    Send Notification from one module to another module
    6 Posts 4 Posters 5.2k Views 4 Watching
    • E Offline
      edubey
      I have one module which collects user data from somewhere. Once the data is collected how can I send notification to another module.
      I can use MM.getModules().
      But then How can I send notification.
      In Simple terms: Notify module A from module B
      Thanks in advance
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @edubey
        @edubey
        modula
        this.sendNotification("NEW_STUFF", {foo: "bar"});
        modulb
        notificationReceived: function(notification, payload, sender){
          if(notification === "NEW_STUFF" && sender === "modula"){
            //handle the payload: {foo: "bar"}
        E SvenSommerS 3 Replies Last reply Reply Quote 3
        • E Offline
          edubey @strawberry 3.141
          @strawberry-3.141
          Thanks, i got it
          • E Offline
            @strawberry-3.141
            Okay, so its more of a broadcast to all modules, not to any specific…right?
            • yawnsY Offline
              yawns Moderator @edubey
              @edubey said in Send Notification from one module to another module:
              @strawberry-3.141
              That’s right. This command sends out a broadcast to all modules. As long as you use a broadcast notification no other module reacts on you don’t have any trouble.
              • SvenSommerS Offline
                SvenSommer @strawberry 3.141
                It seemed the sender is now a object not only a string with several properties. Therefore this code snippet has changed a little by sender to sender.name:
                  if(notification === "NEW_STUFF" && sender.name === "modula"){
                Looking for some building inspiration?
                Check out my large, thin and metal framed mirror on robstechlog.com.
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
