    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 164.4k Views 20 Watching
      anatius
      I am trying to dim my mirror at nighttime - on weekdays between 10PM and 7AM, on weekends between 10Pm and 8AM. However, the below code does not do the trick - where is my mistake?
      			module: 'MMM-ModuleScheduler',
      				global_schedule: [
      					{from: '0 7 * * 1-5', to: '0 20 * * 1-5', dimLevel: '30'},
      					{from: '0 8 * * 0,6', to: '0 20 * * 0,6', dimLevel: '30'},
      • I Offline
        ianperrin @anatius
        @anatius The config looks okay, can you check the output of the log pm2 logs mm once you have started MM2 and viewed it in a browser then post the results here?
        It should look something like:
        MMM-ModuleScheduler received INITIALISE_SCHEDULER
        MMM-ModuleScheduler is setting the config
        MMM-ModuleScheduler is removing all scheduled jobs
        MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
        MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
        MMM-ModuleScheduler is creating a global schedule for all modules using "0 7 * * 1-5" and "0 20 * * 1-5" with dim level 30
        MMM-ModuleScheduler is dimming all modules
        MMM-ModuleScheduler has created the global schedule for all modules
        MMM-ModuleScheduler will next show all modules at Mon Dec 19 2016 07:00:00 GMT+0000 (UTC)
        MMM-ModuleScheduler will next dim all modules at Mon Dec 19 2016 20:00:00 GMT+0000 (UTC)
        MMM-ModuleScheduler is creating a global schedule for all modules using "0 8 * * 0,6" and "0 20 * * 0,6" with dim level 30
        MMM-ModuleScheduler will next show all modules at Sat Dec 24 2016 08:00:00 GMT+0000 (UTC)
        MMM-ModuleScheduler will next dim all modules at Sat Dec 24 2016 20:00:00 GMT+0000 (UTC)
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          anatius @ianperrin
          @ianperrin
          Hi Ian,
          Below is the relevant output of the log (error log is empty). Note that now (Monday at 3 PM) all modules are dimmed though they should not be…
          MMM-ModuleScheduler will next show all modules at Tue Dec 20 2016 07:00:00 GMT+0100 (CET)
          MMM-ModuleScheduler will next dim all modules at Mon Dec 19 2016 20:00:00 GMT+0100 (CET)
          MMM-ModuleScheduler will next show all modules at Sat Dec 24 2016 08:00:00 GMT+0100 (CET)
          MMM-ModuleScheduler will next dim all modules at Sat Dec 24 2016 20:00:00 GMT+0100 (CET)
          Many thanks for your support!
          Christian
          • I Offline
            ianperrin @anatius
            Hi @anatius (Christian)
            Okay, I think I see the problem, and a fix is in the works, its just going to take a little time until I can finish it.
            I’ve created an issue on github which contains more details on why this is happening.
            Until the fix is in place, you have two (understandably sub-optimal) options
            • leave the mirror running and it should self-correct after the next 8pm and/or 7/8am depending on when it is started :(
            • temporarily use the same expression for all days of the week, e.g.
            global_schedule: [ {from: '0 7 * * *', to: '0 20 * * *', dimLevel: '30'} ]
            A 1 Reply Last reply Reply Quote 1
              anatius @ianperrin
              @ianperrin
              Hi Ian,
              Thanks for the support. You are right indeed, the error corrects itself the first time the scheduler sets the module to undimmed. It is just that the starting conditions are not correct, but this is no big deal for me. It is just that I was too impatient to wait for the scheduler to change status for the first time…
              Christian
              • L Offline
                lucallmon
                Firstly, thanks for making such an awesome module!
                However, I can get it to work with all of my modules except one… I can’t get it to work with MMM-Instagram. I have it set up just like all of my other modules, but this one just ignores the scheduler script and always runs, never following the code. Here is the module code in config.js:
                		      	module: 'MMM-Instagram',
                		        position: 'top_right',
                			classes: 'scheduler',
                				module_schedule: [
                					{from: '0 5 * * 1-5', to: '0 9 * * 1-5'},
                					{from: '0 17 * * 1-5', to: '0 22 * * 1-5'},
                					{from: '0 6 * * 6-7', to: '0 24 * * 6-7'}
                		                access_token: '//ACCESS_TOKEN//',
                		                count: 200,
                		                min_timestamp: 0,
                		                animationSpeed: 2500,
                                		updateInterval: 12000
                any thoughts? here’s a picture of what it looks like when the scheduler is active: https://goo.gl/photos/K3S6HA7m61j5iSEe8
                • L Offline
                  lucallmon @lucallmon
                  @ianperrin @cowboysdude
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @lucallmon
                    @lucallmon Honestly I’m a bit lost on this one… I’m going to defer to @ianperrin for this one…
                    • L Offline
                      lucallmon
                      alt text
                      https://goo.gl/photos/dFMRL8JkvE5XWvaN7
                      This is what I get when I wake up and the monitor was supposed to go off at night and then turns back on in the morning. This happens every morning. Essentially, the monitor signal cuts but it never actually turns off or enters a low power state as it does when I actually shut down the Pi. This only happens when it’s overnight. When I do a trial off for a few minutes, it doesn’t do it. I think it might be the crappy old monitor, but I don’t know. Any thoughts?
                      • L Offline
                        I have found that this white screen that happens every day essentially freezes the entire Magic Mirror and I have to press CRTL+Q to restart. It doesn’t actually freeze the entire RPi.
                        • SnilleS Offline
                          Snille Module Developer
                          Hi there!
                          Thank you for this excellent module! :)
                          I would like to use the scheduler together with “Profile Switcher”.
                          Scenario:
                          • Let’s say normally I always show “Clock”, “Monthly calendar” and “Wounderground Weather” (local weather).
                          • Then on Mondays and Wednesdays at 05:30 to 07:30 I would like to also show “Weather” and “weather forecast” (in my case for another location).
                          • Then I would like to have a “profile” called “Snille” who (when activated) shows all of the above plus also “System Status” and “Bitcoin” (for example).
                          I have tried this, but it seams that when a module is scheduled, it get’s “locked” by the scheduler and therefore the “Profile Switcher” can not show it…
                          Getting this in the console (when selecting the profile):
                          Will not show currentweather. LockStrings active: module_0_MMM-ModuleScheduler
                          Will not show weatherforecast. LockStrings active: module_0_MMM-ModuleScheduler
                          If I “force” to unlock (using my Modlulebar to show and hide) the module it can be showed with the “Profile Switcher”.
                          I’m thinking… Do you have to “lock” the modules with the scheduler? :)
                          • SnilleS Offline
                            @ianperrin I have sent a PR to you adding an option to solve the problem. :)
                            • K Offline
                              kasperb
                              Hello all,
                              @ianperrin Thanks for the great module!
                              I’ve been using MMM-ModuleScheduler successfully for a couple of weeks, however, after a recent update the module is no longer working as designed. It appears that the correct SHOW & HIDE commands are being send (see logs below), however, the modules do not appear or disappear from the MM itself.
                              The only command that works well is the HDMI on/off. Any guidance or insight is appreciated.
                              Thanks!
                                | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Thu Apr 20 2017 23:30:00 GMT-0400 (EDT) based on "30 23 * * *"
                              0|mm       | Powering off HDMI
                              0|mm       | MMM-ModuleScheduler is sending HIDE_MODULE to module_11_MMM-ImagesPhotos
                              0|mm       | MMM-ModuleScheduler will next send HIDE_MODULE to module_11_MMM-ImagesPhotos at Thu Apr 20 2017 23:45:00 GMT-0400 (EDT) based on "45 23 * * *"
                              0|mm       | MMM-ModuleScheduler is sending SEND_NOTIFICATION to REMOTE_ACTION
                              0|mm       | MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Fri Apr 21 2017 06:00:00 GMT-0400 (EDT) based on "0 6 * * *"
                              0|mm       | MMM-ModuleScheduler is sending SHOW_MODULE to module_4_localtransport
                              0|mm       | MMM-ModuleScheduler will next send SHOW_MODULE to module_4_localtransport at Fri Apr 21 2017 06:00:00 GMT-0400 (EDT) based on "0 6 * * *"
                              0|mm       | MMM-ModuleScheduler is sending SHOW_MODULE to module_6_iFrame
                              0|mm       | MMM-ModuleScheduler will next send SHOW_MODULE to module_6_iFrame at Fri Apr 21 2017 06:00:00 GMT-0400 (EDT) based on "0 6 * * *"
                              0|mm       | Powering on HDMI with preferred settings
                                ArkantosArk
                                Hi All and thanks to @ianperrin for creating this awesome module.
                                I’m trying to schedule my screen to turn it on and off in specific times from Monday to Friday, and doing also the same thing in different times on weekend.
                                Right now this is my configuration, but is not quite working:
                                module: ‘MMM-ModuleScheduler’,
                                notification_schedule: [
                                // TURN THE MONITOR/SCREEN ON AT 08:00 EVERY DAY
                                {notification: ‘REMOTE_ACTION’, schedule: ‘0 8 * * * 1-5’, payload: {action: “MONITORON”}},
                                // TURN THE MONITOR/SCREEN OFF AT 09:30 EVERY DAY
                                {notification: ‘REMOTE_ACTION’, schedule: ‘30 9 * * * 1-5’, payload: {action: “MONITOROFF”}},
                                // TURN THE MONITOR/SCREEN ON AT 19:00 EVERY DAY
                                {notification: ‘REMOTE_ACTION’, schedule: ‘0 19 * * * 1-5’, payload: {action: “MONITORON”}},
                                // TURN THE MONITOR/SCREEN OFF AT 23:00 EVERY DAY
                                {notification: ‘REMOTE_ACTION’, schedule: ‘0 23 * * * 1-5’, payload: {action: “MONITOROFF”}},
                                // TURN THE MONITOR/SCREEN ON AT 10:30 WEEKEND
                                {notification: ‘REMOTE_ACTION’, schedule: ‘30 10 * * * 6-7’, payload: {action: “MONITORON”}},
                                // TURN THE MONITOR/SCREEN OFF AT 21:00 WEEKEND
                                {notification: ‘REMOTE_ACTION’, schedule: ‘0 21 * * * 6-7’, payload: {action: “MONITOROFF”}},
                                // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                {notification: ‘REMOTE_ACTION’, schedule: ‘0 2 * * SUN’, payload: {action: “RESTART”}}
                                Can somebody tell me if this is the right way to do it or if there is some kind of issue there?
                                Thanks!
                                • H Offline
                                  Henrik
                                  When “hiding” a module, does that also stop it from executing? I’m looking for a way to reduce the number of API calls made, by disabling a module at night.
                                  If not, any other suggestion on how to achieve this?
                                  Thanks in advance.
                                  I 1 Reply Last reply Reply Quote 1
                                  • I Offline
                                    ianperrin @Henrik
                                    @Henrik
                                    It’s not possible for MMM-ModuleScheduler to affect the behaviour of the modules it hides/shows.
                                    However, it is possible for a modules to ‘react’ to being shown/hidden.
                                    To reduce the API calls the developer of the modules you use could implement/subclass the suspend and resume methods.
                                    B 1 Reply Last reply Reply Quote 2
                                      bachoo786 @ianperrin
                                      @ianperrin hi thanks for this module.
                                      I used it to turn my uknationalrail module on and off at certain times. However what I noticed was that your module disables my uknationalrail module I.e. it turns it on but then it doesn’t update. If I remove your module and the settings of your module on my module it works fine.
                                      Is this a bug?
                                      • FoziF Offline
                                        Fozi Project Sponsor @bachoo786
                                        @bachoo786 I had the same issue with MMM-googlemaps-route. The module was switched on at the defined time, but the map was not updated, only the travel times. Unfortunately, I had to find turn off the scheduler, but found a workaround for the route module to reduce the number of API calls.
                                          bachoo786 @Fozi
                                          @Fozi ah right well i would like to turn it on and off I have used remote control module as well but I face the same issue. I can adjust to reduce the number of API calls but thats least of my worries as I would like to have a clean MM interface hence turning off the module would be awesome provided it worked.
                                          • I Offline
                                            ianperrin @bachoo786
                                            @bachoo786 MMM-ModuleScheduler (and MMM-RemoteControl) are only sending hide/show requests via the MagicMirror API, so have no control over the target modules upstream API calls.
                                            However, it may be possible something is amiss. Can you post your config and I’ll see if I can spot anything?
                                            • 4 / 5
