    MMM-Voice-Control - only black screen after installation.
    9 Posts 2 Posters 4.3k Views 2 Watching
    • Q Offline
      Q14siX
      After I installed the module, the display remains completely black when the MM2 started.
      Can someone help me?
      npm start -dev
      magicmirror@2.1.0 start /home/pi/MagicMirror
      electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config …
      Loading module helpers …
      No helper found for module: MMM-Voice-Control.
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Connecting socket for: MMM-DWD-WarnWeather
      MMM-DWD-WarnWeather helper started…
      Starting module: newsfeed
      Connecting socket for: MMM-WatchDog
      Staring module helper: MMM-WatchDog
      Connecting socket for: MMM-FRITZ-Box-Callmonitor
      Starting module: MMM-FRITZ-Box-Callmonitor
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-Admin-Interface
      Starting node helper for: MMM-Admin-Interface
      Connecting socket for: MMM-Fuel
      Starting module: MMM-Fuel
      Sockets connected & modules started …
      Launching application.
      /home/pi/.pm2/logs/mm-error-0.log
      without content
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Q14siX
        @Q14siX can you start the mirror with npm start dev and check if you can spot an error in the console there? the log you posted looks fine cant see an issue here
        • Q Offline
          Q14siX
          No changes…
          npm start dev
          electron js/electron.js “dev”
          Loading config …
          Server started …
          Connecting socket for: MMM-SystemStats
            @Q14siX you are posting the terminal log but when you start with npm start dev you have a window on the side which has also a console log
            • Q Offline
              Q14siX
              Initializing MagicMirror.
              translator.js:182 Loading core translation file: translations/de.json
              translator.js:204 Loading core translation fallback file: translations/en.json
              loader.js:182 Load script: modules/MMM-Voice-Control//MMM-Voice-Control.js
              module.js:415 Module registered: MMM-Voice-Control
              loader.js:152 Bootstrapping module: MMM-Voice-Control
              loader.js:182 Load script: modules/MMM-Voice-Control//node_modules/annyang/annyang.js
              annyang.js Failed to load resource: the server responded with a status of 404 (Not Found)
                @Q14siX did you run npm install in the module directory?
                • Q Offline
                  Q14siX
                  Yes, already several times.
                  But:
                  npm install
                  npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                  npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
                  npm WARN modules No description
                  npm WARN modules No repository field.
                  npm WARN modules No README data
                  npm WARN modules No license field.
                  And:
                  ~/MagicMirror/modules/MMM-Voice-Control $ npm install
                  Magic-Mirror-Module-Voice-Control@1.0.0 /home/pi/MagicMirror/modules/MMM-Voice-Control
                  └── annyang@2.6.0
                    @Q14siX the second should fix your issue
                    • Q Offline
                      Q14siX
                      In the module is an error.
                      The annyang.js file must be manually copied from the directory “dist” to the directory of the module.
