    console.Log() shows nothing?
    Scheduled Pinned Locked Moved Solved Development
    19 Posts 8 Posters 17.0k Views 7 Watching
    • I Offline
      izanbard @mortenbirkelund
      @mortenbirkelund these console.log() statements are not crated in the node application, but in the browser. Open the mirror in a main stream browser (IE or chrome or something) and hit F12 which will bring up the dev tools look in the console there for your message.
      • yawnsY Offline
        yawns Moderator @strawberry 3.141
        @strawberry-3.141
        Just to add, because I found this irritating at first:
        If your browser does not open the console in dev mode then press F12 (works in every common browser) and look at the error/warning/log output there
        Ah, @izanbard was faster :-)
          mortenbirkelund
          @strawberry-3.141 said in console.Log() shows nothing?:
          npm start dev
          Thank you very much, both of you. Now I can see the logs.
          • I Offline
            @mortenbirkelund just a note if you put a console.log() in the node_helper, then it apears on the command line output (or PM2 out.log if you are using PM2)
              mortenbirkelund
              Thank you once again for your help. Now that I understand where to see the logs, i can see that my button is not working. Anybody who knows why nothing happens when I click the button
              Module.register("MMM-Slider",{
              	// Default module config.
              	defaults: {
              		//text: "Hello World!"
              	// Override dom generator.
              	getDom: function() {
              		wrapper.appendChild(this.createButton());
              		return wrapper;
              	createButton: function() {
              		var button = document.createElement("span");
              		button.innerHTML ="Click me";
              		button.id = this.identifier + "_button";
              		button.addEventListener("click", function () {
              			console.log("The button was clicked");
              		return button;
                mortenbirkelund
                @Snille I have looked at your button module for inspiration. Do you know why nothing happens when I click the button?
                  mortenbirkelund
                  Found the error. I needed to add
                  .region.fullscreen {
                  z-index: -1;
                  as css and now it is working.
                  • SnilleS Offline
                    Snille Module Developer
                    Hmm… I don’t have any custom css om my develop-version of MM, but the problem is of course that you will not see the pointer when moving over to the “mirror” if you are using a mouse.
                    You can add a custom.css with only:
                    body {
                      cursor: pointer;
                    then you will see where you “are” when moving the mouse. :)
                    But you should not need anything else.
                    If you cant find it, make it and share it!
                    Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                    • H Offline
                      hasbean @mortenbirkelund
                      @mortenbirkelund I know this is really 4 years old, but it was my first match on Google. I couldn’t figure out why logs weren’t printing to terminal.
                      Anyhow, to make Electron print to terminal, add this to the environment variables:
                      ELECTRON_ENABLE_LOGGING=1
                      Hope it helps others!
                      • E Offline
                        easty @hasbean
                        @hasbean For a complete beginner, how do you do add that statement to environment variables?
