How do I edit config, I see every new module starts whit going to config.js
10 Posts 4 Posters 5.3k Views 3 Watching
  • K Offline
    KMH0
    I dont know what to do now … :(
    1. Duplicate config/config.js.sample to config/config.js.
    2. Modify your required settings.
    The following properties can be configured:
    S 1 Reply Last reply Feb 20, 2017, 3:24 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @KMH0
      @KMH0
      1. open a terminal type in cd ~/MagicMirror/config to change directory
      2. nano config.js
      3. After you made your changes press ctrl+x and confirm
      4. change directory to parent directory cd ..
      5. start the mirror npm start
      K 1 Reply Last reply Feb 20, 2017, 4:12 PM Reply Quote 3
      • K Offline
        KMH0
        Thanks! It worked :D Made my day
        • K Offline
          KMH0
          • K Offline
            KMH0 @strawberry 3.141
            @strawberry-3.141 So I was playing around, thinking I knew everything now and my mirror is blank… I was trying to add a module in the config, and now I messed up. Any suggestions?
            B 1 Reply Last reply Feb 20, 2017, 4:14 PM Reply Quote 0
              broberg Project Sponsor @KMH0
              @KMH0 post your config, this will help to indentify the issues
              K 1 Reply Last reply Feb 20, 2017, 4:23 PM Reply Quote 1
              • K Offline
                KMH0 @broberg
                @broberg
                var config = {
                        port: 8080,
                        language: 'en',
                        timeFormat: 24,
                        units: 'metric',
                                        module: 'alert',
                                        module: "updatenotification",
                                        position: "top_bar"
                                        module: 'clock',
                                        position: 'top_left'
                                        module: 'calendar',
                                        header: 'US Holidays',
                                        position: 'top_left',
        symbol: 'calendar-check-o ',
                                        module: 'compliments',
                                        position: 'lower_third'
                                        module: 'currentweather',
                                        position: 'top_right',
                                                locationID: '',  //ID from http://www.openweathermap.org
                                                appid: 'YOUR_OPENWEATHER_API_KEY'
                                        module: 'newsfeed',
                                        position: 'bottom_bar',
                                                feeds: [
        title: "New York Times",
                                                showSourceTitle: true,
                                                showPublishDate: true
                • Y Offline
                  yawns Moderator
                  You missed one ] which I added on 4th line from bottom
                  var config = {
                          port: 8080,
                          language: 'en',
                          timeFormat: 24,
                          units: 'metric',
                                          module: 'alert',
                                          position: "top_bar"
                                          module: 'clock',
                                          module: 'calendar',
                                          module: 'newsfeed',
                                                  feeds: [
                  K 1 Reply Last reply Feb 20, 2017, 4:31 PM Reply Quote 3
                  • K Offline
                    KMH0 @yawns
                    @yawns Thank you so much! But how do I add modules ? Do I just copy paste in to the config?
                    Y 1 Reply Last reply Feb 20, 2017, 5:00 PM Reply Quote 0
                    • Y Offline
                      yawns Moderator @KMH0
                      @KMH0
                      Actually it is always the same thing.
                      1. Find yourself a module you like, for example: MMM-IP
                      2. Top right on the github repository you see a green button saying “clone or download”. If you click it you get the url for this repository. In this case it is https://github.com/fewieden/MMM-ip.git
                      3. Open a terminal on your pi (either directly or using SSH) and type cd ~/MagicMirror/modules
                      4. Clone the module to your pi by typing git clone https://github.com/fewieden/MMM-ip.git. This downloads the repository and extracts it into a new folder.
                      5. Enter the new directory cd MMM-ip and run npm install (in this case it is not required … the readme should tell you to do so)
                      6. Edit your config file and add the code for the new module as the readme instructs to.
                      7. Restart your magic mirror process and check what happened.
                      Sidenote: If you run into trouble with your config file, you can always paste the content into http://jshint.com/. If everything is fine it will only show this which is fine:
                      One undefined variable
                      64	module
