    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 3.1m Views 60 Watching
    • caracasnetC
      caracasnet
      Hi, as usual i read late the forum. If in any case you stay with a mirror “cold” or make again more for you just let me know. I am in Leipzig i could pick up. In any case that works for you my ideal size of mirror will be 367mm x 1572mm just to try. Thanks
      • G
        Goldjunge_Chriz
        Here is the final list.
        # username sizes (m) area (m²) location additional comments pickup/delivery confirmed
        01 yawns 0.765 * 0.765 0.59 Germany, Cologne polished edges delivery ✓
        02 gustav1976 0.6 * 1.8 1.08 Germany, Koblenz polished edges delivery ✓
        03 gustav1976 1.0 * 1.2 1.20 Germany, Koblenz polished edges delivery ✓
        04 gustav1976 1.4 * 0.8 1.12 Germany, Koblenz polished edges delivery ✓
        05 lolobyte 0.8 * 0.6 0.48 Germany, Heilbronn polished edges pickup in Schweinfurt ✓
        06 lolobyte 0.8 * 0.6 0.48 Germany, Heilbronn polished edges pickup in Schweinfurt ✓
        07 lolobyte 0.4 * 1 0,4 Germany, Heilbronn polished edges pickup in Schweinfurt ✓
        08 Jeff 0.8 * 0.5 0.4 Germany, Karlsruhe polished edges pickup in Schweinfurt ✓
        09 Ashidian 0.69 * 0.435 0.3 (pay 0.4) Germany, Rostock polished edges delivery ✓
        10 mcg 0.5 * 1.0 0.5 Germany, Ludwigshafen polished edges pickup in Heilbronn ✓
        11 cfenner 0.665 * 0.665 0.442 Germany, Mannheim polished edges pickup in Heilbronn from member mcg ✓
        12 sero 0.5 * 0.4 0.2 (pay 0.4) Germany, Stuttgart polished edges pickup in Heilbronn ✓
        13 Deepgear 0.46 * 1.5 0.69 Germany, Pforzheim polished edges pickup in Schweinfurt ✓
        14 Binog 0.8 * 0.5 0.4 Germany, Cologne polished edges delivery ✓
        15 yaye 0.5 * 0.4 0.2 (pay 0.4) Germany, Stuttgart polished edges pickup in Heilbronn ✓
        16 Ali Baba 0.4 * 1.0 0.4 Germany, Hoyerswerda polished edges delivery ✓
        17 mantha 0.563 * 0.97 0.55 Germany, Ulm polished edges pickup in Heilbronn ✓
        18 fox 0.553 * 0.323 0.18 (pay 0.4) Germany, Schwabmünchen polished edges delivery ✓
        19 wiloo 0.7 * 0.5 0.35 (pay 0.4) Germany, Traunstein polished edges delivery ✓
        20 ace0024 1.7 * 0.45 0.76 Germany, Neuried near Munich polished edges delivery ✓
        21 mire 0.8 * 1.0 0.8 Germany, Ludwigsburg polished edges pickup in Heilbronn ✓
        22 selarp 0.55 * 0.8 0.44 Schweden polished edges delivery ✓
        23 jupilde 0.6 * 0.9 0.54 Germany, Stuttgart polished edges pickup in Heilbronn ✓
        24 ZombieDE 0.36 * 1.0 0.36 (pay 0,4) Germany, Passau polished edges delivery ✓
        25 olexs 0.63 * 0,379 0.239 (pay 0,4) Germany, Bad Homburg polished edges pickup in Schweinfurt from member woody ✓
        26 ferby09 0.6 * 1.0 0.6 Germany, Berlin polished edges delivery ✓
        27 oberschlingel 0.54 * 0.8 0.43 Germany, Berlin polished edges delivery ✓
        28 tomster 1 * 0.8 0.8 Germany, Munich polished edges delivery ✓
        29 tomster 0.74 * 0.54 0.4 Germany, Munich polished edges delivery ✓
        30 webmasterrn 0.4 * 0.5 0.2 (pay 0.4) Germany, Esslingen polished edges pickup in Heilbronn ✓
        31 miek 0.6 * 0.8 0.48 Austria, Vienna polished edges delivery ✓
        32 todro 0.5 * 0.8 0.4 Germany, Leutenbach polished edges pickup in Heilbronn ✓
        33 todro 0.675 * 0.317 0,214 (pay 0.4) Germany, Leutenbach polished edges pickup in Heilbronn ✓
        34 Woody 0.84 * 0.48 0.4 Germany, Frankfurt polished edges pickup in Schweinfurt ✓
        35 trekky 0.5 * 0.5 0.25 (pay 0.4) Germany, Esslingen polished edges pickup in Heilbronn from member webmasterrn ✓
        Total 18.782 (17.275)
        M 1 Reply Last reply
          bleusswissbless
          hi !
          I just discover - as a new member - this topic. I wondering if it’s still possible to join this group command ? My need is about 0,4m² and a delivery in France. Is it possible yet, if yes, how much it will cost ?
          J 1 Reply Last reply
            jseutens @bleusswissbless
            @bleusswissbless This order is sadly enough closed , i’m just waiting for all the nice pictures when they all build their mirror.
            • T
              tomster
              @Goldjunge_Chriz
              As you mentioned in the OP the mirror to some point is designed as a sun protection glass. Do you have any info on the transmittance ratio of IR wavelength? I plan on using my RasPi’s camera for face recognition and now assume that these design characteristics would not allow me to put the camera behind the mirror. Can you clarify on this?
              Thx in advance & thx again even more for putting up this bulk order!
              Regards,
              Tom
              G 1 Reply Last reply
              • G
                Goldjunge_Chriz @tomster
                @tomster
                It is only a very thin layer on it to improve the color spectrum of the reflection. This layer is located on the outward side. So I do not believe that there should be a problem, since it is not pure sun protection glass ;) There is no value, since the mirror was not specifically examined for it. It is usually also not a criterion for such a mirror, so there was also no need for a test ;)
                  muellerl @Goldjunge_Chriz
                  @Goldjunge_Chriz said in Two way mirror order in Germany:
                    muellerl @muellerl
                    @muellerl
                    würde auch gerne einen Two way mirror bei Dir bestellen.
                    Wie geht denn das. Bzw. wie kann ich den bei Dir bestellen ?
                    yawnsY 1 Reply Last reply
                    • yawnsY
                      yawns Moderator @muellerl
                      @muellerl said in Two way mirror order in Germany:
                      @muellerl
                      Hi, since this forum is international please write in english. Unfortunately the current order is closed, there is no way to jump in. Sorry.
                      lolobyteL 1 Reply Last reply
                      • lolobyteL
                        lolobyte @yawns
                        @yawns
                        here is also a french connection group.
                        They already have to write in English!
                        • A
                          Ashidian
                          @Goldjunge_Chriz how about an update? I paid a week ago. How about the others, how many haven’t paid yet, when do you think the payments are complete so you can order the mirrors from the supplier?
                          • G
                            Goldjunge_Chriz @Ashidian
                            @Ashidian
                            Currently a total of 4 payments are still missing. 2 of which are still missing completely and the other two were not in the sum completely :) the order I have already prepared on my table lie. As soon as all payments have arrived, I’ll send the order straight out :) I think it will be the latest Wednesday. I will keep you up to date ;)
                            Reply Quote 2
                              sero
                              Go go go guys! :)
                              • lolobyteL
                                lolobyte
                                Late but done now.
                                  sharky
                                  Hallo Goldjunge, magst Du mal die genaue Bezeichnung des Spiegelglases nennen, falls ich es überlesen habe.
                                  Würde mich gern belesen oder auch gucken, ob ich es selbst irgendwo her bekomme. Das wäre traumhaft.
                                  Besten Dank und liebe Grüße,
                                  Sharky
                                  • foxF
                                    fox
                                    Payment now complete?
                                    I think the others have to wait until the turtles come off :airplane: :grinning:
                                    Issues With MMM-WatchDog known?
                                    https://forum.magicmirror.builders/post/29827
                                    Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                    • G
                                      Goldjunge_Chriz @sharky
                                      @sharky said in [ORDER CLOSED] Two way mirror order in Germany:
                                      Sharky
                                      Unfortunately, I can not name the manufacturer, because he wants to avoid individual requests from individuals which cause a high administrative effort. If I would tell the manufacturer he would get daily mails of people who want only one mirror and I get anger ;)
                                      A small note by the way: Since this is an English-speaking forum, please write also in English.
                                      • G
                                        Goldjunge_Chriz @fox
                                        @fox
                                        We got it soon :) Now it is missing only one complete transfer and two are not complete. (Only the mirror value paid, polished edges and/or shipping costs forgotten)
                                        • G
                                          Goldjunge_Chriz
                                          Good news guys :) the payments are now all arrived and complete. I will make the order tomorrow morning immediately :) It will then take about 3 weeks until the mirrors arrive at me;)
                                          A big thank you goes to @ferby09, @Jeff and @sero who give a small tip.
                                          And a very special thank you goes to @webmasterrm , who gave a bigger tip. Very nice gest of you, thanks :)
                                          F 1 Reply Last reply
                                          Reply Quote 3
                                          • F
                                            ferby09 @Goldjunge_Chriz
                                            @Goldjunge_Chriz The real tip follows when I’ve build my mirror and am satisfied with the final product. :P
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 27
                                            • 28
                                            • 21 / 28
