    console.Log() shows nothing?
    Scheduled Pinned Locked Moved Solved Development
    19 Posts 8 Posters 17.2k Views 7 Watching
      mortenbirkelund
      @strawberry-3.141 said in console.Log() shows nothing?:
      console.log(“Debug Message”);
      Thanks for your reply. The “Log” in the title was a mistake.
      the console.log(); doesnth work either.
      Module.register("MMM-Slider",{
      	// Default module config.
      	defaults: {
      		//text: "Hello World!"
      	// Override dom generator.
      	getDom: function() {
      		console.log("Test");
      		wrapper.appendChild(createButton());
      		return wrapper;
      	start: function() {
      		console.log("Debug Message");
      	createButton: function() {
      		//Create the button
      		var button = document.createElement("button");
      		button.innerHTML ="Click me";
      		button.addEventListener("click", function() {
        			console.log("Visiting show URL");
      		return button;
      The above code was my simple attempt to create a button. The button is created, but nothing happens when i click it, and nothing is shown when MagicMirror is started.
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-ProfileSwitcher.
      No helper found for module: MMM-Slider.
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Launching application.
      Create new calendar fetcher for url: http://springschedule.au.dk/ical/ical.asp?objectclass=student&id=xxxxxx - Interval: 300000
      Shouldn’t the logs be visible in the command line?
      strawberry 3.141S I 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @mortenbirkelund
        @mortenbirkelund the module doesnt log in the terminal only the node_helper does. The module logs into electron or your browser start the mirror wih npm start dev
        • I Offline
          izanbard @mortenbirkelund
          @mortenbirkelund these console.log() statements are not crated in the node application, but in the browser. Open the mirror in a main stream browser (IE or chrome or something) and hit F12 which will bring up the dev tools look in the console there for your message.
          • yawnsY Offline
            yawns Moderator @strawberry 3.141
            @strawberry-3.141
            Just to add, because I found this irritating at first:
            If your browser does not open the console in dev mode then press F12 (works in every common browser) and look at the error/warning/log output there
            Ah, @izanbard was faster :-)
              mortenbirkelund
              npm start dev
              Thank you very much, both of you. Now I can see the logs.
              • I Offline
                @mortenbirkelund just a note if you put a console.log() in the node_helper, then it apears on the command line output (or PM2 out.log if you are using PM2)
                  mortenbirkelund
                  Thank you once again for your help. Now that I understand where to see the logs, i can see that my button is not working. Anybody who knows why nothing happens when I click the button
                  	defaults: {
                  		wrapper.appendChild(this.createButton());
                  		return wrapper;
                  		var button = document.createElement("span");
                  		button.id = this.identifier + "_button";
                  		button.addEventListener("click", function () {
                  			console.log("The button was clicked");
                  		return button;
                    mortenbirkelund
                    @Snille I have looked at your button module for inspiration. Do you know why nothing happens when I click the button?
                      mortenbirkelund
                      Found the error. I needed to add
                      .region.fullscreen {
                      z-index: -1;
                      as css and now it is working.
                      • SnilleS Offline
                        Snille Module Developer
                        Hmm… I don’t have any custom css om my develop-version of MM, but the problem is of course that you will not see the pointer when moving over to the “mirror” if you are using a mouse.
                        You can add a custom.css with only:
                        body {
                          cursor: pointer;
                        then you will see where you “are” when moving the mouse. :)
                        But you should not need anything else.
                        If you cant find it, make it and share it!
                        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
