    MMM-TrafficCal - Dynamically display commutes based on calendar entries
    13 Posts 6 Posters 11.5k Views 7 Watching
      chewitt86 @RedNax
      @RedNax This is potentially a very cool module, I’m still working on incorporating it into my mirror (I’m not a coder so takes me a while) but I did have a question as to whether or not I could change the module to have a fixed destination rather than to look up from a calendar?
      RedNaxR 1 Reply Last reply
      • RedNaxR
        RedNax Module Developer @chewitt86
        @chewitt86 There already is a static version of this (in fact, i hijacked it to make mine :) ) https://github.com/SamLewis0602/MMM-Traffic
        C 1 Reply Last reply
        • G
          gismo2006
          Hi, some days ago I try to use your module. I installed everything like you write at your readme file. I create a new calender. But It didn’t work. After some try, I read that it use a new function in the calender module. So I try to change to the develop tree. But after that my magic mirror didn’t start again. So I copy a previous version I have saved and the mirror started normally.
          Greets gismo
            chewitt86 @RedNax
            @RedNax Brilliant! thanks very much!
              A Former User
              A fantastic enhancement on the origional by the looks of it, thanks for taking the time RedNax.
              Question, all installed and configured.
              Apart from https://www.npmjs.com/package/request (npm install request)
              Any recommended method for installation on a mac?
                shashank @Guest
                @wjdw87 hi, I installed this module, i cannot see any display on MM with regards to TrafficCalc, may i know the steps how to enter info on a gmail calander for MYTRIP and Destination
                  Bobby @RedNax
                  @RedNax I have some problems with this module. How should be a correct calendar entry? I cannot see anything on the mirror. This ist the only thing in the log:
                  received TRAFFIC_COMMUTE
                  TRAFFIC URLS:
                  TRAFFIC URLS:
                  TRAFFIC URLS:
                  TRAFFIC URLS:
                  Bobby
                  • RedNaxR
                    RedNax Module Developer @Bobby
                    @Bobby
                    Hi Bobby,
                    Your config should be something like this:
                    		module: "MMM-TrafficCal",
                    		classes: "dimmed medium",
                    			api_key: "API KEY to the calendar holding your trip planning, could optionally be a seperate one",
                    			origin: "Damrak 1, Amsterdam", // Your default trip origin. Must be an unambiguous google resolvable adress
                    			tripkey: "MYTRIPS", // A keyword to identify a TrafficCal calendar entry
                    			chinangeColor: true,
                    			limitYellow: 25,
                    			limitRed: 50,
                    			traffic_model: "pessimistic",
                    			interval: 120000
                        An example of an entry:
                    0_1486889620335_upload-cccf478f-b636-4ff2-962e-f4491bda83f8
                    You’ll have to run a calendar module with the MYTRIPS calendar entries in it. You can optionally hide it using the remote control module.
                    		header: "Trips",
                    		fetchInterval: 60000,
                    			maximumNumberOfDays: 1,
                    					symbol: "calendar-check-o ",
                    					url: "https://calendar.google.com/calendar/ical/YOUR URL TO THE TRIPS CALENDAR",
                    			titleReplace: {
                    				"De verjaardag van ": "",
                    				"'s birthday": ""
                    Good luck!
                    B S 2 Replies Last reply
                      Bobby @RedNax
                      @RedNax Thx, for your answer. I have solved my problem, my destination has German “umlaute (ä, ü, ö)” in name. Thus the google request did not clear. This is not utf-8. An other question is, what does ist mean “ipv”?
                       mycommute.commute + ' ipv ' + mycommute.noTraffic
                      Thanks fpr your help
                      Bobby
                      • RedNaxR
                        @Bobby Whoops, thats a Dutch abbreveation of ‘instead of’… Should really make that a config item… :S
                        • RedNaxR
                          RedNax Module Developer @RedNax
                          @RedNax New version has these strings as config items…
                            shashank @RedNax
                            @RedNax hi, i created the Calendar and able to view the MYTRIP details but TrafficCalc is not working
                            how and where to get this ApiKey
                            api_key: “API KEY to the calendar holding your trip planning, could optionally be a seperate one”,
