    MMM-TrafficCal - Dynamically display commutes based on calendar entries
    13 Posts 6 Posters 11.5k Views 7 Watching
    • G
      gismo2006
      Hi, some days ago I try to use your module. I installed everything like you write at your readme file. I create a new calender. But It didn’t work. After some try, I read that it use a new function in the calender module. So I try to change to the develop tree. But after that my magic mirror didn’t start again. So I copy a previous version I have saved and the mirror started normally.
      Greets gismo
        chewitt86 @RedNax
        @RedNax Brilliant! thanks very much!
          A Former User
          A fantastic enhancement on the origional by the looks of it, thanks for taking the time RedNax.
          Question, all installed and configured.
          Apart from https://www.npmjs.com/package/request (npm install request)
          Any recommended method for installation on a mac?
            shashank @Guest
            @wjdw87 hi, I installed this module, i cannot see any display on MM with regards to TrafficCalc, may i know the steps how to enter info on a gmail calander for MYTRIP and Destination
              Bobby @RedNax
              @RedNax I have some problems with this module. How should be a correct calendar entry? I cannot see anything on the mirror. This ist the only thing in the log:
              received TRAFFIC_COMMUTE
              TRAFFIC URLS:
              TRAFFIC URLS:
              TRAFFIC URLS:
              TRAFFIC URLS:
              Bobby
              RedNaxR 1 Reply Last reply
              • RedNaxR
                RedNax Module Developer @Bobby
                @Bobby
                Hi Bobby,
                Your config should be something like this:
                		module: "MMM-TrafficCal",
                		classes: "dimmed medium",
                			api_key: "API KEY to the calendar holding your trip planning, could optionally be a seperate one",
                			origin: "Damrak 1, Amsterdam", // Your default trip origin. Must be an unambiguous google resolvable adress
                			tripkey: "MYTRIPS", // A keyword to identify a TrafficCal calendar entry
                			chinangeColor: true,
                			limitYellow: 25,
                			limitRed: 50,
                			traffic_model: "pessimistic",
                			interval: 120000
                    An example of an entry:
                0_1486889620335_upload-cccf478f-b636-4ff2-962e-f4491bda83f8
                You’ll have to run a calendar module with the MYTRIPS calendar entries in it. You can optionally hide it using the remote control module.
                		header: "Trips",
                		fetchInterval: 60000,
                			maximumNumberOfDays: 1,
                					symbol: "calendar-check-o ",
                					url: "https://calendar.google.com/calendar/ical/YOUR URL TO THE TRIPS CALENDAR",
                			titleReplace: {
                				"De verjaardag van ": "",
                				"'s birthday": ""
                Good luck!
                B S 2 Replies Last reply
                  Bobby @RedNax
                  @RedNax Thx, for your answer. I have solved my problem, my destination has German “umlaute (ä, ü, ö)” in name. Thus the google request did not clear. This is not utf-8. An other question is, what does ist mean “ipv”?
                   mycommute.commute + ' ipv ' + mycommute.noTraffic
                  Thanks fpr your help
                  Bobby
                  • RedNaxR
                    @Bobby Whoops, thats a Dutch abbreveation of ‘instead of’… Should really make that a config item… :S
                    • RedNaxR
                      RedNax Module Developer @RedNax
                      @RedNax New version has these strings as config items…
                        shashank @RedNax
                        @RedNax hi, i created the Calendar and able to view the MYTRIP details but TrafficCalc is not working
                        how and where to get this ApiKey
                        api_key: “API KEY to the calendar holding your trip planning, could optionally be a seperate one”,
