    How HOT Does it Get?
    29 Posts 9 Posters 25.3k Views 8 Watching
    • O
      ottobot @AAPS
      @AAPS just checked my pi zero after running for a few days straight. 51.4c that’s with no fan, no heatsink, and the frame around the mirror covering it.
      • O
        ottobot @Mykle1
        @Mykle1 Fing is a great app to find your pi on your network as well. They make it for android and ios.
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @AAPS
          @AAPS said in How HOT Does it Get?:
          You just telling me this is helpful. I could maybe set a static IP address if I suddenly start feeling less lazy. :thinking:
          I did some poking around and discovered an easier way to set a static IP for the Pi, although it’s not permanent. I have FIOS, and within the router interface you can set a “static lease” for any of the devices on your network. Easy as Pi. Took less than a minute
          A 2 Replies Last reply
          • Hein-JanH
            Hein-Jan
            Mine was running at aprox 70°C. My mirror is vertically orientated. The Pi is in a casing but al the sides of the casing have been removed. I have fitted the CPU and the memory with heatsinks.
            The Pi was mounted near the top of my mirror (I could slide it under the piece of board that is being used to mount the mirror on the wall.) My mirror case does have some ventilation holes at the top, but no fan.
            Being slightly worried about the 70°C (I expect it to go up to 80°C in summer) I decided to change the postion of the Pi in my mirror from the top of the frame to the bottom, so it was no longer in the monitors pre-heated air.
            At the bottom of the case my Pi is now running at aprox 55°C. A drop of 15°C by simply relocating within the mirror frame.
            I’ll take that over running a fan for my mirror.
            • A
              AAPS @Mykle1
              @Mykle1 Can you just do that on the router’s webpage?
              Mykle1M 1 Reply Last reply
              • Mykle1M
                You sure can. Here, I’ll save you some searching around:
                Sign in to Verizon router. Click Advanced tab (almost top right). Click yes to proceed. Click IP Address Distribution bottom right. Click Connection List almost in the middle. On the left, find the device that you want to assign a static lease IP address to. On the right, in the Action column, click the Edit icon. Tick the Static Lease Type box. Click Apply. That is now a static IP address. GO back one page and look in the Lease Type column. It will show you the Static designation.
                Peace
                • A
                  AAPS
                  Thank You!!! :grinning: :thumbsup_tone3:
                  • A
                    AAPS @Mykle1
                    @Mykle1 said in How HOT Does it Get?:
                    How long does the new static IP address last if it isn’t permanent?
                    @1m2 By the way, what kind of case is that, and where could I get one for myself?
                    • Mykle1M
                      I tried to find out how long the lease lasts for but I was unable to discover that information. The word “temporary” appeared somewhere when I was doing the initial search for assigning static IP’s. That is why I noted that the change wasn’t permanent.
                      Worst case scenario if the leases expire: Go back to that one page in your router. A few clicks. Leases renewed.
                      Best case scenario: They don’t expire (or last a very long time)
                      A 1 Reply Last reply
                      • A
                        AAPS @Mykle1
                        @Mykle1 Nice! I’ll figure it out.
