    Toothbrush integration
    34 Posts 5 Posters 29.1k Views 8 Watching
      dfuerst
      RPi3
      NODE : v6.9.2
      NPM: 3.10.9
      MagicMirror@2.0.0
        dfuerst
        scenario 1:
        scanning started…
        Toothbrush connection ALIVE atMon Jan 30 2017 17:12:15 GMT+0100 (CET)
        Toothbrush is running
        0:1
        0:2
        Toothbrush connection LOST at Mon Jan 30 2017 17:12:17 GMT+0100 (CET) was alive since Mon Jan 30 2017 17:12:15 GMT+0100 (CET)
        two input in less than 3 sec! (2 sec) => ignoring input!
        0:3
        0:4
        0:5
        endless counting
        scenario 2:
        scanning started…
        noble: unknown peripheral e0e5cffc4d8c connected!
        noble: unknown peripheral e0e5cffc4d8c disconnected!
        Toothbrush connection ALIVE atMon Jan 30 2017 17:14:25 GMT+0100 (CET)
        0:1
        0:2
        Toothbrush connection LOST at Mon Jan 30 2017 17:14:28 GMT+0100 (CET) was alive since Mon Jan 30 2017 17:14:25 GMT+0100 (CET)
        0:3
        0:4
        0:5
        0:6
        endless counting
        scenario 3:
        same result as in scenario1
        scenario 4:
        SvenSommerS 1 Reply Last reply Reply Quote 1
          dfuerst
            dfuerst
            in MM:
            scanning was started. Everything is working fine.
            noble warning: unknown handle 64 disconnected!
            , in MagicMirror
            • SvenSommerS Offline
              SvenSommer @dfuerst
              @dfuerst
              Behavior of brushTimer.js script
              According to results of the tested scenarios your brush has a different behavior than mine.
              I was expecting a reconnect when you power off your brush.
              This is very bad.
              Maybe we can find another person to test the characteristics of this behavior?
              @Shifty or @onetwankyfive: Are you able to give the testscript a run with the postet scenarios to help us out here?
              Behavior of the module within the MM-framework
              With th help of @aschulz90 I finally solved to run noble within the MM²-framework. See here for details.
              I noticed the noble warning: unknown handle 64 disconnected!- warning. It’s nothing that should bother.
              Looking for some building inspiration?
              Check out my large, thin and metal framed mirror on robstechlog.com.
              Modules released:
              MMM-GoogleAnalytics
              MMM-GrafanaChart
              MMM-GrafanaGauges
              O D 2 Replies Last reply Reply Quote 0
              • O Offline
                onetwankyfive @SvenSommer
                @SvenSommer I have a brush that is compatible and can help… are the instructions posted 5 days ago the correct ones? I can give it a whirl tonight / tomorrow morning if they are.
                  dfuerst @SvenSommer
                  @SvenSommer
                  Ok, as proven during the scenarios:
                  my brush does a connect followed by another reconnect after 3sec, which happens without user interaction.
                  so i land again at ‘hcitool con’, can your script be modified easiely to operate as intended at the very beginning (scanning for BLE brush macaddrr. every few seconds and stopping upon not finding it anymore, vanishing+resetting after a defined time period) of this topic?
                  btw i use the:
                  Oral-B Pro 6500 Smart Series Electric Toothbrush with Bluetooth Technology Powered by Braun
                  @onetwankyfive
                  i appreciate your help testing the script, please provide us with the model no/type of your brush
                    SvenSommer
                    @onetwankyfive
                    Thanks four your help! Yes, please follow these instructions of the eight steps to get the testscript running.
                    For clarification, please provide us with the output from the four scenarios:
                    1. Start the Brush; wait like 10 seconds and stop.
                    2. Start and stop within 3 seconds.
                    3. Start, wait like 10 seconds and stop. Start again within the next 10 seconds for like 5 seconds.
                    4. Start, wait like 10 seconds and stop. Start again after 40 seconds and stop whenever you like.
                    And as @dfuerst mentioned the model seems to differ in their behavior. I’m using a a Braun Oral-B PRO 6000. Do you know yours?
                    @dfuerst
                    I don’t get your point in using hcitool.
                    Do you get a reconnect after you have stopped your brush with hcitool?
                    Or is your brush connected via hcitool as long as it’s running?
                    To answer your question: If you want to use hcitool, its easier to adapt to MMM-Networkscanner by @ianperrin like you did in your first attempt.
                    But as I already mentioned, I’m sure this is even more unreliable and unaccurate.
                    But if you wanna try, I’m willing to help you.
                    Modules released:
                    MMM-GoogleAnalytics
                    MMM-GrafanaChart
                    MMM-GrafanaGauges
                      SvenSommer
                      @onetwankyfive, @dfuerst
                      As this is not an request topic any more I made a new one in the developer section. You can find it here.
                      Feel free to move over, if you want to assist the development of the module I’m creating right now.
                      Modules released:
                      MMM-GoogleAnalytics
                      MMM-GrafanaChart
                      MMM-GrafanaGauges
                      • 3 / 4
