    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 163.5k Views 20 Watching
    • MichMichM Offline
      MichMich
      Any ETA for https://github.com/ianperrin/MMM-ModuleScheduler/issues/4 and https://github.com/ianperrin/MMM-ModuleScheduler/issues/6?
      I 2 Replies Last reply Reply Quote 0
      • I Offline
        ianperrin @MichMich
        @MichMich said in MMM-ModuleScheduler:
        Wow - someone is keen ;)
        The first iteration of #4 has been committed. Global schedules can now be added to show/hide/dim all modules - see the updated documentation for more info.
        On the to list is to
        • add support for showing/hiding/dimming modules in groups
        • add the ability to exclude specific modules from the global schedules
        #6 comes afterwards when I can switch my dev environment to the develop branch
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        • I Offline
          ianperrin @MichMich
          @MichMich
          • one schedule can now be used to hide/show/dim all modules - see global scheduling
          • one schedule can now be create to hide/show/dim a group of modules - see group schedules
          To do:
          • add the ability to exclude specific modules from the global/group schedules
          • unit and regression tests ;)
          • MichMichM Offline
            MichMich
            Nice work! LockStrings are not yet implemented, right? Until then I can’t use the module.
            • cowboysdudeC Offline
              I’m using it like this… but it’s not working for some reason:
              module: ‘MMM-ModuleScheduler’,
              global_schedule: [
              // SHOW MODULES WITH THE CLASS ‘daytime_scheduler’ AT 06:00 AND HIDE AT 22:00 EVERY DAY
              {from: ‘50 6 * * *’, to: ‘0 9 * * *’, groupClass: ‘scheduler_mfm’},
              {from: ‘50 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_mfd’},
              {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_sat’},
              {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_sun’},
              {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_nflg’},
              {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_nflng’}
              Then for example a module:
              		module: 'compliments',
              		position: 'lower_third',
                                  classes: 'scheduler_mfm'
              I did update the module with ‘git pull’ so that’s okay but it’s not rendering correctly and shutting the module ‘off’
              Did I miss something simple again? :)
              • I Offline
                ianperrin @cowboysdude
                @cowboysdude - During my testing of the global scheduling feature, I identified an issue which meant the initial state of the modules may not have been correct. I’ve committed a potential fix for this which may fix your issue too so please feel free to git pull again and test.
                If it doesn’t work, can you let me know what is output in the logs pm2 logs mm - you should see something like the following for each of your global schedules
                MMM-ModuleScheduler is creating a global schedule for scheduler_mfm modules using '50 6 * * *' and '0 9 * * *' with dim level undefined
                MMM-ModuleScheduler is hiding scheduler_mfm modules
                MMM-ModuleScheduler has created the global schedule for scheduler_mfm modules
                MMM-ModuleScheduler will next show scheduler_mfm modules at Tue Nov 01 2016 06:50:00 GMT+0000 (UTC)
                MMM-ModuleScheduler will next hide scheduler_mfm modules at Tue Nov 01 2016 09:00:00 GMT+0000 (UTC)
                The second line in the above log example will only appear if the schedule means that the modules affected it should be initially hidden
                • I Offline
                  ianperrin @MichMich
                  LockStrings should now be supported - feel free to test and let me know if it works as expected!
                    Will give it a try! Thanks @ianperrin !
                      anatius
                      I am trying to dim my mirror at nighttime - on weekdays between 10PM and 7AM, on weekends between 10Pm and 8AM. However, the below code does not do the trick - where is my mistake?
                      			module: 'MMM-ModuleScheduler',
                      				global_schedule: [
                      					{from: '0 7 * * 1-5', to: '0 20 * * 1-5', dimLevel: '30'},
                      					{from: '0 8 * * 0,6', to: '0 20 * * 0,6', dimLevel: '30'},
                      • I Offline
                        ianperrin @anatius
                        @anatius The config looks okay, can you check the output of the log pm2 logs mm once you have started MM2 and viewed it in a browser then post the results here?
                        It should look something like:
                        MMM-ModuleScheduler received INITIALISE_SCHEDULER
                        MMM-ModuleScheduler is setting the config
                        MMM-ModuleScheduler is removing all scheduled jobs
                        MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
                        MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
                        MMM-ModuleScheduler is creating a global schedule for all modules using "0 7 * * 1-5" and "0 20 * * 1-5" with dim level 30
                        MMM-ModuleScheduler is dimming all modules
                        MMM-ModuleScheduler has created the global schedule for all modules
                        MMM-ModuleScheduler will next show all modules at Mon Dec 19 2016 07:00:00 GMT+0000 (UTC)
                        MMM-ModuleScheduler will next dim all modules at Mon Dec 19 2016 20:00:00 GMT+0000 (UTC)
                        MMM-ModuleScheduler is creating a global schedule for all modules using "0 8 * * 0,6" and "0 20 * * 0,6" with dim level 30
                        MMM-ModuleScheduler will next show all modules at Sat Dec 24 2016 08:00:00 GMT+0000 (UTC)
                        MMM-ModuleScheduler will next dim all modules at Sat Dec 24 2016 20:00:00 GMT+0000 (UTC)
                          anatius @ianperrin
                          @ianperrin
                          Hi Ian,
                          Below is the relevant output of the log (error log is empty). Note that now (Monday at 3 PM) all modules are dimmed though they should not be…
                          MMM-ModuleScheduler will next show all modules at Tue Dec 20 2016 07:00:00 GMT+0100 (CET)
                          MMM-ModuleScheduler will next dim all modules at Mon Dec 19 2016 20:00:00 GMT+0100 (CET)
                          MMM-ModuleScheduler will next show all modules at Sat Dec 24 2016 08:00:00 GMT+0100 (CET)
                          MMM-ModuleScheduler will next dim all modules at Sat Dec 24 2016 20:00:00 GMT+0100 (CET)
                          Many thanks for your support!
                          Christian
                          • I Offline
                            ianperrin @anatius
                            Hi @anatius (Christian)
                            Okay, I think I see the problem, and a fix is in the works, its just going to take a little time until I can finish it.
                            I’ve created an issue on github which contains more details on why this is happening.
                            Until the fix is in place, you have two (understandably sub-optimal) options
                            • leave the mirror running and it should self-correct after the next 8pm and/or 7/8am depending on when it is started :(
                            • temporarily use the same expression for all days of the week, e.g.
                            global_schedule: [ {from: '0 7 * * *', to: '0 20 * * *', dimLevel: '30'} ]
                            A 1 Reply Last reply Reply Quote 1
                              anatius @ianperrin
                              @ianperrin
                              Hi Ian,
                              Thanks for the support. You are right indeed, the error corrects itself the first time the scheduler sets the module to undimmed. It is just that the starting conditions are not correct, but this is no big deal for me. It is just that I was too impatient to wait for the scheduler to change status for the first time…
                              Christian
                              • L Offline
                                lucallmon
                                Firstly, thanks for making such an awesome module!
                                However, I can get it to work with all of my modules except one… I can’t get it to work with MMM-Instagram. I have it set up just like all of my other modules, but this one just ignores the scheduler script and always runs, never following the code. Here is the module code in config.js:
                                		      	module: 'MMM-Instagram',
                                		        position: 'top_right',
                                			classes: 'scheduler',
                                				module_schedule: [
                                					{from: '0 5 * * 1-5', to: '0 9 * * 1-5'},
                                					{from: '0 17 * * 1-5', to: '0 22 * * 1-5'},
                                					{from: '0 6 * * 6-7', to: '0 24 * * 6-7'}
                                		                access_token: '//ACCESS_TOKEN//',
                                		                count: 200,
                                		                min_timestamp: 0,
                                		                animationSpeed: 2500,
                                                		updateInterval: 12000
                                any thoughts? here’s a picture of what it looks like when the scheduler is active: https://goo.gl/photos/K3S6HA7m61j5iSEe8
                                • L Offline
                                  lucallmon @lucallmon
                                  @ianperrin @cowboysdude
                                    cowboysdude Module Developer @lucallmon
                                    @lucallmon Honestly I’m a bit lost on this one… I’m going to defer to @ianperrin for this one…
                                    • L Offline
                                      lucallmon
                                      alt text
                                      https://goo.gl/photos/dFMRL8JkvE5XWvaN7
                                      This is what I get when I wake up and the monitor was supposed to go off at night and then turns back on in the morning. This happens every morning. Essentially, the monitor signal cuts but it never actually turns off or enters a low power state as it does when I actually shut down the Pi. This only happens when it’s overnight. When I do a trial off for a few minutes, it doesn’t do it. I think it might be the crappy old monitor, but I don’t know. Any thoughts?
                                      • L Offline
                                        I have found that this white screen that happens every day essentially freezes the entire Magic Mirror and I have to press CRTL+Q to restart. It doesn’t actually freeze the entire RPi.
                                        • SnilleS Offline
                                          Snille Module Developer
                                          Hi there!
                                          Thank you for this excellent module! :)
                                          I would like to use the scheduler together with “Profile Switcher”.
                                          Scenario:
                                          • Let’s say normally I always show “Clock”, “Monthly calendar” and “Wounderground Weather” (local weather).
                                          • Then on Mondays and Wednesdays at 05:30 to 07:30 I would like to also show “Weather” and “weather forecast” (in my case for another location).
                                          • Then I would like to have a “profile” called “Snille” who (when activated) shows all of the above plus also “System Status” and “Bitcoin” (for example).
                                          I have tried this, but it seams that when a module is scheduled, it get’s “locked” by the scheduler and therefore the “Profile Switcher” can not show it…
                                          Getting this in the console (when selecting the profile):
                                          Will not show currentweather. LockStrings active: module_0_MMM-ModuleScheduler
                                          Will not show weatherforecast. LockStrings active: module_0_MMM-ModuleScheduler
                                          If I “force” to unlock (using my Modlulebar to show and hide) the module it can be showed with the “Profile Switcher”.
                                          I’m thinking… Do you have to “lock” the modules with the scheduler? :)
                                          • SnilleS Offline
                                            @ianperrin I have sent a PR to you adding an option to solve the problem. :)
                                            • 3 / 5
