How do I edit config, I see every new module starts whit going to config.js
I dont know what to do now … :(
- Duplicate config/config.js.sample to config/config.js.
- Modify your required settings.
The following properties can be configured:
- open a terminal type in
cd ~/MagicMirror/configtochangedirectory nano config.js- After you made your changes press
ctrl+xand confirm - change directory to parent directory
cd .. - start the mirror
npm start
Thanks! It worked :D Made my day
This post is deleted! -
@strawberry-3.141 So I was playing around, thinking I knew everything now and my mirror is blank… I was trying to add a module in the config, and now I messed up. Any suggestions?
@KMH0 post your config, this will help to indentify the issues
var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: "updatenotification", position: "top_bar" }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'lower_third' }, { module: 'currentweather', position: 'top_right', config: { location: 'New York', locationID: '', //ID from http://www.openweathermap.org appid: 'YOUR_OPENWEATHER_API_KEY' }}, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;} -
You missed one ] which I added on 4th line from bottom
var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: "updatenotification", position: "top_bar" }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'lower_third' }, { module: 'currentweather', position: 'top_right', config: { location: 'New York', locationID: '', //ID from http://www.openweathermap.org appid: 'YOUR_OPENWEATHER_API_KEY' } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;} -
@yawns Thank you so much! But how do I add modules ? Do I just copy paste in to the config?
@KMH0
Actually it is always the same thing.- Find yourself a module you like, for example: MMM-IP
- Top right on the github repository you see a green button saying “clone or download”. If you click it you get the url for this repository. In this case it is https://github.com/fewieden/MMM-ip.git
- Open a terminal on your pi (either directly or using SSH) and type
cd ~/MagicMirror/modules - Clone the module to your pi by typing
git clone https://github.com/fewieden/MMM-ip.git. This downloads the repository and extracts it into a new folder. - Enter the new directory
cd MMM-ipand runnpm install(in this case it is not required … the readme should tell you to do so) - Edit your config file and add the code for the new module as the readme instructs to.
- Restart your magic mirror process and check what happened.
Sidenote: If you run into trouble with your config file, you can always paste the content into http://jshint.com/. If everything is fine it will only show this which is fine:
One undefined variable 64 module
