    How HOT Does it Get?
    29 Posts 9 Posters 25.3k Views 8 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @AAPS
      @AAPS said in How HOT Does it Get?:
      That’s great. My new problem now is figuring out how to make it wake up. How did you do it?
      It’s no good connecting a mouse and/or keyboard to the mirror to wake it up. It takes the “magic” away, you know?
      I had this problem as well. I decided to disable the screensaver. IMHO this is easiest done by installing xscreensaver (you don’t have to do any coding). Once installed, you go to the desktop of your GUI on the Pi, click on the raspberry icon, upper left, select preferences, select screensaver and disable the screensaver. Its one of the button choices. Now you can use the MMM-Remote-Control module to turn your monitor on and off, modules on and off, etc. It’s fabulous. Works from any computer on the same network and even works from your cell phone.
      You can thank me later. ;-)
      • A
        AAPS
        I’ll thank you right now, and the remote control thing is pretty much what I have been doing, but I want motion detection because the ip adress of my pi changes constantly, so I run the risk of turning my display off and not knowing the site I need to go on to turn it back on. Either way I am about to buy a pir sensor for five bucks and play with it, so whatever I manage to do will have to work for me. ☺
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @AAPS
          My ip address changes too but I can find it easily by signing in to my router. You can set a static ip address for your Pi. I tried but got frustrated and gave it up. I’ll try again when my patience isn’t so low.
          I’ve also been toying with the idea of a PIR sensor or webcam but I’m still just trying to perfect my setup before diving into that. Good luck in your venture. I wish I could have been more help
          O 1 Reply Last reply
          • A
            AAPS
            You just telling me this is helpful. I could maybe set a static IP address if I suddenly start feeling less lazy. :thinking:
            • O
              ottobot @AAPS
              @AAPS just checked my pi zero after running for a few days straight. 51.4c that’s with no fan, no heatsink, and the frame around the mirror covering it.
              • O
                ottobot @Mykle1
                @Mykle1 Fing is a great app to find your pi on your network as well. They make it for android and ios.
                • Mykle1M
                  I did some poking around and discovered an easier way to set a static IP for the Pi, although it’s not permanent. I have FIOS, and within the router interface you can set a “static lease” for any of the devices on your network. Easy as Pi. Took less than a minute
                  A 2 Replies Last reply
                  • Hein-JanH
                    Hein-Jan
                    Mine was running at aprox 70°C. My mirror is vertically orientated. The Pi is in a casing but al the sides of the casing have been removed. I have fitted the CPU and the memory with heatsinks.
                    The Pi was mounted near the top of my mirror (I could slide it under the piece of board that is being used to mount the mirror on the wall.) My mirror case does have some ventilation holes at the top, but no fan.
                    Being slightly worried about the 70°C (I expect it to go up to 80°C in summer) I decided to change the postion of the Pi in my mirror from the top of the frame to the bottom, so it was no longer in the monitors pre-heated air.
                    At the bottom of the case my Pi is now running at aprox 55°C. A drop of 15°C by simply relocating within the mirror frame.
                    I’ll take that over running a fan for my mirror.
                    • A
                      AAPS @Mykle1
                      @Mykle1 Can you just do that on the router’s webpage?
                      • Mykle1M
                        You sure can. Here, I’ll save you some searching around:
                        Sign in to Verizon router. Click Advanced tab (almost top right). Click yes to proceed. Click IP Address Distribution bottom right. Click Connection List almost in the middle. On the left, find the device that you want to assign a static lease IP address to. On the right, in the Action column, click the Edit icon. Tick the Static Lease Type box. Click Apply. That is now a static IP address. GO back one page and look in the Lease Type column. It will show you the Static designation.
                        Peace
                        • A
                          AAPS
                          Thank You!!! :grinning: :thumbsup_tone3:
                          • A
                            AAPS @Mykle1
                            @Mykle1 said in How HOT Does it Get?:
                            How long does the new static IP address last if it isn’t permanent?
                            @1m2 By the way, what kind of case is that, and where could I get one for myself?
                            • Mykle1M
                              I tried to find out how long the lease lasts for but I was unable to discover that information. The word “temporary” appeared somewhere when I was doing the initial search for assigning static IP’s. That is why I noted that the change wasn’t permanent.
                              Worst case scenario if the leases expire: Go back to that one page in your router. A few clicks. Leases renewed.
                              Best case scenario: They don’t expire (or last a very long time)
                              A 1 Reply Last reply
                              • A
                                AAPS @Mykle1
                                @Mykle1 Nice! I’ll figure it out.
