    problème youtube MMM-ISS-Live
    2 Posts 2 Posters 33 Views 2 Watching
      manu85340
      Hello everyone. I installed the MMM-ISS-Live module by @kristjanesperanto, but the video isn’t working; I get the following message in the YouTube window: “Video unavailable; playback on other websites has been disabled by the video owner.”
      I added these lines to my config.js file, right before modules: [:
          webPreferences: {
            webviewTag: true
        electronSwitches: ["enable-unsafe-swiftshader"],
      I should mention that I don’t have any ad blockers installed.I’ve attached a screenshot.
      I’ve had this module installed for several years—initially with @mykle1 Capture ecran youtube.JPG version, and later with @kristjanesperanto .
      It stopped working due to YouTube’s restrictions, but I saw that @kristjanesperanto has brought it back to life. Could you help me get MMM-ISS-Live working? Thanks for your help.
      KristjanESPERANTOK 1 Reply Last reply
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @manu85340
        @manu85340 Hi, that message comes from YouTube itself, so your Electron settings are probably fine. Please make sure no DNS filter (e.g. Pi-hole or AdGuard Home) is active, since the video only plays for me once Pi-hole is switched off. Then try this config:
          module: "MMM-ISS-Live",
            url: "https://youtu.be/fO9e9jnhYK8"
        If you use a different url at the moment, it may be a stream whose owner disabled embedding. Does the video play with this one?
