    Weekly Calendar
    65 Posts 13 Posters 94.8k Views 21 Watching
    • K
      KirAsh4 Moderator @idkmynameiskyle
      @idkmynameiskyle, it doesn’t exist in the wild yet. I just started working on it yesterday. It’s going to be a (long) while still before I get to anything worth releasing.
      • K
        KirAsh4 Moderator
        Right, we have two different requests here. One is to display a simple, empty calendar, and another to display an actual Google Calendar with contents.
        • I
          idkmynameiskyle @KirAsh4
          @KirAsh4 I think the monthly compact view is an excellent addition to the default calendar. It looks great and it integrates well with the default design and layout.
          The running week would still be a great thing to have across perhaps the bottom of a vertical mirror so that people can see what days they have to work in a given week, or other quick-glance information.
          • K
            @idkmynameiskyle, yep, though again, I look at the amount of information one could possibly have on any given day and how to format things neatly and visible.
            As an example, if I look at my Google calendar and pick one week (this week), this is what it looks like:
            Notice the '+7 more' line that I pointed out. I can’t see those in a standard weekly view. I have to either click on the link there, which trigers a pop-up with the remaining items, or switch to a daily view to see it all.
            Again, this is me personally. Your calendar may not be as crazy populated as mine (and I even turned OFF two others for this.) But I have to think of the possibility that someone might have multiple events in one day, specially in a family setting where everyone is doing their own thing.
            • K
              KirAsh4 Moderator
              This thread got very long and encompasses two different things:
              • The request to make a weekly calendar view, which then turned into
              • Another request for a plain (empty) monthly view as well.
              The latter has been addressed, and is for all intents and purposes, ready. However, it no longer applies to the original post’s request. So I’m going to split this up into two separate threads. I’ll try to move the relevant posts around and clean things up a bit (if possible.)
              Those of you wanting the Weekly Calendar, please continue the discussion here. Those of you wanting the Monthly Calendar, you can continue the discussion on the new thread.
              • K
                KirAsh4 Moderator
                Small update:
                • Rewrote most of the module to use DOM elements instead of hard-coding HTML tags
                • Added calendar symbols to events
                This is captured on a landscape monitor. When I’m at work, that’s what I have to work with. Things get a bit squirrely on a portrait layout because of long titles. need to fit the CSS alignment on that.
                • K
                  KirAsh4 Moderator
                  Guess I can always fake a portrait screen. Proper alignment done.
                  • I
                    @KirAsh4 That looks incredible!!
                    • K
                      KirAsh4 Moderator
                      Thanks. Slowly working through it.Need to roll in those multi-day events … seeing some stuff from our work calendar that isn’t displaying correctly … yet. Just a matter of proper parsing and displaying …
                      • K
                        KirAsh4 Moderator
                        Harder part is going to be adding time display to the events … or, an hourly view. Thinking of real estate again. How many arrays can I nest … :)
                          Mitchfarino Module Developer @KirAsh4
                          @KirAsh4 I’m really looking forward to this being released, it looks great and gives a better view than the default list.
                          Nice work, and thanks for putting the time in
                            billp100
                            Wow…Awesome work, that is pretty damn close to what I was envisioning…Thank you for your work
                            • K
                              KirAsh4 Moderator
                              The issue with taking up most of the screen is … that it’s not easily done. There are several “regions” on the screen that are constrained to a specific size so they don’t overlap others. Even on my large vertical screen, I can’t display a full 24 hour list. I’m flirting with the idea of limiting it to 12 hours (say 7am to 7pm) but that’s still stuff to just play with. As I said, this isn’t anywhere near even a test phase.
                              • K
                                KirAsh4 Moderator
                                Writing this code is not for the faint of heart. I will put out this warning: this may or may not result in the final piece. And the reason I say this is simply because of how difficult it is to deal with the various overlays. I may end up scrapping this idea completely and go for a different solution that may or may not end up looking similar. (Yes I’m aware that the time starts at midnight … the actual element takes up the whole screen, it’s been pushed down and ‘height restricted’.)
                                • K
                                  KirAsh4 Moderator
                                  And I seriously can not fathom that this thread has almost 1,000 views. Sheesh guys … you’re making me giddy. :)
                                  • W
                                    Wilco89
                                    Looks very Nice, but I think this will fill my Screen a bit to much.
                                    Maybe there is also 1 Step back and then with numbers under the title “starttime - endtime”?
                                    • K
                                      KirAsh4 Moderator
                                      Fill as it too wide? It’s merely following the regions defined within MM. Or do you mean height? At the moment it’s restricted. I can’t follow the regions there because otherwise there’s very little that can fit. So it’s an overlay “on top” of everything else and then I forcibly restrict the height. It’s not a perfect solution and it’s only being done to get the layout right.
                                      As for a ‘step back’, I’m not sure what you mean. You mean going back to what I posted yesterday? Yeah that code didn’t go away (I never get rid of code that way). This right here is literally an exercise. I wanted to see what it would take, how much and whether it can be done. I also needed a hair cut, and this helped with me pulling my hair out at times. :)
                                        Mitchfarino Module Developer @Wilco89
                                        @Wilco89 yeah, it seems to take up too much real estate on screen.
                                        So a lot of the reflection will be the calendar.
                                        Must be hard to work with he regions available though
                                        • W
                                          Wilco89 @KirAsh4
                                          @KirAsh4 the width won’t be the problem, height will.
                                          When you should use your yesterdays post and set startingtime and EndTime under the title of the appointment, it would be usefull for my mirror, otherwise it will fill my mirror too much.
                                          I Hope you van make that to An module.
                                          (Sorry for typo’s, using my phone with autocorrect (dutch))
                                          • K
                                            KirAsh4 Moderator
                                            Geen probleem. Yeah, since I’m just testing things out, I wouldn’t worry too much about what it looks like right now. I won’t make something that won’t work for people. I tend to make it all user configurable anyway, so don’t worry about that part.
                                            • 2 / 4
