    Upgrade
    27 Posts 6 Posters 8.1k Views 6 Watching
    • mumblebajM
      @sdetweil Hi Sam. Apologies for the late reply. See below.
      mble@pi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                              \______/
      install log being saved to /home/mumble/install.log
      Updating packages ...
      Installing helper tools ...
      nvm_command is sudo n v22.21.1
      installing correct version of node and npm, please wait
      Minimum Node version: v22.21.1
      Installed Node version: v22.21.1
      No Node.js upgrade necessary.
      Minimum npm version: V10.9.4
      Installed npm version: V10.9.4
      No npm upgrade necessary.
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 509, done.
      remote: Counting objects: 100% (509/509), done.
      remote: Compressing objects: 100% (406/406), done.
      remote: Total 509 (delta 118), reused 319 (delta 93), pack-reused 0 (from 0)
      Receiving objects: 100% (509/509), 572.14 KiB | 9.54 MiB/s, done.
      Resolving deltas: 100% (118/118), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: eslint-plugin-package-json@1.5.0
      npm error notsup Not compatible with your version of node/npm: eslint-plugin-package-json@1.5.0
      npm error notsup Required: {"node":"^22.22.2 || >=24.15.0"}
      npm error notsup Actual:   {"npm":"10.9.4","node":"v22.21.1"}
      npm notice
      npm notice New major version of npm available! 10.9.4 -> 11.18.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.18.0
      npm notice To update run: npm install -g npm@11.18.0
      npm notice
      npm error A complete log of this run can be found in: /home/mumble/.npm/_logs/2026-07-04T07_32_18_929Z-debug-0.log
      Unable to install dependencies!
      I had to manually install v22.22.2 before I could install MM.
      • mumblebajM
        @sdetweil Yeah, I saw that so not sure where that 22.22.2 came from but it was there as can bee seen in the previous post. I had to install 22.22.2 and then only would MM install. Was weird.
        As for the SD card failure, I don’t know why this is but when I upgraded in April the card failed. When I upgraded now the first time the card failed so I had to setup a new one again.
          sdetweil @mumblebaj
          @mumblebaj yes, wierd… I just opened the project on github
          picked package.json on the master branch
          "engines": {
          		"node": ">=22.21.1 <23 || >=24"
          develop branch says the same
          karsten13K 1 Reply Last reply
          • karsten13K
            karsten13 @sdetweil
            the eslint-plugin-package-json dependency has this requirement but this is only a devDependency so a normal install without devDependencies should not trigger this error.
            		"node_modules/eslint-plugin-package-json": {
            			"version": "1.5.0",
            			"resolved": "https://registry.npmjs.org/eslint-plugin-package-json/-/eslint-plugin-package-json-1.5.0.tgz",
            			"integrity": "sha512-KQkAdn+7I4vn1W4Va+V8M94RhcgZBvgrxMglDqgEhJgQDRUJ9RdtrEiHoe/84oVTIlp0jiPttLYwkExdvHYhZQ==",
            			"dev": true,
            			"license": "MIT",
            			"dependencies": {
            				"@altano/repository-tools": "^2.0.1",
            				"change-case": "^5.4.4",
            				"detect-indent": "^7.0.2",
            				"detect-newline": "^4.0.1",
            				"eslint-fix-utils": "~0.4.1",
            				"eslint-json-compat-utils": "^0.2.3",
            				"jsonc-eslint-parser": "^3.1.0",
            				"package-json-validator": "^1.5.0",
            				"semver": "^7.7.3",
            				"sort-object-keys": "^2.0.0",
            				"sort-package-json": "^4.0.0"
            			"engines": {
            				"node": "^22.22.2 || >=24.15.0"
            			"peerDependencies": {
            				"@eslint/json": ">=1.0.0",
            				"eslint": ">=9.0.0"
            			"peerDependenciesMeta": {
            				"@eslint/json": {
            					"optional": true
              sdetweil @karsten13
              @karsten13 when I run
              npm run install-mm I get the dev error, even tho it specifies no dev
              > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
              npm error notsup Actual:   {"npm":"10.9.4","node":"v22.22.1"}
              npm error A complete log of this run can be found in: /home/sam/.npm/_logs/2026-07-06T17_12_27_381Z-debug-0.log
              • karsten13K
                karsten13 @sdetweil
                I wrote “should”, didn’t test it and this was my expectation to node behavior …
                As node seems to check all dependencies, we need >= 22.22.2, we can edit release notes and forum post if needed …
                S 2 Replies Last reply
                  sdetweil @karsten13
                  @karsten13 bummer… I fixed this is a prior release of something, renamed the devdependencies: entry and then there was nothing to check… what a pita
                  fixed my scripts…
                  @mumblebaj
                  can you rerun, set node back…
                  sudo n 22.21.1
                  then run upgrade again with force to allow install over the same version
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  worked for me… thanks for the heads up
                  mumblebajM 1 Reply Last reply
                    sdetweil @karsten13
                    @karsten13 fixed the release notes
                    • karsten13K
                      karsten13 @sdetweil
                      @sdetweil I did it on github, will write a test for this so that we see it prior to release
                      Reply Quote 2
                      • mumblebajM
                        @sdetweil No worries. I will check tomorrow after work and downgrade node and install again. Will advise
                          sdetweil @mumblebaj
                          @mumblebaj if you have nvm or n installed (I detect nvm, install n )
                          do this
                          sudo n
                          it might give you a list, then pick the right one 22.21.1
                          if not there, then
                          sudo n 22.21.1
                          to install it
                          mumblebajM msimon360M 2 Replies Last reply
                          • mumblebajM
                            @sdetweil Just ran it quickly and it seems like it installed 22.22.2
                            mumble@pi:~ $ sudo n
                                 copying : node/22.21.1
                               installed : v22.21.1 (with npm 10.9.4)
                            mumble@pi:~ $ node -v
                            v22.21.1
                            mumble@pi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                            update log will be in /home/mumble/MagicMirror/installers/upgrade.log
                            doing test run = false
                            Minimum Node version: v22.22.2
                            Installed Node version: v22.22.2
                            Minimum npm version: V10.9.7
                            Installed npm version: V10.9.7
                            upgrading from version 2.37.0 to 2.37.0
                            force: line 762: pm2: command not found
                            some node app still running, please shutdown those apps, maybe MagicMirror, and restart
                            here is a list of those processes
                            • msimon360M
                              msimon360 @sdetweil
                              @sdetweil Just and FYI, I just tried a fresh install and got the same issue with node.
                              marksimon@digiframe:~ $ git clone https://github.com/MagicMirrorOrg/MagicMirror.git
                              Cloning into ‘MagicMirror’…
                              remote: Enumerating objects: 31023, done.
                              remote: Counting objects: 100% (5/5), done.
                              remote: Compressing objects: 100% (3/3), done.
                              remote: Total 31023 (delta 2), reused 2 (delta 2), pack-reused 31018 (from 2)
                              Receiving objects: 100% (31023/31023), 26.41 MiB | 2.15 MiB/s, done.
                              Resolving deltas: 100% (19515/19515), done.
                              marksimon@digiframe:~ $ cd MagicMirror/
                              marksimon@digiframe:~/MagicMirror $ node --run install-mm
                              npm error notsup Required: {“node”:“^22.22.2 || >=24.15.0”}
                              npm error notsup Actual: {“npm”:“10.9.4”,“node”:“v22.21.1”}
                              Then I tried using the script and it installed node v22.22.2 and looks like it is working.
                              marksimon@digiframe:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                              update log will be in /home/marksimon/MagicMirror/installers/upgrade.log
                              Check current Node installation …
                                sdetweil @msimon360
                                yes, you didn’t use the install script you did it manually
                                • mumblebajM
                                  @sdetweil I see some major changes coming down the line for npm v12.
                                  https://github.blog/changelog/2026-07-08-npm-install-time-security-and-gat-bypass2fa-deprecation/
                                    sdetweil @mumblebaj
                                    @mumblebaj yeh, I was working on a mobile app last weekend
                                    It had npm 11 installed ( windows) and had all the acceptscript problems
                                    • mumblebajM
                                      @sdetweil Yeah, warnings come from 11.16.0+
                                        sdetweil @mumblebaj
                                        @mumblebaj on windows these were NOT warnings… I actually had to run different tasks to get the scripts allowed/approved… I hadn’t expected that in npm 11…
                                        same problem as always, some scammers leveraged the automation tools to do damage and now we all have to pay for it…
                                          MyMirror
                                          Moin (as we say here in Hamburg),
                                          I’ve just reinstalled my MM using Sam’s “Install MagicMirror²” script. The script displayed and verified Node version 22.22.1.
                                          I then ran Sam’s upgrade script, which expected Node version 22.22.2 and installed it.
                                          If that’s how it’s meant to be – everything’s fine.
                                          pimaster@MM0626:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                          update log will be in /home/pimaster/MagicMirror/installers/upgrade.log
                                          local version 2.37.0 already same as master 2.37.0
                                          moving css contents to config
                                            MyMirror @MyMirror
                                            There might also be a minor error in Sam’s restore script here.
                                            The “MMM-MyWastePickup” directory was the only one that triggered the “folder already exists” error following a fresh installation.
                                            restoring MMM-MyWastePickup
                                            module MMM-MyWastePickup contains package.json, doing npm install
                                            there were files saved for this module , restoring
                                             MMM-MyWastePickup folder already exists, skipping restore from https://github.com/jclarke0000/MMM-MyWastePickup.git
                                            restoring MMM-NearCompliments
                                            module MMM-NearCompliments contains package.json, doing npm install
