Module MMM-pages not working after Upgrading to 2.38
I manually updated to 2,38 just now.
After re-installing all my modules and copying my cutom.css and config.js, my MagicMirror is playing up.
I use MMM-pages which seems to have stopped working.
This is my MMM-pages config{ module: "MMM-pages", config: { rotationTime: 1000 * 30, // rotate every 30 seconds modules:[ ["MMM-MyCommute","MMM-CountDown","MMM-OpenWeatherForecast","clock","MMM-PublicTransportHafas","MMM-DWD-Pollen","MMM-Fuel"], // page 1 ["MMM-CalendarExt3"], // page 2 ], fixed: [ // modules that are always shown "MMM-Wallpaper", "updatenotification", "MMM-Cursor", "MMM-page-indicator", "newsfeed", ], }, },The logfile does not really give me any clues:
[2026-10-01 20:34:50.483] [ERROR] [unknown] (node:1417) UnhandledPromiseRejectionWarning: TypeError: data is not iterable at NodeHelper.processApodData (/home/pi/MagicMirror/modules/MMM-Wallpaper/node_helper.js:624:25) at NodeHelper.processResponse (/home/pi/MagicMirror/modules/MMM-Wallpaper/node_helper.js:284:21) at /home/pi/MagicMirror/modules/MMM-Wallpaper/node_helper.js:238:16 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) (Use `electron --trace-warnings ...` to show where the warning was created) [2026-10-01 20:34:50.484] [ERROR] [unknown] (node:1417) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)Only workaround I have found is to disable MMM-CalendarExt3.
Disabling MMM-pages has no effect - same problem as if MMM-pages is enabled…
Any Idea what is happening ?It all worked perfectly on 2.37
@p1lspeda I think you are using my fork of pages… they have changed the official one since then
but the wallpaper error is in the node_helper…
can you open the developers console
ctrl-shift-i (lower case letter eye)
select the console tab
and look around for any errors, top right would be a number of those as well (pink box)
First of all: thanks for taking the time to help.
The MMM-pages module I am using is: https://github.com/edward-shen/MMM-pages
After disabling the MMM-pages module, the MMM-Wallpaper Error has vanished from my logfile.
I stated before I had disabled MMM-pages: this was incorrect, I had simply disabled page-2 within the MMM-pages config.Weirdly my the MMM-PublicTransportHafas has also failed to work under 2.38.
It just shows up as “UNDEFINED” and no logfile entry.[2026-10-01 21:32:56.041] [WARN] [apis] MMM-Fuel: Filtered stationIds list is empty [2026-10-01 21:40:10.987] [WARN] [apis] MMM-Fuel: Filtered stationIds list is empty /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT [2026-10-01 21:43:21.195] [WARN] [apis] MMM-Fuel: Filtered stationIds list is empty -
@p1lspeda I think @kristjanesperanto has worked on both those modules recently
@p1lspeda Could you share the first error shown in the browser console? Where exactly does Hafas display
UNDEFINED, and isstationNameset?Which versions of MMM-pages, MMM-PublicTransportHafas and Node.js are you running?
Which MMM-Wallpaper module are you using: kolbyjack’s or jupadin’s?
@KristjanESPERANTO
thanks to you too for taking the time to help.
Let me try and answer your questions.
According to the changelog, I am running version 1.5.1 of MMM-pages## [1.5.1](https://github.com/edward-shen/MMM-pages/compare/v1.5.0...v1.5.1) (2026-08-12)According to the changelog, I am runnung version 4.5.2 of MMM-PublicTransportHafas
## [4.5.2](https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas/compare/v4.5.1...v4.5.2) (2026-08-31)Node.js:
this is weird - the install.log from sam’s install/upgrade script states v. 22.22.2Node currently installed. Checking version number. Minimum Node version: v22.22.2 Installed Node version: v22.22.2 No Node.js upgrade necessary.a nodejs -v shows something entirely different
pi@magicmirror:~ $ date Fri 2 Oct 06:21:37 CEST 2026 pi@magicmirror:~ $ nodejs -v v20.19.2As for the MMM-Wallpaper: I am using kolbyjack’s version
stationName is set
... stationID: "3029051", stationName: "Höfchen/Listmann", // Replace with your station name! ...The UNDEFINED is shown on my screen
I think this is the first error I could find in the console browser
Edit:
I have updated nodejs to v24 and I have updated MMM-Wallpaper (I noticed kolbyjack had updated his git 3hrs ago).
My MagicMirror-error.log does not show any errors/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT [2026-10-02 07:00:27.480] [WARN] [apis] MMM-Fuel: Filtered stationIds list is empty -
I have done some more debugging and I have 2 issues:
1st Issue is MMM-PublicTransportHafas: I have just updated to https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas and the issue has been resolved.2nd issue was with MMM-pages:
After starting MagicMirror, my mirror would switch directly to the 2nd page.
The automatic switching between page 0 and page 1 stopped working
Only after I had manually switched to my 2nd page (clicking on the indicator provided by MMM-pages-indicator), the automatic switch started working and my Mirror is almost back up and running.It seems as if I have identified MMM-pages as the culprit.
@p1lspeda Thanks for the update! Could you share your current MMM-pages config and the console messages from startup until you switch pages manually?
@KristjanESPERANTO
Here goes:
my MMM-pages config:{ module: "MMM-pages", config: { //rotationTime: 1000 * 30, // rotate every 30 seconds timings: { default: 30000, 0: 30000, }, modules: [ ["MMM-MyCommute","MMM-CountDown","MMM-OpenWeatherForecast","clock","MMM-PublicTransportHafas","MMM-DWD-Pollen","MMM-Fuel"], // page 1 //["clock"], ["MMM-CalendarExt3"], // page 2 ], fixed: [ // modules that are always shown "MMM-Wallpaper", "updatenotification", "MMM-Cursor", "MMM-page-indicator", "newsfeed" ], }, },And while I was trying to get the info/errors from the console browser - as it always happens - my MagicMirror started up without any issues.
No idea what has changed - but it is working.
Btw: while I was writing this reply, I got an update notification for MMM-pages. I updated the module and everything seems to be working fine.Thanks for your patience and help
["MMM-MyCommute","MMM-CountDown","MMM-OpenWeatherForecast","clock","MMM-PublicTransportHafas","MMM-DWD-Pollen","MMM-Fuel"], // page 1 //["clock"], ["MMM-CalendarExt3"], // page 2just for a side discussion, there is another way to config pages
using a page name like “page1” (you had this comment at the end // page 1)
and then adding the classes:“page1”, to all the modules you want on page1…I always had trouble remembering where this module was when I was looking at its specific config, had to scroll back to pages config, lost where I was in config, then have to find it again… repeat too many times
and the page names can be anything
mom, dad, joey, mary, stocks, weather, whatever
i call the fixed section , “fixed”
then the page def looks cleanand the modules tell me where they are… never have to look back and forth , where was this again?
so your def would have been
{ module: "MMM-pages", config: { //rotationTime: 1000 * 30, // rotate every 30 seconds timings: { default: 30000, 0: 30000, }, modules: [ ["page1", "page2" ], fixed: [ "fixed" ] // modules that are always shown }, },then on the def for MMM-CalendarExt3
{ module:"MMM-Calendar-Ext3", position: ....., classes:"page2", ... config: { ext3 config parms } }if you want the same module on multiple pages, just add the space separated list of page names
classes:"page2 page5", // in any order
