",                 // "file" | "USB" | "URL"
                    usbPath: "D:/soundFiles",       // Explanation: only used when source === "USB"
                    allowedExtensions: [".mp3", ".wav", ".ogg", ".m4a"],
                    pageSize: 20,                    // Explanation: number of buttons per page
                    showControlBar: true,            // NEW: use symbol bar; hides legacy Random button
                    randomButtonText: "Random Play", // Explanation: label for the legacy random button (when control bar is off)
                    stopButtonText: "Stop",          // Explanation: label for the stop button
                    infoText: "Select a number or use Random Play.",
                    continueOnHide: true,            // Explanation: true = audio continues when module hides
                    syncUsbToLocal: false,           // Explanation: optional backend copy from USB to ./soundFiles
                    autostartRandomLoop: false       // Explanation: true = auto start random loop on startup
                			module: "newsfeed",
                				feeds: [
                						title: "BBC News",
                						url: "http://feeds.bbci.co.uk/news/rss.xml"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                			module: "weather",
                				weatherProvider: "openmeteo",
                				type: "current",
                				lat: 53.48333,
                				lon: -2.51667,
                			module: "weather",
                			header: "Weather Forecast",
                				type: "forecast",
                				lat: 53.48333,
                				lon: -2.51667,
                			header: "US Holidays",
                						symbol: "calendar-check",
                						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                			header: "UK Holidays",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
                  sdetweil @tommyk
                  @tommyk the app on phone says syntax error?
                  can you open the app on a computer web browser so we can examine the browser logs?
                  once loaded(or not) open the developers window, console
                  ctrl-shift-i, then select the console tab, maybe the javascript error is listed there
                  • T Offline
                    tommyk @sdetweil
                    @sdetweil hi sam
                    how do I open app in pc browser ?
                    told you I was stupid lol
                    thanks for helping me
                    • T Offline
                      tommyk @tommyk
                      sorry . think this is it
                      (index):1 Refused to apply style from ‘http://localhost:8080/config/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                      loader.js:230 Error on loading stylesheet: config/custom.css
                      (anonymous) @ loader.js:230
                      alert.js:45 Starting module: alert
                      updatenotification.js:19 Starting module: updatenotification
                        sdetweil @tommyk
                        @tommyk the module instructions, step 5
                          sdetweil @tommyk
                          @tommyk you can get rid of these noise errors
                          Open a terminal window, and do
                          cd config
                          touch custom.css
                          Next time you start MagicMirror you won’t get those errors reported
                          If you use my/the scripted install, it does this for you
                          • T Offline
                            tommyk @sdetweil
                            thanks for all your help guys but it just wont work for me ,which is a shame
                            because it looked like just what I was looking for, but I have tried and tried
                            I uninstalled the remote control module and reinstalled it but It wont open on my phone
                            for some reason, so its beginning to look like I am stuck with the keyboard.
                            of course I will keep trying because it is doin my head in…it worked for 5 minutes and then
                            stopped.
                            I may end up starting from scratch. with a new memory card and fresh OS install
                            but it wont beat me lol
                            cheers
                              sdetweil @tommyk
                              @tommyk I installed RC, and used the default config…
                              then started mm and used my MM address and port, from the same machine
                              http://localhost:8090/remote.html
                              and from my phone
                              http://sams:8090/remote.html
                              both worked find
                              you DO have address and ipWhitelist set as “0.0.0.0”, and [], respectively, correct…
                              this allows any host (phone, laptop,… system other than MM machine) to connect to the MM server
                              otherwise the connection will be refused/blocked
                              • T Offline
                                tommyk @tommyk
                                yeah sam,
                                I am so confused, dont understand it
                                but thanks for all your help
                                  sdetweil @tommyk
                                  @tommyk mm is meant to be a closed system on the wall…
                                  no one needs to access this, as its output only… SO
                                  the default config says ONLY apps INSIDE this SAME machine can access the MM server
                                  localhost is the name of the network connection (loop back)
                                  now, it so happens one could add controls to limit JUST ONE (or a few) machines too…
                                  this is the ipWhitelist
                                  but as we’ve seen that (output only with no external access) doesn’t work for a number of use cases.
                                  remote control, my mmm-config, …
                                  SO, changing the config
                                  address means listen for incoming requests on A network adapter, wifi OR ethernet…
                                  address=“192.168.2.106” (for my desktop ethernet address)
                                  but what if you have both? or more than one…
                                  you can ONLY put ONE address there…
                                  so there is a shortcut , “0.0.0.0”, means listen on ALL adapters, regardless their address…
                                  now… i’ll just make an example, not implying anything…
                                  you built this thing, and if ANYONE in your house could get in and fiddle with the MM parts, or others,
                                  they might take the system down or something else…
                                  kids that don’t know, but LOVE to explore…!!
                                  how can i keep THEM out…
                                  we I could limit access to ONLY MY phone, laptop,… then they couldn’t get in…
                                  so you could put your phone and laptop ip addresses in the ipWhitelist:[] list
                                  and then only YOU can get into the MM app system …
                                  the RemoteControl readme, mentions this change in the config…
                                  • T Offline
                                    tommyk @sdetweil
                                    @sdetweil yes, I understand what you are saying sam
                                    but if I put 0.0.0.0 as per instructions anyone can access it, right ?
                                    so I dont get why I cant
                                    phone app says error with javascript
                                    I am at my wits end lol
                                      sdetweil @tommyk
                                      @tommyk only anyone on your home network… not anyone in the world…
                                      I don’t know on the phone app… I didnt install the app…
                                      • T Offline
                                        tommyk @sdetweil
                                        @sdetweil yep right
                                        there is only me using the mirror
                                        so when I run MM
                                        RC shows the bar code and ip address
                                        when I scan code it tries to connect to app
                                        it says… error when trying to to load javascript file
                                          sdetweil @tommyk
                                          @tommyk ok, I just added the QR to mine,
                                          what is the address shown under the QR code??
                                          mine shows
                                          http://192.168.2.106:8090/remote.html
                                          which is my server address, and port
                                          here is those values in my config.js
                                              address: "0.0.0.0",
                                              port: 8090,
                                              ipWhitelist: [],
                                          the app opens on my phone correctly
                                          same view as on my computer
                                          • T Offline
                                            tommyk @sdetweil
                                            http://192.168.1.172:8080/remote.html
