MMM-Voice-Control - only black screen after installation.
@Q14siX you are posting the terminal log but when you start with npm start dev you have a window on the side which has also a console log
Initializing MagicMirror.
translator.js:182 Loading core translation file: translations/de.json
translator.js:204 Loading core translation fallback file: translations/en.json
loader.js:182 Load script: modules/MMM-Voice-Control//MMM-Voice-Control.js
module.js:415 Module registered: MMM-Voice-Control
loader.js:152 Bootstrapping module: MMM-Voice-Control
loader.js:182 Load script: modules/MMM-Voice-Control//node_modules/annyang/annyang.js
annyang.js Failed to load resource: the server responded with a status of 404 (Not Found) -
@Q14siX did you run
npm installin the module directory? -
Yes, already several times.
But:
npm install
npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
npm WARN modules No description
npm WARN modules No repository field.
npm WARN modules No README data
npm WARN modules No license field.And:
~/MagicMirror/modules/MMM-Voice-Control $ npm install
Magic-Mirror-Module-Voice-Control@1.0.0 /home/pi/MagicMirror/modules/MMM-Voice-Control
└── annyang@2.6.0 -
@Q14siX the second should fix your issue
In the module is an error.
The annyang.js file must be manually copied from the directory “dist” to the directory of the module.
